Bill D 2,746 #1 Posted April 16, 2021 What are the differences between the 2575701s kit and the 2575702s kit? Also I am working on a K341 and it calls for carb kit 2575711s which is totally different from the other two. Why? Thanks for the advice. Bill Share this post Link to post Share on other sites
ebinmaine 78,271 #2 Posted April 16, 2021 Does this thread help? 7 minutes ago, Bill D said: 2575701s This is the number I use for 60s and 70s Kohler carbs. Share this post Link to post Share on other sites
pfrederi 20,259 #3 Posted April 16, 2021 (edited) Does your 341 have a Walbro carb? Edited April 16, 2021 by pfrederi 1 Share this post Link to post Share on other sites
roadapples 6,987 #4 Posted April 16, 2021 Between 01 and 02 the tip of the seat is the only difference. But it does matter... 2 1 Share this post Link to post Share on other sites
ebinmaine 78,271 #5 Posted April 16, 2021 4 minutes ago, pfrederi said: Does your 341 have a Walbro carb? Is there a cutoff year for these? I've only dealt with Kohler's previous to maybe 76 or 77 and all of mine have been colder carbs. Not Walbro. Share this post Link to post Share on other sites
pfrederi 20,259 #6 Posted April 16, 2021 I am not sure it was so much a year cutoff. Could be what they had available. Have to tell probably by engine spec numbers. 1 Share this post Link to post Share on other sites
pfrederi 20,259 #7 Posted April 16, 2021 The 2575711s is for walbro carbs ..Long skinny float valve. Right inpic You can see the difference on the valve seat road apples mentioned 4 1 Share this post Link to post Share on other sites
pfrederi 20,259 #8 Posted April 16, 2021 8 minutes ago, ebinmaine said: Is there a cutoff year for these? I've only dealt with Kohler's previous to maybe 76 or 77 and all of mine have been colder carbs. Not Walbro. Add to the confusion I have some WHs with Walbro Fixed Jet some adjustable. Not for sure if they are original either... 2 Share this post Link to post Share on other sites
Bill D 2,746 #9 Posted April 16, 2021 2 hours ago, roadapples said: Between 01 and 02 the tip of the seat is the only difference. But it does matter... How do I tell the difference? It does not have a walbro carb. Bill Share this post Link to post Share on other sites
roadapples 6,987 #10 Posted April 16, 2021 I'd take it apart and see which is in it now... 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,149 #11 Posted April 16, 2021 This manual is hard to follow viewing one page at a time because there is no way to determine if you are viewing a left or right page. In book form there is a left and right page on the same subject. Garry Share this post Link to post Share on other sites
JCM 11,117 #12 Posted April 17, 2021 Came across this Kohler kit in the house this morning and I know I have more in the shop, but passing on this info in case it helps. #25 757 01-S with my handwritten note backside fits 8 hp-14 hp. 3 Share this post Link to post Share on other sites
ebinmaine 78,271 #13 Posted April 17, 2021 2 minutes ago, JCM said: Came across this Kohler kit in the house this morning and I know I have more in the shop, but passing on this info in case it helps. #25 757 01-S with my handwritten note backside fits 8 hp-14 hp. Fits my 16 too Jim. 1 Share this post Link to post Share on other sites
tunahead72 2,627 #14 Posted April 17, 2021 13 hours ago, roadapples said: I'd take it apart and see which is in it now... 13 hours ago, gwest_ca said: This manual is hard to follow viewing one page at a time because there is no way to determine if you are viewing a left or right page. In book form there is a left and right page on the same subject. Garry That would be my advice also. If you don't feel like taking it apart just yet, look for numbers stamped into the mounting flange, or anywhere else on the body of the carb. If you find a Kohler number stamped on it, you can look through the (very useful) manual that Garry posted and find all kinds of information about your carb, including a detailed parts breakdown and exactly which kit you need. Share this post Link to post Share on other sites
Gregor 4,847 #15 Posted April 17, 2021 So letting my stupid out again. 8HP, style #16 carb. 14HP, style #30 carb. Same kit fits both? Share this post Link to post Share on other sites
ebinmaine 78,271 #16 Posted April 17, 2021 2 minutes ago, Gregor said: So letting my stupid out again. 8HP, style #16 carb. 14HP, style #30 carb. Same kit fits both? Nothing stupid there. Legitimate question. Yes. The flange mounts are the same size. The throat size is what changes and that has no effect on gasket size. 1 Share this post Link to post Share on other sites
ACman 7,719 #17 Posted July 25, 2022 @JCM @tunahead72 @roadapples @daveoman1966 so I just had a carb rebuilt for my k91 which my nephew lost the needle during tear down and the guy used a 02-S kit . I’m looking for a kit for my cousin’s 63 John Deere (cough) 110 which has a k161 . 64 and up used k181 like Wheel Horse did . Do you think it’s a 01-S is the one to order. I know this is the original engine on his tractor . My RJ who knows what year th k91 is or what it came off of . Share this post Link to post Share on other sites
ebinmaine 78,271 #18 Posted July 25, 2022 9 minutes ago, ACman said: @JCM @tunahead72 @roadapples @daveoman1966 so I just had a carb rebuilt for my k91 which my nephew lost the needle during tear down and the guy used a 02-S kit . I’m looking for a kit for my cousin’s 63 John Deere (cough) 110 which has a k161 . 64 and up used k181 like Wheel Horse did . Do you think it’s a 01-S is the one to order. I know this is the original engine on his tractor . My RJ who knows what year th k91 is or what it came off of . My notes tell me that up to 16 horse single cylinder is an '01s. I don't know what the difference is between the 01 and 02. Share this post Link to post Share on other sites
Wheelhorse#1 1,902 #19 Posted July 25, 2022 (edited) removed Edited July 29, 2022 by Wheelhorse#1 mistake Share this post Link to post Share on other sites
ACman 7,719 #20 Posted July 25, 2022 On 4/16/2021 at 3:03 PM, pfrederi said: The 2575711s is for walbro carbs ..Long skinny float valve. Right inpic You can see the difference on the valve seat road apples mentioned did you mean 01-s not 11s and do you know if the gaskets are the same ? @ebinmaine it just got me wondering because it seems all the aftermarket are the same generic stuff inside the bag . 1 Share this post Link to post Share on other sites
ebinmaine 78,271 #21 Posted July 25, 2022 1 minute ago, ACman said: did you mean 01-s not 11s and do you know if the gaskets are the same ? @ebinmaine it just got me wondering because it seems all the aftermarket are the same generic stuff inside the bag . I can take a look at the two specific different Kohler kits when I get home in about an hour. I'm wondering if maybe the bowl size is different? Share this post Link to post Share on other sites
roadapples 6,987 #22 Posted July 25, 2022 Only rebuilt 10 through 16s. The only difference I know of is in pfrederi's picture... @oldredrider??? Share this post Link to post Share on other sites
