ebinmaine 78,354 #226 Posted February 28, 2023 The BBT engine mechanic has the starter generator on. She made up a linkage rod for the carb to governor. Installed the carb. Need to find a belt for the SG.. 3 Share this post Link to post Share on other sites
ebinmaine 78,354 #227 Posted March 1, 2023 5 hours ago, ebinmaine said: Need to find a belt for the SG I'll be durned if'n we didn't have one hangin' on the wall.... Hey how do I find these rubber grommets for inside the fuel pipe from pump to carb? We bench tested the starter generator. It's good. I built a couple wires and Trina installed them. Confirmed the points setting at .020. Found a plug wire on the wall that desperately needed the @peter lena dielectric treatment. Freed up the stuck boot, de-bent the terminal and put that on. Use what ya have! We found a 5 terminal 103990 ignition switch, muffler, solenoid. Next time we get a minute we'll finish the wiring and try to put fire in the hole!! 4 Share this post Link to post Share on other sites
Moparfanforever 926 #228 Posted March 1, 2023 I think Lowell has the fuel line grommets. 1 Share this post Link to post Share on other sites
Moparfanforever 926 #229 Posted March 1, 2023 https://wheelhorsepartsandmore.com/product/kohler-fuel-line-rubber-grommets-qty-2/ 1 Share this post Link to post Share on other sites
ebinmaine 78,354 #230 Posted March 1, 2023 4 minutes ago, Moparfanforever said: https://wheelhorsepartsandmore.com/product/kohler-fuel-line-rubber-grommets-qty-2/ @Handy Don Share this post Link to post Share on other sites
ebinmaine 78,354 #231 Posted March 8, 2023 @PeacemakerJack 1 Share this post Link to post Share on other sites
ebinmaine 78,354 #232 Posted March 8, 2023 Well folks we dragged the Millie into the basement workshop last night... The 10 HP Tecumseh engine was always meant to be temporary so now we're going to swap in the correct 8 HP Kohler engine. Also, Trina wants to put a 6-speed with Limited Slip Differential in this Beast so it's much more work capable. Here's the list as it stands: Steering shaft replacement. Fluid fill ALL tires. Engine swap to Kohler 8 HP. Ignition SWITCH and wiring changeover to accommodate the difference in ignitions. Transmission swap from 3 speed to 6 speed. Fix sticking seat latch. Add or repair hood holder at hinge and forward max. 3 4 Share this post Link to post Share on other sites
Handy Don 16,288 #233 Posted March 8, 2023 1 hour ago, ebinmaine said: we dragged the Millie into the basement workshop last night Are you saying she was unwilling to “have some work done”? Or just reluctant at the extent of the upcoming procedures? 1 Share this post Link to post Share on other sites
ebinmaine 78,354 #234 Posted March 8, 2023 4 minutes ago, Handy Don said: Are you saying she was unwilling to “have some work done”? Or just reluctant at the extent of the upcoming procedures? I didn't confirm the tractor's emotions. 2 Share this post Link to post Share on other sites
Lee1977 7,632 #235 Posted March 8, 2023 Buy Trina some new parts to work with, you stingy old man. She just did a $1000 worth of clean sanding and painting on your C-160. 1 1 Share this post Link to post Share on other sites
Achto 31,619 #236 Posted March 8, 2023 On 2/28/2023 at 7:32 PM, ebinmaine said: Hey how do I find these rubber grommets for inside the fuel pipe from pump to carb? You might have this covered already but this is what I use. This is a pack of 25. https://www.walmart.com/ip/James-Gasket-Oil-Line-Seal-JGI-63529-57/159564941 If you have a Harley dealer around, they may be able to set you up as well. These gaskets were used for the rocker box oil lines on Shovel Head & Pan Head engines. ( make sure they give you black ones, gas eats the orange ones ) 1 Share this post Link to post Share on other sites
ebinmaine 78,354 #237 Posted March 8, 2023 2 hours ago, Achto said: this is what I use. Thanks for that Dan. I ordered up a bag. @Handy Don I'll send you a few when these come in. 1 1 Share this post Link to post Share on other sites
ebinmaine 78,354 #238 Posted March 10, 2023 The BBT and I spent a couple hours on disassembly. I got the new ish 6 speed transmission out from under the bench and draining. Pulled a few bolts. The input pulley and brake drum are off. Shifter is out. I'd asked about a GOOD set of usable lock ring pliers a few weeks ago. Put one of the pairs I got to use this evening. That was a very good way to spend $15. While I was at that Trina attacked the tractor. Sheet metal. Off. Belt. Off. Some of the wiring. Disconnected. Engine. Off! She'll be taking this one down a bit more so the paint can be freshened up. 2 3 Share this post Link to post Share on other sites
Pullstart 69,787 #239 Posted March 10, 2023 11 hours ago, ebinmaine said: The BBT and I spent a couple hours on disassembly. I got the new ish 6 speed transmission Let me know how it goes! Seems someone liked a different shade of red…. Like it was your density to get it! McFly! I don’t think I ever mentioned in Leroy’s thread… but the weekend we got that, we had just gotten home (or almost home) from camping and Norman’s head gasket(s) blew, trailer in tow. We had abandoned him in a friend of a friend’s business’ parking lot and borrowed a truck to go get the FB marketplace deal made No time like ta-now to get another deal on a ! 4 1 Share this post Link to post Share on other sites
ebinmaine 78,354 #240 Posted March 10, 2023 3 minutes ago, Pullstart said: time like ta-now to get another deal 😂 1 Share this post Link to post Share on other sites
ebinmaine 78,354 #241 Posted March 12, 2023 Trina made up a gas tank holder for her self made work table. Instant engine test station. 3 3 Share this post Link to post Share on other sites
ebinmaine 78,354 #242 Posted March 12, 2023 The Old Kohler 8 HP engine runs great!! @Herder 1 6 1 Share this post Link to post Share on other sites
ebinmaine 78,354 #243 Posted March 12, 2023 Engine is back down to bare bones again. Trina will keep on with disassembly and cleaning then paint in a couple days, after the upcoming snow storm. We finished removing the wiring from the chassis with the exception of the harness for the lights. 2 Share this post Link to post Share on other sites
Pullstart 69,787 #244 Posted March 13, 2023 Random question, what are the specs on those front tires? I love the rears on Jane and they happen to be a match on the pattern. 1 Share this post Link to post Share on other sites
ebinmaine 78,354 #245 Posted March 13, 2023 5 hours ago, Pullstart said: Random question, what are the specs on those front tires? I love the rears on Jane and they happen to be a match on the pattern. I'll check em out for ya later and post a pic or 3 1 Share this post Link to post Share on other sites
ebinmaine 78,354 #246 Posted March 14, 2023 On 3/12/2023 at 11:09 PM, Pullstart said: Random question, what are the specs on those front tires? I love the rears on Jane and they happen to be a match on the pattern. Looks like they're a standard issue Deestone brand my friend. 1 Share this post Link to post Share on other sites
ebinmaine 78,354 #247 Posted March 14, 2023 Fair amount of work done in a short time this evening. Trina the engine mechanic continued with disassembly and cleaning. Oil drained. Cylinder head is off. Oil pan is off. Before attempting to start the engine I had done a very quick hand planing on the cylinder head to check for straightness. She finished that process. 180 grit. 220 grit. Then ended at 400 grit. Fuel pump is disassembled and hand planed. Steering fan gear has been removed. Waiting patiently for a replacement from @Racinbob. Carb disassembly complete. Check out the bowl gasket !! 3 Share this post Link to post Share on other sites
PeacemakerJack 10,920 #248 Posted March 16, 2023 On 3/12/2023 at 10:09 PM, Pullstart said: Random question, what are the specs on those front tires? On 3/14/2023 at 6:22 PM, ebinmaine said: Looks like they're a standard issue Deestone brand my friend. Those look REALLY familiar…where have I seen those before…🤔… Same size, brand, but @ebinmaine’s are in better shape. I don’t even remember the tractor that mine originally came on but they are a permanent fixture on GhostRider. A great little tire🙌🏻 Eric—you guys are making great progress so far👍🏻 2 1 Share this post Link to post Share on other sites
ebinmaine 78,354 #249 Posted March 16, 2023 3 minutes ago, PeacemakerJack said: Eric—you guys are making great progress so far👍🏻 Thank you my friend! More toys in the mail today for that tractor and others. I got a 1 in pipe thread tap so I can try to clean the threads out of the exhaust a little. Box of four throttle cables bought at the recommendation of @WHX?? And @Achto from PSEP. Also a very special extremely heavy duty hub pulling tool from one of our awesome members!! Hopefully there will be a little more progress this evening... 2 1 Share this post Link to post Share on other sites
WHX?? 56,160 #250 Posted March 16, 2023 (edited) 3 hours ago, ebinmaine said: Also a very special extremely heavy duty hub pulling tool from one of our awesome members!! What who when where? Why does the head appear to be weird shaped? Edited March 16, 2023 by WHX?? 1 Share this post Link to post Share on other sites
