Cee245 861 #1 Posted May 20, 2022 First off, I Got to meet a couple of nice fellas when picking this up. @squonk, @rjg854 Would have liked to chat more but I did get back in time to coach our junior little league and go to my appointment.. much Thanks again and your friend is in my prayers. Soooo......I drove 380 miles to pick up this 1975 C160. Not too bad. I have numerous things to do like checking of wear areas and parts, improvements, etc to do to this thing... Definitely needs all fluids / filters replaced and I'll put a plug in and tune it up... I'm hoping to purchase a few thousand gallons of the Lucas tacky green?? Red?? HD?? grease @peter lena likes and just dip the whole thing in it. OR I'll go over stuff and put a dab here and there like he talks about to help keep costs down. lol Plan is give this the attention it needs. A few things need fixed like the hood latch and brake pedal as they are snapped off (see pics) (oh and if you have one in good shape or at least complete PM me please!) I don't think I wanna know how that cast iron foot pedal broke!? Must've been a great story Also, I noticed the engine isn't mounted on the right side. Cant be stock?? Replacement? Not 100% sure of too much of anything on this yet .... I'll look into it when I go over everything else. Just seemed strange. Runs and moves decent. Anyway, I borrowed a battery out of my 416 and moved it inside and very briefly looked the C160 over again. This looks like a solid candidate for bringing out the patina I see guys referring to sometimes......If dipping it in slippery Pete's grease doesn't pan out, any tricks of the trade on that? I did notice where a tiedown strap I had on wrong rubbed a little spot on the hood, it actually looked what I think is pretty good in that little spot now. Another cool thing about this is I noticed I can SEE a ton more on this compared to my 416 onan or kohler 417A. Of course the twins will be bigger,, but I was surprised to the room...Looks easier to work on with more room to get at stuff. Really liking the flip up seat and pan. That's a nice feature or seems like it would be. Although I'm not so sure about the seat. Thinking I may switch to a different style. That's just me. Back rest looks nice though. looking forward to working on this. And that muffler is .....? For some reason I kinda like it. Maybe use some of my high heat paint and make it black at least for now...... Cory 1 11 Share this post Link to post Share on other sites
daveoman1966 3,884 #2 Posted May 20, 2022 I also have a C-160 Auto..with hyd lift. The K341 engine has two bolts from the bottom going into the Oil Pan... Mine is the same. If you are in need of parts...like the broken pedal...or other stuff, I am not far from Erie... Near Saegertown (Blooming Valley actually). The one thing I would caution you on: The Sundstrand Hyd unit is very sensitive to any sort of debris in the oil...so take care when changing the oil... WIPE down everything around the filter and fill spout. The internals of the pump are soft BRASS and easily scarred...leading to poor performance. I've rebuilt about a dozen of these...that's how I know. 3 5 Share this post Link to post Share on other sites
Retired Wrencher 6,979 #3 Posted May 20, 2022 Cory nice pickup big block 16. That will get it done with power to spare. 3 Share this post Link to post Share on other sites
squonk 48,079 #4 Posted May 20, 2022 All of the C series tractors with big blocks bolt from the bottom on the right side. Pedal is specific for hydros. I had a pedal here for a manual but it wouldn't work. Trans filter is a Wix 51410 or Napa 1410. 5 Share this post Link to post Share on other sites
Ed Kennell 47,268 #5 Posted May 20, 2022 Nice save Cory Dave and Mike got you covered on the hidden engine bolts on these big singles. Come to the Big Show and you'll find a match in my bucket of pedals. 7 Share this post Link to post Share on other sites
ebinmaine 80,653 #6 Posted May 20, 2022 Great find on that tractor! Excellent when you get to meet other members. Once you get that Beast up and running you'll find out just how valuable it is as a worker. 16 single and a 17 twin are pretty comparable but that big heavy thumping of a 16 is unique. To give yourself a printable tool that can be used for a really good going over piece by piece take a look at our New To The Herd Checklist. 3 Share this post Link to post Share on other sites
JoeM 10,252 #7 Posted May 20, 2022 Every tractor has a story and now that rub mark is a cool part of the story! A nice machine in very capable hands! 3 Share this post Link to post Share on other sites
rjg854 13,342 #8 Posted May 20, 2022 Was nice meeting you also, Cory. 5 Share this post Link to post Share on other sites
peter lena 10,047 #9 Posted May 20, 2022 @Cee245 looks like a nice pick up , referring to comments , ideas, patina saving to me is easy , initially just an aerosol lubrication soak down , let dry then rub down clean cloth , do it again , watch metal soak up oil stopping rust and feeding paint . recommend rislone , zinc oil treatment and rislone 30 wt ,https://www.amazon.com/Rislone-4405-Supplement-Concentrate-Treatment/dp/B0075559UY?th=1 , look on bottle back for details . thats what I use , amazing engine ease as it frees up the crud in there , hot coal black oil changes , repeat . I don,t dip things in lucas green , but use it any ware there is need for no failure lubricant . make rust run out of long neglected linkage ends , was already thinking of how I would start initial recovery , get oil soaking on every rusted area , drain fuel tank , replace valve and grommet , soak throttle and choke cables , you know the drill . keep it greasy , ill be watching . good luck , pete 3 Share this post Link to post Share on other sites
peter lena 10,047 #10 Posted May 20, 2022 @Cee245 refered to rislone 30 wt , meant rotella 30 wt oil , must have slipped on the grease , pete 8 Share this post Link to post Share on other sites
kpinnc 18,940 #11 Posted May 20, 2022 If the transmission has ATF in it, go with that on the change. The Sundstrands originally came that way and WH later issued a bulletin that said 30W oil was an authorized alternative. Some got changed over, some didn't. That being said, ATF has cleaning and anti-condensation properties that can't be matched by oil. I've opened up hydros with ATF in them, and they look as shiny and clean as the day they were built. I will never change mine over after seeing the inside of hydros with ATF vs conventional oil. Night and day difference! 5 1 Share this post Link to post Share on other sites
ebinmaine 80,653 #12 Posted May 20, 2022 3 minutes ago, kpinnc said: That being said, ATF has cleaning and anti-condensation properties that can't be matched by oil. I've opened up hydros with ATF in them, and they look as shiny and clean as the day they were built. I will never change mine over after seeing the inside of hydros with ATF vs conventional oil. Night and day difference! I'll second that. 3 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,484 #13 Posted May 20, 2022 Looks like it has a Gravely muffler on it. Be interested in knowing if you think it has enough capacity. Have seen them on 12hp engines and anything larger was a twin cylinder with one for each cylinder. 2 Share this post Link to post Share on other sites
squonk 48,079 #14 Posted May 20, 2022 (edited) 1975 used motor oil in the hydro and that's what's in it. Do not use ATF. Personally I use Mobil 1 . I believe the sticker on the tractor says 10/30 or 10/40. I use 10/40 in mine as it's a tad weak and it seems to help. Edited May 20, 2022 by squonk 4 Share this post Link to post Share on other sites
ebinmaine 80,653 #15 Posted May 20, 2022 2 minutes ago, gwest_ca said: Looks like it has a Gravely muffler on it. Be interested in knowing if you think it has enough capacity. Have seen them on 12hp engines and anything larger was a twin cylinder with one for each cylinder. I've got one like that on my own 1975 C160 Automatic. Seems to run fine although it may be a little loud. Can't say for sure anything about the structural integrity of the muffler as I didn't originally install it. 1 Share this post Link to post Share on other sites
peter lena 10,047 #16 Posted May 20, 2022 @ebinmaine what ever else is going on , its just too obvious , you are having too much fun , amazing how that often relates with horse work , pete 1 1 Share this post Link to post Share on other sites
ebinmaine 80,653 #17 Posted May 20, 2022 Just now, peter lena said: @ebinmaine what ever else is going on , its just too obvious , you are having too much fun , amazing how that often relates with horse work , pete Every time Pete. Every single time. 2 Share this post Link to post Share on other sites
WHX?? 58,077 #18 Posted May 20, 2022 Bucket lister right ther! I might have that pedal if Ed don't Cee. I parted out a C square hood hydro awhile back. I have the hood latch rod too. Dibs on the seat ifn it don't grow on ya. That's my favorite style..... bonus arm rests!! 10 hours ago, Cee245 said: couple of nice fellas when picking this up. @squonk, @rjg854 The Bobbsey twins.... 3 Share this post Link to post Share on other sites
squonk 48,079 #19 Posted May 20, 2022 1 hour ago, WHX?? said: The Bobbsey twins.... Extra b and left out an "o" 2 1 Share this post Link to post Share on other sites
Cee245 861 #21 Posted May 20, 2022 Thanks for all the info everyone! @ebinmaine, I printed a copy of the checklist and will go through that so I don't forget anything... @Ed Kennell, as long as work cooperates, I'm going. Even if they don't let me, I have sick days accrued. I'll definitely look for you and @WHX??. Its so cool to me that all these little parts are in buckets and shelves (me included) and are willing to sell them. @WHX?? I'm definitely interested in the rod for the hood. And if I'm not mistaken, the Eaton 1100 is ALSO 1410 Napa? 3 Share this post Link to post Share on other sites
Handy Don 17,465 #22 Posted May 20, 2022 22 minutes ago, Cee245 said: And if I'm not mistaken, the Eaton 1100 is ALSO 1410 Napa? Yes 1 1 Share this post Link to post Share on other sites
johnnymag3 2,646 #23 Posted May 20, 2022 Dibs on the seat ifn it don't grow on ya. That's my favorite style..... I have a complete seat if you are interested !!!!! I am keeping the arm rests though. I will dig it out if necessary.. Heavy bugger to ship though John 1 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,484 #24 Posted May 20, 2022 I've got one like that on my own 1975 C160 Automatic. Seems to run fine although it may be a little loud. Can't say for sure anything about the structural integrity of the muffler as I didn't originally install it. Very quiet on the 12hp. Wonder if your inlet baffle is burnt out? That was my concern on the 16hp single cylinder. 1 Share this post Link to post Share on other sites
ebinmaine 80,653 #25 Posted May 20, 2022 4 minutes ago, gwest_ca said: Wonder if your inlet baffle is burnt out? Certainly possible. I've been meaning to check the points gap on that tractor as well. 1 Share this post Link to post Share on other sites
