Followers
0
Customized,Rare,Weird,Diffrent,Unique Wheel Horses
By
Charlie Smith, in Wheel Horse Tractors
Similar Content
By Tim's Toy Tractor
Seat, New! Universal Garden Tractor / Riding Mower Seat
This is a new seat that I purchased for a project tractor and never used, it is in Perfect as New Condition.
I have used this seat on a few Wheel Horse tractors, and they have been a perfect fit and look great.
This is a Universal fitment seat; it has multiple mounting holes and mounting patterns for fitment on most Graden Tractors and Riding Mowers.
$49.00 Call Tim @ 1-313-460-8858 (Local Pick-Up Only, No Shipping)
Two 3 Rib Firestone Tires, 16x6.50-8, 2 of them mounted on OEM Wheel Horse Rims, NEW!
These tires are New, Never Used! Not the cheap China ones, these are High Quality Firestone Tires!
Great for any Garden Tractor or Riding Mower
They are mounted on original Wheel Horse wheels that have been sandblasted & epoxied, and painted with ivory colored paint, note there are a few chips along the inside bead from mounting the tires. The rims will need your specific size wheel bearings installed.
$99.00 Call Tim @ 1-313-460-8858 (Local Pick-Up Only, No Shipping)
C - Series, Hood and Sheet Metal (square black insert) (also known as black hood models) for sale!
This sheet metal set, including C Series Hood, Dash piece, Seat Bracket, and Left & Right-Side Covers, and Left & Right Floorboards was sandblasted, epoxy primed, and painted the OEM Wheel Horse Red Paint.
The painted set is not perfect, a little metal pitting on one of the floorboards, a few little imperfections in the paint here and there as I'm a rookie painter, but this is a nice painted set of sheet metal to freshen up your C Series Wheel Horse!
$140.00 O.B.O. Call Tim @ 1-313-460-8858 (No Shipping, Local Pick-Up Only)
By WheelPuke
I have my 25A fuse blowing every time I put a new one in the slot. The old one was burnt up when I got the tractor put this year. It sat for a year with a dead battery. I stopped using it as much because the transmission is clattering pretty bad when taking off on second or higher. I had to replace the clutch belt a few years ago and couldn't get an OEM. Not sure what is the problem there that's another issue though.
I have checked the wiring and patched the worn spots where it could be grounding out. The fuse blows as soon as there is power to the system with the ignition off. I'm at a loss of what to check for at this point. Any input from someone who has had this issue would be appreciated. I'm not sure what these units are in the photos but do not know how to test them for a failure. They are directly in loop with the battery and the ignition loom looks to run into that 25A fuse.
By Deer hunter
Does anyone know where I could find a complete engine rebuild kit from for the k-19 ? I absolutely love my c-195 and have had it for years. But the motor let go last fall and I want to rebuild it or upgrade the motor, any suggestions?
