MainelyWheelhorse 3,008 #1 Posted May 23 Hi guys, I got my 42”RD back together and as stumped about how to adjust the belt tension. I assume the spring and plate that the idler rides on since it slides left and right, is the tensioner. Is it left somewhat loose to ride and slide with the belt or is it secured after sliding it over to tension it? It was tight before I took the idler and tensioner off but I assumed it was the PO possibly putting it together wrong. Currently there isn’t enough tension to have all three blades turn at once. I confirmed that with my father when he mentioned after seeing it working that the mule drive belt was going but the deck belt was not. Thanks! 1 Share this post Link to post Share on other sites
ineedanother 2,769 #2 Posted May 23 I've never owned that deck but your routing looks correct. Are you sure you're using the correct belt and that it's riding in the pulleys under the guards correctly? 1 1 Share this post Link to post Share on other sites
ICONN 4 #3 Posted May 23 I have this deck and just sharpened the blades. The spring must adjust out the slack in the belt otherwise the belt is TOO LONG. 3 1 Share this post Link to post Share on other sites
squonk 47,729 #4 Posted May 23 That hefty spring provides all of the tension. If your belt is loose, it's too long or worn out. 1 1 1 Share this post Link to post Share on other sites
953 nut 68,140 #5 Posted May 23 (edited) Should be 1/2" by 89" belt. https://www.tractorsupply.com/tsc/product/huskee-v-belt-1-2-in-x-89-in-oc-1012571?store=219&crmid=6663814901&utm_source=google&utm_medium=pmax&utm_campaign=tsc0_sea_tsc_cat_search_sch_us_cvr&utm_content=sku_na&adtype=pla&campaignid=22258948701&device=c&product_channel=local&product_id=1012571&store_code=219&gad_source=1&gad_campaignid=22269431188&gbraid=0AAAAADnTm20RvsdRIUAIoaUKG5VZVFJy7&gclid=Cj0KCQjwoMXQBhDcARIsAH-eEtsuJ7oBLhKKwvF0vx6VpZW98MCuEDEXLPcfJOMBlfOmbo-g1vlI9qwaArkZEALw_wcB Edited May 23 by 953 nut Added link to Tractor supply 2 1 Share this post Link to post Share on other sites
Bill D 3,062 #6 Posted May 23 89"x 1/2" belt. Please take a picture with the belt guards off. 2 Share this post Link to post Share on other sites
peter lena 9,992 #7 Posted May 23 @MainelyWheelhorse added this years ago to my decks , almost hiding in plane site ? long unsupported belt , combined with unknown spindle bearing grease ? bakes for a buzzing wreck , experimented with one deck , all 3 run the same trouble free quiet , also regreased my mule drive bearings , improved that gold mine of issues . pete 2 1 Share this post Link to post Share on other sites
midpack 1,148 #8 Posted May 23 I've seen where the slot in the sliding tensioner gets worn from riding on the bolt causing it to get hung up. Is the plastic glide ok? Bolt holding the tensioner too tight? If the tensioner moves freely I would try a smaller belt 3 Share this post Link to post Share on other sites
MainelyWheelhorse 3,008 #9 Posted May 23 1 hour ago, Bill D said: 89"x 1/2" belt. Please take a picture with the belt guards off. 11 hours ago, ineedanother said: I've never owned that deck but your routing looks correct. Are you sure you're using the correct belt and that it's riding in the pulleys under the guards correctly? The belt that’s on it is the one that was on it before I rebuilt it. It seemed to workfine then besides the spindles needing attention. It seems to be good pulley wise, as I spun it around before I put it back together. The belt didn’t come off or ride oddly in the pulleys. it just seemed a bit too loose. The routing is off the routing decal on the right of the deck. Share this post Link to post Share on other sites
MainelyWheelhorse 3,008 #10 Posted May 23 48 minutes ago, midpack said: I've seen where the slot in the sliding tensioner gets worn from riding on the bolt causing it to get hung up. Is the plastic glide ok? Bolt holding the tensioner too tight? If the tensioner moves freely I would try a smaller belt Possibly, but it was tightened down when I got it so I thought that’s how it was supposed to be. I’ll check it. Should I put a little grease? Share this post Link to post Share on other sites
lynnmor 8,970 #11 Posted May 23 Remove the tension bar, clean up the mess and reassemble with the missing spring and new plastic parts. The bar should slide freely to keep the belt tensioned. 2 1 1 Share this post Link to post Share on other sites
midpack 1,148 #12 Posted May 23 44 minutes ago, MainelyWheelhorse said: Should I put a little grease? That's a pretty dirty area generally, maybe some dry lube. It doesn't move far 1 Share this post Link to post Share on other sites
Handy Don 17,189 #13 Posted May 23 (edited) 22 minutes ago, lynnmor said: Remove the tension bar, clean up the mess and reassemble with the missing spring and new plastic parts. The bar should slide freely to keep the belt tensioned. Exactly. Tighten the bar retaining bolts only enough to keep the sliding motion smooth. The lube is the plastic slides. It helps to keep in mind that even the highest quality belts do not run perfectly smoothly--some movement is normal. The tensioner is a compromise between cranking the tension up so high that the bearings suffer and the belt wears prematurely on one hand, and having the belt loosen quickly from even a little bit of wear on the other hand. Edited May 23 by Handy Don 1 Share this post Link to post Share on other sites
MainelyWheelhorse 3,008 #14 Posted May 23 @lynnmor it has the spring, @Bill D wanted a pic with the pulley cover off. I was still working on putting it together in that pic. @midpack OK, I’ll try that too. Share this post Link to post Share on other sites
MainelyWheelhorse 3,008 #15 Posted May 23 3 minutes ago, Handy Don said: Exactly. Tighten the bar retaining bolts only enough to keep the sliding motion smooth. The lube is the plastic slides. It helps to keep in mind that even the highest quality belts do not run perfectly smoothly--some movement is normal. The tensioner is a compromise between cranking the tension up so high that the bearings suffer and the belt wears prematurely on one hand, and having the belt loosen quickly from even a little bit of wear on the other hand. @Handy Don Ok, it looked like it could slide, thanks for the confirmation. Share this post Link to post Share on other sites
ineedanother 2,769 #16 Posted May 23 16 minutes ago, MainelyWheelhorse said: @Handy Don Ok, it looked like it could slide, thanks for the confirmation. In the first pic the slide looks to be installed correctly and all the way to the tightest position which is why I suspected either the wrong belt length or it not being on one of the outer pulleys. I'm still leaning toward belt length being the issue. 2 Share this post Link to post Share on other sites
peter lena 9,992 #17 Posted May 23 @MainelyWheelhorse typically its COLLECTIVE ISUES , TO REPEDITIVE PROBLEMS , you know what starts belt bounce ? INCREMENTAL LUBRICATION FAILURE , just the tiniest / slightest bearing hang up , starts the REPEDITIVE BOUNCE , decks , mule drives , and related pto , start lever , are a GOLD MINE FOR IMPROVEMENT , did this many years ago on my C-85 , still have it , as well as a test bed for related issues on other horses . bombproof , never had a bearing fail or pto clutch burn out , pete 1 Share this post Link to post Share on other sites
oldlineman 1,772 #18 Posted May 23 (edited) In your #9 post picture it looks like the slide has a little space for more movement tighter. I would clean area up good and check the plastic washer-spacers for condition and replace if necessary. Sellers on here have them . Not sure who I bought from,someone will chime in and refresh my memory. Glenn Petti had them # 107675 and # 107674 Edited May 23 by oldlineman 1 Share this post Link to post Share on other sites
sqrlgtr 3,584 #19 Posted May 23 3 hours ago, ineedanother said: In the first pic the slide looks to be installed correctly and all the way to the tightest position which is why I suspected either the wrong belt length or it not being on one of the outer pulleys. I'm still leaning toward belt length being the issue. I concur spring looks to not have any tension on it and slide looks to be in the tightest position. Belt to long looks to be problem. 1 Share this post Link to post Share on other sites
MainelyWheelhorse 3,008 #20 Posted May 23 (edited) @953 nut @ineedanother @ICONN @squonk @Bill D @peter lena @sqrlgtr@midpack @Handy Don @oldlineman Thanks for the help guys. Now I know how the tensioner is supposed to work. It was too tight so the spring wasn’t engaged and it couldn’t slide to tension up the belt. I went back to re tighten and check the tensioner to make sure it worked. I also redid the routing and the belt tightened right up. It seems to mow great now just like it did before. Now, with an eighth of the noise. The forum came through again! Edited May 23 by MainelyWheelhorse 1 7 Share this post Link to post Share on other sites
