the jeep driver
417A Clutch Seized When Mowing, How Do I Fix?
the jeep driver
My daughter was using the Wheel Horse rider to mow, I was push mowing.  She drives over to me and says, "Dad, the blades aren't turning." I look at the mower, she's got the blades engaged (lever forward) but nothing is moving.  I disengage the blades, and re-engage... nothing.  No movement from the belt nor clutch.  Then I notice the smell, and look closer, the belt is so hot is melting on the clutch.  Or rather, the clutch is so hot it's melting the belt.  Melting occurred
While the clutch is disengaged, I can spin the clutch freely; and whilst it's engaged, it won't move.
So, what did I do now?  Peter told me to lube that needle bearing, but I couldn't find a write up/how to anywhere, so I was putting it off until after the leaves were done falling in the Fall.  I haven't taken anything off yet, other than the pins that hold the pinion and such, and the little brake pad.  I see there are two snap rings, assume they come off, and then the assembly slides out as a whole?
Some pictures of the clutch, can anyone tell if it's usable from them?
gwest_ca
I don't think the pto is the problem. If a bearing in it failed you would not likely turn it by hand and would likely drive all the time with the engine running.
Check the front idlers for bearing failure and then check the deck. You have a pulley somewhere the belt can not turn.
This is with the belt off the pulley correct? If so that is normal.
  • Like 4
Jeff-C175
Sounds more to me like something in the mower deck is seized up.
When you put the mule drive pulleys back on, you put the spacers in the correct locations?  If you get it wrong, the two pulleys hit each other and that can cause problems.
You will want to clean the burnt rubber out of the pulley grooves on the PTO for sure.
Try spinning the drive pulley on the deck by hand.  Also the mule drive pulleys.
Edited by Jeff-C175
  • Like 3
lynnmor
Do check the deck pulleys as stated above.
It does look like the snap ring that pushes the bearing in the PTO is missing and the pin is going against the end.
8ntruck
:text-yeahthat:  a missing outer snap ring on the stub shaft that the clutch hoop pushes on will prevent the clutch from engaging enough to drive the deck.  Is the belt melted in one spot, or in a long area of the sides.  If it is only melted in one spot, it is likely that the PTO clutch is slipping.
squonk
I agree remove the belt and find out what's stuck. That PTO got hot. Probably burned up the grease inside. I would inspect and regrease the roller bearing if the bearing is ok. The outer bearing I would replace. Metal looks blue (got hot). Outer bearing # is Napa PP204RR6
  • Thanks 1
953 nut
Remove the old drive belt for the deck, it is trashed anyway. Turn each of the pullies on the mule drive one at a time, they should spin freely. Put on some gloves and turn one of the blades on the deck and see if the others turn smoothly with it, if not then remove the deck belt and turn each blade independently, they should all rotate freely when not connected to the others. While the belt is off the deck check the idler pulley that applies tension for that belt. They don't last forever.
  • Excellent 1
peter lena
 @the jeep driver  looks like a long overdue combined service issue , every bearing phase should be rotating  easily / freely . that outer pto cone bearing is cooked , probably the inside needle bearing as well. removing the pto brake mount / pad , and swinging the outer arm to the side , lets you easily pull off the pto cone . would replace both bearings , personally clean out and regrease the needle bearing , you will have to go over every related bearing on that set up . a spot fix won't  will not do it . obviousely you have  combined , bearing failures , if your deck / blades , is packed , dull worn blades , combined with , overheated , lubrication failure in your mule bearings . every phase of that rotation , should easily / smoothly hand off to the next phase, thats why I  emphasize , detailing and upgraded lubrication to every rotating point . pull off the cone, drop the deck , lets have a look . probably multiple failures . let us know , your rebuild has to be thorough , for every action , thats the next phase, pete
kpinnc
Don't forget the idler pulley on the deck. Like the two pulleys on the mule drive, it's non-servicable and a typical failure point.
peter lena
@kpinnc when replacing any bearing , the first thing I  look for is wide rubber grease shields , why? so you can easily remove them with a flat pocket screwdriver , all of my mule drive bearings have been wiped clean and carb cleaner flushed , then re grease  with a 560 deg rated , anti sling ,polyurea grease , I  do this on new " non -serviceable bearings " , that changes them to  bombproof , instead of noisy / whining junk  . also do this on those idler pulley bearings , when replacing pulley , get same type / size , but with a larger bearing , wide side shields . bearing  I/D will be  1/2 "  or 5/8 " , then get a bronze push in bushing , with a 3/8 I/ D hole  to match the 1/2 "  or 5/8" larger bearing , thats makes a direct fit replacement  and an upgrade , to stop failure . already did all the trials on this upgrade , used regularly on all my horses . no whining noise , no failures , solid very smooth , why not make a failure go away ?  pete
kpinnc
I agree 100 percent Pete. I have done the same on many occasions. I just meant by "non-servicable" that they don't have a conventional way to be greased regularly like spindles with a grease gun, and often are overlooked as a result.
Personally, I try to hold onto every "old" WH cast pulley I can find with the snap ring retainer. Those make life much easier because of exactly what you're talking about: those seals are even more easily accessable and you can keep a spare set ready to go whenever needed. :thumbs:
  • Excellent 1
peter lena
@kpinnc  agree with those old cast pulleys , snap ring ,simplicity . also, when going on a  pulley search , local T/S  stores usually has a  exact size / type match up , with those larger bearing s  already in place , just a bronze 3/8 ID  is needed  for a  matching fit. there are few areas that I  have not upgraded , to eliminate a  chronic  issue . tractors look the same , yet the problem is gone . thanks for the shout , weather is saposed to Kool off , be at the lake at dark thirty , hook in mouth , pete
ineedanother
Good luck with that Pete. I'll be at the office wishing I was there too.
Jeff-C175
On 8/29/2022 at 9:12 PM, the jeep driver said:
clutch
C'mon back and tell us what you found!
the jeep driver
Nothing conclusive as of yet... All I've time time to do is mess with the deck, everything seems to more freely either by pulling the belt or spinning the pulleys once the belt is off.  I plan on taking the clutch apart tomorrow.  More pictures and questions will be forthcoming!  Thank you!
  • Thanks 1
John2189
With the belt on and engine running, was the pto turning?    With engine off, If the clutch spins while disengaged , and doesn’t spin engaged, It would almost have to be a locked up spindle or idler. Or the pto clutch is slipping and needs adjustment. Does the pto handle have resistance to it when you engage it?
I see you are in NE Ohio, im in Minerva
  • Thanks 1
the jeep driver
On 8/29/2022 at 10:47 PM, lynnmor said:
...check the deck pulleys ...
On 8/30/2022 at 7:55 AM, 953 nut said:
... pullies on the mule drive one at a time, they should spin freely. ...turn one of the blades on the deck...turn each blade independently... idler pulley ...
On 8/30/2022 at 9:50 PM, kpinnc said:
... idler pulley on the deck. ...
On 8/30/2022 at 8:18 AM, peter lena said:
 @the jeep driver every bearing phase should be rotating  easily / freely .
I've checked every pulley on the deck and mule, with the deck belt both on and off, everything moves as it should, including the blades.  I can't check anything that would require the drive belt since I don't have a new one yet.  Edit to mention that none of the pulleys make any whine or chirp when I move them.  They also don't feel loose.
Edited by the jeep driver
the jeep driver
Yes.
the jeep driver
What snap ring is missing?  Where does it go?  I have two that I can see...  I think they would be #34 and #35...?  I haven't taken either one off yet... It looks like there's another #34 behind the bearing that I won't be able to see with the bearing in place.
the jeep driver
Just the one spot melted... when I was watching the nothing on the PTO was moving with the lever engaged. I didn't get to watch for long though before the belt failed and I shut the tractor off.
Jeff-C175
I believe he may have been referring to the OUTER #34 .  If that one pops off, the stub axle will push IN, and #29 will grind on the end of the PTO bell.  I've got one bell that this happened to and it wore it down so far there's no slot left for #35.  It still works though it's just that when you take it apart you have to be careful that the bearing doesn't fall out.  It SHOULD be a tight fit, but on this particular one it is not...
Jeff-C175
Do you mean that the PTO bell was not turning?  Can't be... cuz then the belt would not have melted.
Look for a worn clutch facing on #43
the jeep driver
Thanks for that part number!  The roller bearing looks good, but now that I've got the PTO off, I'm taking it over to a highly mechanically inclined friend for a second opinion.  He'll have all the correct grease if that's all it needs.  I'll just relace the outer bearing no matter how it looks while I have it apart.
8ntruck
Check the surface on the PTO pulley that contacts the clutch.  It could warp if it got hot enough.
the jeep driver
By "PTO bell" do you mean part #37?  There wasn't anything on the PTO moving... The belt was just sitting against the clutch plate sizzling.
This is mine, I didn't take it off.  How do you think it looks?  Or is it too difficult to tell if it's worn out from a picture?
  • Similar Content
    • decvt79
      By decvt79
      My 1999 270H with 48” deck is having an issue getting power to PTO.   Checked PTO with jumper to battery and it worked fine and I’ve actually been cutting grass using the jumper for awhile.  I checked power from PTO switch to PTO and there is none.  I checked PTO switch and it appeared OK but I replaced it anyway and still no power to PTO.   Then checked brown/tan wire leading to switch and there is none.   Could the issue be the NMIR module and is there a good way to check it.  If bad, where is the best place to get a replacement and do other brands/models have NMIR a modules I can use.    Also, would suppling battery power directly to PTO switch and bypassing NMIR result in switch working.
    • trident
      By trident
      Need some help. My 800 Special has an electric PTO. It is not working. Checked Ohms - nothing. My questions are 1) how does the PTO come off and 2) can they be rebuilt? I took the bolt out that I thought holds it on but no luck. Must be something more?
    • BMW1
      By BMW1
      What direction does the front PTO Pulley turn on a wheel horse D180 with a Kohler K482 as you face the front of the tractor?
      I want to get a hydraulic pump for a Johnson 10 loader I will be mounting to tractor and want to make sure I get a pump that rotates the correct direction.
    • RJ Hamner
      By RJ Hamner
      Its been a while since I was able to work on my 416-8 rebuilt and right now the few brain cells are having a tough time.
      I am in the process of putting the wiring harness back in and the problem is the clutch safety switch.
      The arm with the idler wheel that engages the switch is over ridding the switch arm.
      I had tried adjusting the rod from the peddle to the arm but no matter my adjustment I still have the problem
      I am kinda at my wits end on this one.
      Any help will be greatly appreciated
      Bob
    • the jeep driver
      By the jeep driver
      I have a 1985 Wheel Horse 417A 31-17KE01.  When I pull up the lever to disengage the drive, the belt will continue to move erratically (slow, speed up, repeat.)  I've attached a couple of pictures, and have a one minute video showing how it's operating... (this is a OneDrive link, if it's not working someone please let me know.)  I wish I could provide more info in my post, but I don't know enough about what's occurring here to do so.
      https://1drv.ms/v/s!AsmNVhojMf_GqAHdTKh3d5-0uFVI?e=30SyhH
