Goldann520
I'm back!
Goldann520
I'm back @WV Hillbilly, @ACman, @horsenewbee. I'm once again a wh owner. You guys were right. Only this time it's only a 1990 312-8 classic. But hey, I gave $50 bucks for it!!!!! Kohler magnum runs like  a champ and has a nice 42" rear discharge deck on it. Paint not too bad, pics to come. Of couse has normal hackery for this price, but im back in the game ! Gotta get back to work now, talk later. Goldann520
  • Like 8
953 nut
Image result for welcome back!
Retired Wrencher
Welcome back. Go :wh: or go home. Big boy rules. Have fun.
Goldann520
Sorry, it's a 91. Has the 100000 serial # and the k8 model #.
Sparky
Welcome back! The 312 is a nice trusty machine
WVHillbilly520H
@Goldann520, that's kinda dajavu as I just acquired an '88 312-8, but for different reasons, Jeff.
Goldann520
Looks just like it, Sept hood is different color. By the way, will a toro 79252 front blade fit it? Says for 260 series tractors, which I think are lawn tractors? Appreciate the help. @WV Hillbilly@ACman has weights and chains too, but if tires are wrong size and blade won't fit.........
Edited by Goldann520
Type o
Tankman
Yeah, we know. Honest Hon, I need this Horse really bad.
  • Haha 1
WVHillbilly520H
That blade from a 260 series will work but you have to fab up some things to make it work, just did that last spring, top pic is how it should look with the correct 260 linkages which you'll only need the angle lever and bar,  then make the center lift link and weld in and of course a rear axle bracket, I don't remember the dimensions as I've sold to a buddy for his 417, Jeff.
Goldann520
Ya not lookin to fab stuff up. I'll wait. Thanks @WV Hillbilly. Here's a couple pics, not unloaded yet. 50 bucks !!!!!!!!!! 717 hrs. Should have some life.needs work but that's what I do. Man I miss my 520😣
  • Like 5
WVHillbilly520H
Truly the only piece I fabbed up was the lift anchor/link in the last picture, everything else was just stripped that wasn't needed and the angle handle just sets on the outside of the running board, maybe cost $5 if have a drill, grinder, and welder.
Goldann520
@WV Hillbilly hey Jeff, you saw the before pics, these are after my 1st cleaning. $50 bucks I paid for this!!!!!!! Needs some work obviously, but think this was deal of the year,  and it's only Feb. Runs great. Thanks For listening to my gloating but a deal like this deserves touting. 717 hrs
elcamino/wheelhorse
@Goldann520 Does not look too bad except I think the steering will be a like tough on your hands. Did some one mess with ignition switch or is it just the picture ?
Goldann520
Ya someone put a push button in it, so some rewiring in order. A tree branch fell on it and smashed it. That's why he decided to move it. Said it was a sign to get rid of it. I was lucky enough to be there at the right time
Type o
Goldann520
@elcamino/wheelhorse ya that's just the 1st layer of mold and crust. After I compound and polish it, should Shine halfway decent. All 4 tires leak down too😣
Type o
Goldann520
@elcamino/wheelhorse maybe you can help me. @WVHillbilly520H look at the dash pic. The brake pedal is way back toward the seat. Brakes work fine, and spring is wirking, but pedal seems way too far back. Any ideas? Thanks Terry  is there a stop for it to fix that problem? Also there was electric lift available for these, right?
Type o
WVHillbilly520H
Looks similar to mine...
Goldann520
Ya, it does. Guess it's the nature of the beast. Thanks @WVHillbilly520H
WVHillbilly520H
Believe it or not this one has 450 hrs on it, unlike the one I found in November at a JD dealership it had 2800hrs :think:.
Edited by WVHillbilly520H
Goldann520
Nice! Plenty of life in that old girl! @WVHillbilly520H there was electric lift available for these, right? I don't yank on lift levers anymore if I can help it. Would like that rear lift too!
Type o
WVHillbilly520H
If you can find the electric lift yes it can be retrofitted, as far as the rear lift @wheelhorseman, Lowell has everything you need.
Goldann520
@WVHillbilly520H thanks for the tip. Oddly mine has the cable tube mounted under the seat but nothing else?
WVHillbilly520H
Same here, the plot thickens, is it a 312-8 thing?
wheelhorseman
No - it’s a 90% of manual transmissions thing.
Edited by wheelhorseman
Goldann520
@wheelhorseman you mean most manual transmissions came from the factory with the tube? Why? Thanks For the interest. By the way what would it cost to complete it . Clevis hitch and all? Thanks
Type o
  • Similar Content
    • MainelyWheelhorse
      By MainelyWheelhorse
      Hi All, I’m a member of the RedSquare Facebook group, some of you may have seen My tractor there. I have a 1992 312-8 with a 37 inch deck. It came with a house my brother bought, and was given to me. It needed work but just minor things. I mow my lawn with it, and I just bought a plow to push snow/dirt so it’s a working restoration. It was relatively well taken care of by the previous owners so it really just needed a refresh. Anyway see you around the site!
    • 87 416-8 horse
      By 87 416-8 horse
      I’m looking for wheel horse tractors for sale or for parts in the Eastern Nebraska or western Iowa area. Preferably 8 speed manuals. Pm me or comment with what you have. The worst I could say is it’s out of my price or distance range. Edit: engine is not important, it’s going to get an engine swap.
      Thanks,
      John
    • tallen4392
      By tallen4392
      looking for rear weights  12 inch  close to 01077 zip maybe fits also let me know what you have  Thanks
    • Duramax7man7
      By Duramax7man7
      Very Solid tractor!
      Newer Agro Tires on Rear and Solid Front Turf Tires. Wheel Weights on rear. Fully Swapped Forward Swept axle off of 520h. I ran my 60" Deck on this tractor for over a year with no issues.
      Deck it solid top to bottom with no rot and newer blades. Belt and Pulley are good to go!
      She's just a little dusty and needs a cleaning. Can get a nice Seat a Tractor Supply.
      $1175 OBO   -POOS
      (248) 9for3-8six3four Text or Call. I do not visit this site enough. God Bless.
      NEW SEAT INSTALLED ON THIS TRACTOR! Started it up and ran it for a while yesterday... Forgot how nice this thing is. Tempting to keep it but it's time to send her one her way. GREAT TRACTOR!
    • BrianStasC-101
      By BrianStasC-101
