oliver2-44 11,750 #26 Posted February 6, 2025 (edited) The steering wheel turned out quite well for a worker. After blasting and cleaning the pitting on the PTO I I filled the pits with the 1000 deg F JBWeld Product. I bead blasted the head. Then I sanded it flat using a piece of glass and 220, 320, 600 wet or dry sand paper. Edited February 6, 2025 by oliver2-44 2 Share this post Link to post Share on other sites
oliver2-44 11,750 #27 Posted February 6, 2025 25 minutes ago, Easton Rich said: Where did you get that flywheel puller? That’s from Harbor Freight. I’ll get a picture of the set for you tomorrow. Share this post Link to post Share on other sites
Easton Rich 1,260 #28 Posted February 6, 2025 Thanks Share this post Link to post Share on other sites
Retired Wrencher 6,989 #29 Posted February 6, 2025 On 2/2/2025 at 10:28 AM, JCM said: Thanks for the mention. You don't seem like the type of person that sits idle too long. and I like that. Your a good man. @oliver2-44 Keep on trucking !! Ditto. 2 Share this post Link to post Share on other sites
Retired Wrencher 6,989 #30 Posted February 6, 2025 6 hours ago, oliver2-44 said: The steering wheel turned out quite well for a worker. After blasting and cleaning the pitting on the PTO I I filled the pits with the 1000 deg F JBWeld Product. I bead blasted the head. Then I sanded it flat using a piece of glass and 220, 320, 600 wet or dry sand paper. @oliver2-44 The best thing I found for doing heads is a good 2x2 or I use a 4x4 piece of flat steal plate and 320 grit. You’re doing a great job so far. Enjoy the project and the ride when done.. 2 Share this post Link to post Share on other sites
oliver2-44 11,750 #31 Posted February 12, 2025 On 2/5/2025 at 9:35 PM, Easton Rich said: Where did you get that flywheel puller? This is the harbor Freight Puller set. Share this post Link to post Share on other sites
oliver2-44 11,750 #32 Posted February 25, 2025 (edited) Before I started disassembling parts of the engine I did a Leak Down Test. I had 40psi on the high side and got 15psi on the low side. Major leakage on the Intake Valve side. I couldn’t detect any leakage on the exhaust valve or the crankcase/piston rings. I don’t think those got a good test with so much leakage on the Intake valve. I double checked that I was at top of the stroke and both valves closed. I also rechecked my valve clearance to make sure the intake wasn’t being held open. So I pulled both valves. They don’t have any slop in the valve guides. I measured the stems and they are like new. Not much carbon on them, but I buffed them clean on my wire wheel. The valves and seats don’t show any pitting. I used some fine lapping compound and it looks like they did a bad valve job when they bored it 0.030 over 10 years ago. The exhaust is only making contact on a knife edge on the outer diameter. The Intake Valve measures a very wide 0.110 lapped seating area width instead of the 0.045 max width spec. Calling all Overhaul Guru’s. @Achto @buckrancher @lynnmor @pfrederi @WHX?? @Ed Kennell @squonk Othets? So why is the Intake Valve leaking so much? Is it because the seat is so wide which spreads the spring tension over the to wide an area to hold it tightly closed. With the large amount of leakage on the Intake valve any other things I should look at? Did they maybe get the angle wrong on the seats? I’m thinking they replaced the valves since the stems measure so good. So they would not have needed to grind the valves. Any thoughts comments on the knife edge seal on the Exhaust valve. Any comments on having a shop retiring the valves and seats? The exhaust seems to sit low so Is there enough metal left on the seat to regrind? Edited February 26, 2025 by oliver2-44 Share this post Link to post Share on other sites
Achto 32,691 #33 Posted February 25, 2025 9 minutes ago, oliver2-44 said: Any comments on having a shop retiring the valves and seats? The exhaust seems to sit low so Is the enough metal left on the seat to regrind? This is where a Neway valve seat cutter comes into play. The dies allow you to do a 3 angle valve job which will allow you to get your mating surface back where it belongs. I have a set for doing Harley valve seats (left over from wrenching on Harley's was my income) but I have not purchased the dies for Kohler engines yet. I save tractors sells a set, spendy but you might be able to find it cheaper else where. Should also be able to find a local shop that will cut them for less than the price of the kit. https://isavetractors.com/neway-valve-seat-cutting-kit-deluxe-3-angle/?utm_source=google&utm_medium=x&utm_campaign=21521624119&utm_content=&utm_term=&ref=smart&gad_source=1&gclid=Cj0KCQiA8fW9BhC8ARIsACwHqYrs44c0_5yZQwtn-hBjzkcCwMpZIO_LMsA2H-xFGvdEaZxqdq76g7saArjnEALw_wcB I have not had a Kohler that has needed more than a good lapping. When I built the engine for my Pulling tractor I had a 12 angle valve job done. Super sealing, but still not sure if the results was worth the $. 1 Share this post Link to post Share on other sites
ebinmaine 80,695 #34 Posted February 25, 2025 22 minutes ago, Achto said: 12 angle valve job I've read here n there that's a good way to make a flathead breathe better. 1 1 Share this post Link to post Share on other sites
squonk 48,119 #35 Posted February 26, 2025 I have tried pressuring the intake and exhaust ports and using soap to see the leakage only to find out the air was overwhelming the springs and slightly opening the valves giving the impression they were not sealing. 1 Share this post Link to post Share on other sites
WHX?? 58,115 #36 Posted February 26, 2025 (edited) Don't know if this would in your case Ollie. It worked on a techy vertical Superglued different grits sand paper to the valve & used the lapping tool for a drill. Saw it done on you tube Didn't work too bad & wasn't perfect but good enough for a techy on a RE-67 putt around cruzer . Didn't want to get the $$ seat cutter for a one time use. Yet to have a Kohler I couldn't straiten out with regular lapping. I used a new valve and I would replace the exhaust one if that were my motor. Be sure to check the valve lash. Edited February 26, 2025 by WHX?? 1 Share this post Link to post Share on other sites
WHX?? 58,115 #37 Posted February 26, 2025 1 hour ago, Achto said: I have a set for doing Harley valve Can a guy get the cutters fairly reasonable for it for a Kohler Dan? 2 Share this post Link to post Share on other sites
Achto 32,691 #38 Posted February 26, 2025 6 minutes ago, WHX?? said: Can a guy get the cutters fairly reasonable for it for a Kohler Dan? Never priced them out. Handles & what not are prolly cheap, the carbide cutters/dies are where the $ is. 2 Share this post Link to post Share on other sites
WHX?? 58,115 #39 Posted February 26, 2025 1 minute ago, Achto said: carbide cutters/dies are where the $ is. Seats for the Clinton couldn't hurt. 3 Share this post Link to post Share on other sites
oliver2-44 11,750 #40 Posted September 24 Finally getting back to this one. No crank, so I went through all the electrical cleaning connections and coating with dielectric grease. I had replaced the solenoid with a 4 terminal. Learned the unused 4terminal needs to be grounded. PO had removed all safety switches and still no crank. Remembered the voltage regular connection. That was it, the terminals were loose on the meter. So it cranked, but no spark. I had previously cleaned the points an did a static timing. I had voltage to the points, but they just didn’t act right. I finally replaced them and still no spark. I was trying to read points with my meter so I had my wife come out ant turn the key. Bingo blue spark in the spark tester I still had connected. Of course she asked why I’d been working on it all day PS I need some new black plastic pieces that hold the terminals on the key switch and regulator. Does anyone have a part name/number and vendor? @953 nut @Racinbob So now I’m ready to put gas in it tomorrow. I’m really curious how it will run with my previous leakdown test and not great valve seating. I have the valve and seat grinder I bought a while back, but I wanted to see how it would run. It’s been 50 years since I used a valve and seat grinder. Trying to fix a previous marginal seat grinding may not be the best place to start. I have a junk block I’ve been meaning to practice on. 5 1 Share this post Link to post Share on other sites
Racinbob 13,188 #41 Posted September 24 7 hours ago, oliver2-44 said: PS I need some new black plastic pieces that hold the terminals on the key switch and regulator. Does anyone have a part name/number and vendor? @953 nut @Racinbob I've always called them Delphi Packard connectors but that might be a brand name. I just use uninsulated crimp connectors and double heat shrink them. Share this post Link to post Share on other sites
WHX?? 58,115 #42 Posted September 24 8 hours ago, oliver2-44 said: Finally getting back to this one. Yes and I had to go back through the posts to pickup where we left off ! Thoughts on the PTO why couldn't he just turn down on a lathe or brake drum machine? Share this post Link to post Share on other sites
953 nut 69,293 #43 Posted September 24 8 hours ago, oliver2-44 said: PS I need some new black plastic pieces that hold the terminals on the key switch and regulator. Does anyone have a part name/number and vendor? The five terminal ignition switch connector is easy to come by on eBay https://www.ebay.com/itm/387663699009? or at Dell https://www.delcity.net/search/? Dell City has a great selection of fittings if you need more than just the ignition switch socket. As for the voltage regulator here are the numbers, eBay is about the only place you will find either one Kohler electrical connector numbers Voltage regulator/rectifier for magnum and K-twin 25 155 41-S Voltage regulator/rectifier 15 amp Kohler K Series 237429S Share this post Link to post Share on other sites
oliver2-44 11,750 #44 Posted Wednesday at 09:05 PM (edited) After fighting with intermittent spark and power I threw in the towel and did a simple rewire. Problem solved! For now none of the safety switches are wired in, and they were previously jumpered. My new wiring is set up to include them after I remove and clean/test each of them. With a little cranking to get fuel to the carb it fired right up. Did some quick carb adjustments and it runs better that I though it would. I had previously drained the transmission and let it hang with front raised up over night. The oil was gray, but no free water. So I filled it with 1/2 diesel nd 1/2 ATF that I wanted to use up. THE GOOD - it drove around.in 1st and Reverse, Hi & Lo. THE BAD - no 2ND OR 3RD GEAR, NOTHING, not even a scratching when I shift. I ran out of time and will get back to this maybe this weekend.' @stevasaurus @953 nut @WHX?? @Achto give me some hope that maybe I just did something stupid when I put the shifter in. 1st thing I'll check is pull the shifter and make sure the shift rails form a square box hole for the shifter to go into. Could I really have gotten the shifter in if one shift rail was completely to one side? I sure seems it has to be something simple for there to just be nothing there. Then again I guess the shift fork could be broke off the rail. Edited Thursday at 01:43 AM by oliver2-44 3 1 Share this post Link to post Share on other sites
stevasaurus 23,856 #45 Posted Thursday at 09:03 PM Just thinking how this could happen with out knowing a whole lot about this trans. If you pull the shifter, check out the part of the shift forks that would hold the shifter. One thing it could be...roll pin is gone from the shift rail and the part is just sliding on the shaft. Waiting to see what you find. 2 Share this post Link to post Share on other sites
Racinbob 13,188 #46 Posted Thursday at 10:11 PM That sounds like a strong possibility Steve. Or the 3/2 gear isn't hooked to the fork or the fork is broken. Gotta wonder how that could happen though. 🤔 1 Share this post Link to post Share on other sites
