msdhomeplans@gmail.com
Carburetor Replacement
Hi I am trying to resurrect my fathers 1966 wheel horse lawn ranger.  I have gas leaking from the carburetor and I need a replacement.  I can not seem to find any accurate resources for the correct one needed.
Here are the specs for the tractor.  I am also in need of a seat for it if you know which work for this model.
Thanks in advance!
Model Number L 156
Serial # 219222
Wheel Horse Lawn Ranger L-156
Tecumseh H60
gasoline
1-cylinder
air-cooled
Displacement: 221 cc
13.53 ci
Bore/Stroke: 2.625x2.50 inches
67 x 64 mm
Power: 6 hp
4.5 kW
Starter volts: 12
Edited by msdhomeplans@gmail.com
pfrederi
Techy carb # 631067A
Just a leak may just need gasket and repair set 31840
Lots of cheap knock offs around.  Some work well others not so well you pays your money you take your chance.
 I usually try to repair the original first
Knock off and original
Edited by pfrederi
  • Like 6
Thank you for the quick response!
ebinmaine
I'd second the advice of trying to repair what you have.
Properly diagnose the actual issue before doing any repair.  (On anything really).
ri702bill
Once the carb is dis-assembled, hold it near your ear (or in my case, the good ear) shake it and listen for the sound of the check ball in the emulsifier tube to RATTLE - if there is NO sound, it is stuck and there is no positive way to clear that passage - time for a different carb. BT,DT
Bill
Handy Don
Bill
Someone here did a thread on drilling out the brass pin that captures that ball and using a small machine screw to seal the emulsifier tube back up after cleaning it out.
@squonk? @stevasaurus?
The issue is that the emulsifiers fuel passages (both the entry and exit) are extremely small.
Only time I've succeeded getting one unclogged was after a longish session in a friend's ultrasonic tank (too bad he's moved away and I'm too cheap to get my own).
Edited by Handy Don
stevasaurus
I think this is what you are asking about.  @rmaynard  This thread is in the Reference Section / Engines.
  • Thanks 2
Howie
I have tried to fix three of these, they all had a steel ball plugging that passage.
Used a Dremel with carbide burr, took considerable time. You have an aluminum
carb body with a black oxide coated pin in that passage. With water in the gas and
resideing in the carb for who know how long it is a recipe for trouble.
Wish they had used something else for the plug. At least the ones I tried were that
way.
  • Similar Content
    • rustyedge1
      By rustyedge1
      The local place I’ve bought parts from for years has changed owners, now they can’t even spell Wheel Horse let alone be if any help.
      Doing my spring tune up I noticed my drive belt is getting pretty ratty. Due to all I’ve read thought I’d ask for some advise on getting it right the first time on a new belt.
      Is there still dealers on this site selling OME stuff ? I know there are tons of aftermarket crap but not looking for that.
      Thank in advance.
    • CS-17
      By CS-17
      Sold!!!
      Used 1966 Wheel Horse 856. Includes Kholer K181 8hp engine and 32" deck. Runs and Drives Great!
        I received it in non working order, I have since done the following repairs:   To Engine/Transmission; New carburetor, fuel pump, fuel line, fuel filter, battery, throttle cable, head bolts, spark plug, regapped points changed oil in engine and transmission and cleaned air filter.   To Body; striped and repainted wheels, blades sharpened and primed hood and rear fenders (ready to be painted).    This mower is ready to add to a collection or used for every day tasks. Cash on pickup. $800 or best offer.   Please feel free to CALL me for details or any question!   THANKS for looking!
    • rustyedge1
      By rustyedge1
      Need a condenser for engine shown in photos 8 hp Kohler. Any venders carry them on this site ?
      All help appreciated..Have PayPal or can send check..
    • WheelPuke
      By WheelPuke
      I have my 25A fuse blowing every time I put a new one in the slot. The old one was burnt up when I got the tractor put this year. It sat for a year with a dead battery. I stopped using it as much because the transmission is clattering pretty bad when taking off on second or higher. I had to replace the clutch belt a few years ago and couldn't get an OEM. Not sure what is the problem there that's another issue though.
      I have checked the wiring and patched the worn spots where it could be grounding out. The fuse blows as soon as there is power to the system with the ignition off. I'm at a loss of what to check for at this point. Any input from someone who has had this issue would be appreciated. I'm not sure what these units are in the photos but do not know how to test them for a failure. They are directly in loop with the battery and the ignition loom looks to run into that 25A fuse.
    • wh315-8
      By wh315-8
      This is a tag on a 1970 Raider 10 from someone on a FB group. Never seen one that had USED on it, it is Model 1-6041 U
                Serial  342 USED.
      owner thought tag reads 2-6041 U for model but not sure.
      I just wonder if this was perhaps a warranty factory return and they used a new id tag this way?
      Anyone ever come across something like this?
       Typed in the numbers for Clarity.
