sjoemie himself
Front mounted tiller
sjoemie himself
A while ago I picked up a Canadiana 5hp heavy duty tiller. It features forward and reverse control and you could buy add on implements for it.
My example unfortunately suffered a catastrofic engine faillure a.k.a. 'window' in the block. Hence it was cheap so I picked it up. The idea I had for it was to mount it on the rear of my 'Murray to IH 1568' build. However since I bought a Wheel Horse i've been thinking about mounting it on the front of that tractor.
This is what i'm thinking..
Edited by sjoemie himself
Added info
8ntruck
Good idea.  Somebody here has done the same thing.  Seems like it was about a year ago.  I'm pretty sure the post was in the implements and attachments section of the forum.
elcamino/wheelhorse
@Ed Kennell Can you provide advise on your Mad Max Tiller to @sjoemie himself?
Pullstart
Here’s Ed’s build thread :handgestures-thumbupright:
Ed Kennell
I see my build thread has been posted...thanks Kev.
    I modified my walk behind tiller and mounted it on a plow frame.      The tiller is raised and lowered by the plow frame.    The tiller rotation throws the dirt away from the tractor.     I normally use it by running the tractor in reverse so I am not running over the tilled area.     It works great for tilling beds that are close to my buildings.104_0330.JPG.aace9c03930f25a4a1ff2eb6153bb35a.JPG
  • Excellent 5
sjoemie himself
Thank you gentlemen! Very useful information!
I thought I saw a front mounted tiller around here somewhere and even looked for it but couldn't find the topic, now I know.
Since I don't have a plow frame and probably never going to find one i'll just use the front tach-a-matic.
My plan is to run the tiller 'backwards' and the tractor forwards, so that the tranny is under constant load.
I think i'll keep the guiding wheels on the front to act as a depth stop so to say..
@Ed Kennell I see that you drive your tiller directly from the pto pulley without a jackshaft with 'gear reduction' to slow the output rpm down. Did it speed up the tiller much or do you think on the walk behind the reduction was incorporated because of the limited power at hand?
Ed Kennell
I have the belt on the small outer PTO pulley and run the engine at 2000 RPM.     This uses around 6 of the 12 HP engine and is plenty of power.     The tiller probably turns a bit faster than it did as designed with the origonal engine turning at 3600 and with a smaller drive pulley.
     It works fine in pre plowed ground, but would  probably be too fast for tilling sod or hard packed soil.
sjoemie himself
Thanks for your input. I think in that case I will incorporate a jackshaft to get the correct rpm.
I want to use the tiller to break up sod so a bit less rpm is probably the way to go.
I'm curious to see what the little Robin diesel will do once I put the tiller down. Could get interesting! :ph34r:
ebinmaine
1 hour ago, sjoemie himself said:
interesting
Yepp.
  • Haha 1
  • Similar Content
    • Rick3478
      By Rick3478
      - SOLD - Moderator may remove at will
      0736TL04 tiller and fitments needed to mount on many long frame, C series, 300/400/500 series tractors.
      Notable details:
      Gearbox and tines have low hours.  Tarp had blown off mid-mount idlers and got rusted up, probably need penetrating oil and new idlers.
      Axle mount is rusty/restorable/useable.  Lift cable has nylon worn through on one side (they tend to do that).  One rear jackshaft bushing
      has couple ears broke off, and jackshaft e-clips are lost (edit: found those).  Belt is original.
      Pick up in my back yard near Elida, Ohio.  Bring help to load, or ramps or something.
      I think it may be worth $100.
      - or -
      Would consider trade for a used car or truck hood that I can use for a sled to drag firewood and equipment around on, something kinda
      rounded without points or ridges to catch.  Have been using an S-10 hood for years, and it's wearing through becoming less useable.
      What 'cha got?
    • Epayne85
      By Epayne85
      Hello all, I have a what I believe is a 36” tiller.
      i can get a few pictures of it this afternoon, it rolls freely and appears in very good condition. It’s missing the rear hinge panel. I’m mainly interested in swapping for a box blade and other items depending what you’d have for the clevis or sleeve hitch or I’ll take best offer. Thank you. Also, I have a snow plow and the frame in which someone has modified for I believe an Atv or different tractor I’d be willing to let go for $50 or throw in towards the deal. The blade is in pretty decent shape and the angle mechanism works flawlessly. Again thank you.
      edit* I will be able to get pictures Labor Day weekend, sorry for the delay if anyone is interested
    • Donavon1
      By Donavon1
      Project black Betty the diesel 1054
    • Wheel Horse 3D
      By Wheel Horse 3D
      Our customized ornaments have a base identical to our version of the original style ornament, but can be topped with 3 different styles of horse head and 3 different styles of wheel! Each is available unfinished, primed, or fully painted.
      They also include the pictured mounting hardware and the base spacer for a clean finished look. Can be ordred here https://greystone-3d.square.site/product/customizable-wheelhorse-hood-ornaments/10
    • Wheel Horse 3D
      By Wheel Horse 3D
      Welcome, and thanks for visiting our vendor area.
      We got our start in 3D printing for customers right here on Red Square!
      If you'd like to see how every thing gets developed and the contributions of Red Square members, please visit the thread that started it all and browse through our progress to date.
      We love our clients' input and work closely to turn ideas into reality. If you have an idea, request, or questions, you can post to that thread, message us or tag us here on Red Square, or visit our online store and reach out to us through there.
      Https://greystone-3d.square.site
