PeacemakerJack 10,837 #251 Posted April 8, 2020 I’ll be in touch Dan. I have to get my shop organized enough to be able to get at Blackbeard again. He has been tucked away for the long winters nap. However, once I have him back out, I’ll study the situation and let you know what I find. 2 1 Share this post Link to post Share on other sites
Pullstart 68,529 #252 Posted April 8, 2020 12 hours ago, PeacemakerJack said: What is really cool with that Kev is how much those look like “traditional” AG’s. I would be game to give those a try on my “redhead” plow mule when I finally get around to building it. Thanks for sharing the link. I imagine the extra 2” ground clearance would be a significant gain in the furrow! I think that Eric @wheelhorse man (?) proved how well a 6-12 will plow at J&C2019, but ground clearance got the best of him a time or two. 1 Share this post Link to post Share on other sites
Achto 30,204 #253 Posted April 8, 2020 (edited) 1 hour ago, pullstart said: I imagine the extra 2” ground clearance would be a significant gain in the furrow! The extra ground clearance would be an advantage. Pus you will get a little more ground speed. Some times (depending on the soil conditions) a narrow tire can also be an advantage. There have been instances where my 8.50's were digging in and pulling while others with 10.50's were slipping. Edited April 8, 2020 by Achto 1 1 Share this post Link to post Share on other sites
Pullstart 68,529 #254 Posted April 8, 2020 1 minute ago, Achto said: The extra ground clearance would be an advantage. Pus you will get a little more ground speed. Some times (depending on the soil conditions) a narrow tire can also be an advantage. There have been instances where my 8.50's were digging in and pulling while others with 10.50's were slipping. More PSI on the contact patch, right? 1 Share this post Link to post Share on other sites
Achto 30,204 #255 Posted April 8, 2020 (edited) 5 minutes ago, pullstart said: More PSI on the contact patch, right? Correct. I've been thinking of setting my snow plow tractor up with 6-12's for that very reason. Wide tires are no good in the snow. Edited April 8, 2020 by Achto 1 1 Share this post Link to post Share on other sites
Pullstart 68,529 #256 Posted April 8, 2020 4 minutes ago, Achto said: Correct. I've been thinking of setting my snow plow tractor up with 6-12's for that very reason. Wide tires are no good in the snow. Unless you’ve got tons of horsepower and plenty of wheel speed! 1 2 Share this post Link to post Share on other sites
PeacemakerJack 10,837 #257 Posted April 8, 2020 After plowing with Clyde...I’m more convinced than ever that a taller narrow tire with a good lug is the way to go! Thinking of farm work (I know Dan can relate). We used the high floatation duals in the spring so as to stay “on top” of the soil and spread out our contact patch as much as possible. Plowing in the fall was going to the narrow tire with LOTS of weight. I love the look of a fat tire on the back of my plow tractor but with the case of full disclosure...a narrow taller tire is better for plowing—just ask @Stormin and his dark horse. Of course the link you gave us Kev worked good but the tires were OUT OF STOCK🤨! At a Benny a piece, those are a good deal. 1 1 Share this post Link to post Share on other sites
Pullstart 68,529 #258 Posted April 8, 2020 Maybe I should’ve ordered before sharing the link 1 Share this post Link to post Share on other sites
C-101plowerpower 1,606 #259 Posted April 9, 2020 17 hours ago, PeacemakerJack said: After plowing with Clyde...I’m more convinced than ever that a taller narrow tire with a good lug is the way to go! Thinking of farm work (I know Dan can relate). We used the high floatation duals in the spring so as to stay “on top” of the soil and spread out our contact patch as much as possible. Plowing in the fall was going to the narrow tire with LOTS of weight. I love the look of a fat tire on the back of my plow tractor but with the case of full disclosure...a narrow taller tire is better for plowing—just ask @Stormin and his dark horse. Of course the link you gave us Kev worked good but the tires were OUT OF STOCK🤨! At a Benny a piece, those are a good deal. https://www.mudthrowers.com/inc/sdetail/62/62489 Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #260 Posted April 9, 2020 @pullstart @PeacemakerJack try here ...https://www.ebay.com/itm/181603054011. 1 Share this post Link to post Share on other sites
Pullstart 68,529 #261 Posted April 19, 2020 Rylee and I got some seat time in the field today. She taught Mrs. P how to plow too! 2 7 Share this post Link to post Share on other sites
Achto 30,204 #262 Posted April 27, 2020 (edited) A little lesson for today, it is important to open a field correctly. Dived the field in half and start your first pass down the middle of the field. From there keep working each side of that furrow towards the out side of the field until done. A field that I plowed today was started on the outsides to be worked toward the middle. Here was an end result to this practice, While trying to make the last passes the right & left wheels both ended up being in a furrow. This resulted in the tractor getting high centered, ( transmission was hung up on the dirt and neither rear tire was touching the ground ). Getting out of this mess involved another tractor and a tow strap. Edited April 27, 2020 by Achto 2 Share this post Link to post Share on other sites
WHX?? 53,345 #263 Posted April 27, 2020 I'll blame it on rookie Pullstart as he was the only one that was in that field last plow day. 'Course it didn't help I was out ther dick1ng around ther the other day trying to put a shine on a plow and plowing the wrong way. Plus I should have disced it and flattened it out and put in rye last year after plow day. Turning the rye now would have put nitrogen back in. No matter it was still seat time getting you out! By the way @Shynon @prondzy no lift cables were injured on getting it out! I think what I should do is get it straightened out and let it go to weed. Then round up and a another fall plowing and then rye again. If the asparagus doesn't pan out this year it will get plowed up. It kinda screws up the whole field where it's at. 3 1 1 Share this post Link to post Share on other sites
Achto 30,204 #264 Posted April 27, 2020 17 minutes ago, WHX24 said: I think what I should do is get it straightened out and let it go to weed Maybe throw some oats on it for the summer. They make a good cover crop. 2 Share this post Link to post Share on other sites
Pullstart 68,529 #265 Posted April 27, 2020 You can’t invite me to come plow... then blame me for plowin’ Jim. Don’t work that way. 5 Share this post Link to post Share on other sites
C-101plowerpower 1,606 #266 Posted April 29, 2020 On 4/27/2020 at 2:38 AM, Achto said: A little lesson for today, it is important to open a field correctly. Dived the field in half and start your first pass down the middle of the field. From there keep working each side of that furrow towards the out side of the field until done. A field that I plowed today was started on the outsides to be worked toward the middle. Here was an end result to this practice, While trying to make the last passes the right & left wheels both ended up being in a furrow. This resulted in the tractor getting high centered, ( transmission was hung up on the dirt and neither rear tire was touching the ground ). Getting out of this mess involved another tractor and a tow strap. i have problems with that when doing competitions, i usually misjudge the depth i have to go to, i start going shallower on the last few passes but allways end up having it too deep still. it'll usually result in me lifting the plow, putting it in gear and pushing and pulling till free 3 Share this post Link to post Share on other sites
Pullstart 68,529 #267 Posted April 29, 2020 We prepared our garden plot yesterday. It rained all night, we still need to disc to break up the sod... or till. 2 6 Share this post Link to post Share on other sites
PeacemakerJack 10,837 #268 Posted April 29, 2020 Great video Kevin—Caleb was getting a little worried because he thought he was the only one who could use the iMovie maker! It is a really fun app that can make some really sweet movies without a lot of work. Looks like the family was having fun. What did Mrs. Pullstart think of plowing—assuming this was her first time...🤔. I haven’t had much success getting Kelli to plow but my man @stevasaurus was able to get her to take a couple of rounds on his tractor at Jim’s plow day in 2018 (I think!). Also glad to see Jada in the Saddle turning some earth. Claudia plowed back in about 2015-6 with me a couple of times but it never really was her thing. I was hoping that with Casey set up for it she would get into it—not so much. However, she still likes taking “Hot Laps” and playing on the tractors with us. Thanks again for taking us on the journey with you guys. 2 1 Share this post Link to post Share on other sites
Pullstart 68,529 #269 Posted April 29, 2020 24 minutes ago, PeacemakerJack said: Great video Kevin—Caleb was getting a little worried because he thought he was the only one who could use the iMovie maker! It is a really fun app that can make some really sweet movies without a lot of work. Looks like the family was having fun. What did Mrs. Pullstart think of plowing—assuming this was her first time...🤔. I haven’t had much success getting Kelli to plow but my man @stevasaurus was able to get her to take a couple of rounds on his tractor at Jim’s plow day in 2018 (I think!). Also glad to see Jada in the Saddle turning some earth. Claudia plowed back in about 2015-6 with me a couple of times but it never really was her thing. I was hoping that with Casey set up for it she would get into it—not so much. However, she still likes taking “Hot Laps” and playing on the tractors with us. Thanks again for taking us on the journey with you guys. I looked for a cheap yet effective movie maker and will keep playing around with it. That way I can group together segments of movies to make a story instead of raw video clips at random. We had a great time! Mrs. P enjoyed plowing, she had a lot of fun prepping the garden. This weekend we also made two batches (about 15 or 16 quarts) of spaghetti sauce from frozen tomatoes out of Grandma’s garden. Mrs. P couldn’t believe how challenging it was to lift the 10” plow behind Putt Putt but she was a trooper about it! Jada had fun being outside with the family and playing with videos which we can all be thankful for! Without the video team, it isn’t very pleasant! 1 2 1 Share this post Link to post Share on other sites
PeacemakerJack 10,837 #270 Posted April 29, 2020 Speaking of video team-if we want to share this garden tractor plowing thing with others, it is done through posted/shared videos and pictures. It is often hard once you get into plowing to take time to get good and interesting shots. However, it is important to preserve and share it when we can. I have always wanted to get a GoPro for those “in the saddle” shots but I learned at Jim’s PD last fall that you have to have a secure mount for one or risk plowing it under😫. I’m glad Mrs P. Enjoyed her experience with it. Her point about manual lifts is well taken though. An assisted lift is a definite plus in a plow mule, especially if one intends to use it at plow days where you may spend a good part of the day using it. 2 Share this post Link to post Share on other sites
Tractorhead 9,215 #271 Posted April 29, 2020 Cool Action captured in a great Video. Thanks for Sharing. 1 Share this post Link to post Share on other sites
Pullstart 68,529 #272 Posted April 29, 2020 And if you’re wondering if the fields are wet after our 3-4” of rain in about 12 hours... the answer is yes! 1 2 1 Share this post Link to post Share on other sites
Andy N. 2,604 #274 Posted May 3, 2020 Tilled the garden today with the 312-8. And got some peas and onions planted...more to come. IMG_0349.mp4 IMG_0350.mp4 4 Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #275 Posted May 3, 2020 @pullstart, Kevin those don't too much like high flotation mud bogging tires ... 2 Share this post Link to post Share on other sites
