Nick Vaughn
hi i have a 76 b-111 old school well after 30+ yrs the tires need changed the current size is 22x7.5-12 can i swap them with a 23x8.5-12 without alot of hassle thank u guys
Kelly
Yes a straight fit, most models come with the 23x8.5x12 tires, the rims you have are the same as the other tractors.
and :WRS:
AMC RULES
:WRS:
Sparky
I'm surprised that a B-111 has 12" rear rims. Are you sure thats the correct size?
I thought they were 10" or 8" rears.
:WRS:
Mike.............
bowtiebutler956
:WRS: If you do have 12" rims then you can buy a set of 23x8.50-12 ag bar tires from Tucker Tire on :techie-ebay: For $103 a pair. That's what I did. :thumbs:
Matt :flags-texas:
Jake Kuhn
As mike asked too,are you sure that that is the size it has because my b111 has 18x8.50-8? Jake
Nick Vaughn
i ahve to doulbe check the modle i know i had a b-111 may ahve been confused lol cant remeber the other one lol either way the current tire is a 22x7.5-12
Nick Vaughn
and my speeling is horrible lol so bear with me
Sparky
I bet what you have a B-100. I think they came with 22x7.50x12. If thats the case, yes, you can install 23x8.50x12's.
Mike........
  • Similar Content
    • CasualObserver
      By CasualObserver
      Operator manual
      Illustrated parts list
      6 pages 3.73MB
      Illustrated parts list #A-7136
      Includes PSB #023 #052 #058 #060 #080
      10 pages 938.48KB
      Engines used according to Toro
      Clinton B1290-1107
      Kohler K91-31307A
      Kohler K91-31388A
      Electric start kit
      Electric starter kit model EC-35 for Clinton engine - Listed for 1958 and 1959
      Electric starter kit model EK-35 for Kohler engine - Listed for 1958 and 1959
      6-12 tire chains model TC-12 - Listed for 1958 and 1959
      Seat cushion Foam rubber with imitation leather cover model FC-24 - Listed for 1958 and 1959
      Transmission drive belt 1567 - (4L x 29" or 1/2" x 29")
      Details & Attachments
      2 pages 107.33KB
      1958 model RJ-58
      1958 serial numbers that have shown up for the RJ-58
      Early models used Kohler K90T-27107D equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      00005
      00251
      01099 - No casting date on trans. Leather gearshift boot, large, round rear wheel hubs, "slab" hitch, replacement engine
      01188 - Has round rear wheel hubs
      01516
      01636
      01768
      01789 - No casting date on trans. Leather gearshift boot, 3-ear triangular rear wheel hubs, "slab" hitch, Clinton engine with Schnacke recoil
      01797
      01871
      02525
      03177
      03501 - Located in UK
      03796 - Kohler K90T-27107D with serial 364044 equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      04041
      04883
      04885
      05000
      05619
      05714
      05798
      06528 - May be 16528
      06749
      06771
      07633
      07649 - Transmission J12-8 October 12, 1958
      07725
      08440
      08612
      09284
      09337 - Hard to read
      10163
      11432
      11628 - # 3521 spline gear with 10 splines changed to 11 splines in 5003 and 5010 transmissions at serial # 11628 PSB #023
      11916
      12221 - B3-9 trans casting date - Kohler K91 engine with Schnacke recoil
      12291
      14473
      14713
      16097
      16528 - May be 06528
      166x6
      16868 - F4-9 trans casting date - Kohler K91 engine with Fairbanks recoil, solid pan seat without holes
      18348
      June 2023
      18500 and lower
      Late 1958 units came with a Kohler K-91T-31307A equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      2 pages 106.94KB
      1959 model RJ-59
      1959 serial numbers that have shown up for the RJ-59
      Early 1959 units came with a Kohler K-91T-31307A equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      18501 and up - Possible 1100 units built
      20078 - Located in UK
      203xx
      21033
      21259 - F30-9 trans casting date = June 30, 1959
      292xx
      21900 - 1960 Suburban 400 began production at serial #21900 somewhere around Aug-Oct 1959.
      Late model RJ-59 tractors with a Kohler would have a K-91T-31388A with the Fairbanks recoil starter and paper air filter element. The 31388A was also used on the 1960 Suburban 400.
      K91T-31388A Serial 425251 found on RJ-59
    • BuffaloD200
      By BuffaloD200
      Finally getting around to working on my ark loader.  The previous owner said he thinks the problem is with the spool valve.
      As I've learned a bit more about hydraulics now, I'd like to get this all sorted out.
      I noticed the power beyond port is connected to the reservoir return.  Is that right?
      Anyone see anything blatantly incorrect?
    • ccs002
      By ccs002
      Looking for a complete hydro pump for a D-160. Tractor is missing everything from the rubber coupler disc back. Also willing to buy a complete tractor for parts, the closer to Harrisonburg VA the better. Thank you.
    • eo1bart
      By eo1bart
      Looking for a gearbox with 1 1/8" axles for my 312. Ok if it needs rebuilding.
      Located in the New England area
    • Tim's Toy Tractor
      By Tim's Toy Tractor
      Seat, New! Universal Garden Tractor / Riding Mower Seat
      This is a new seat that I purchased for a project tractor and never used, it is in Perfect as New Condition.
      I have used this seat on a few Wheel Horse tractors, and they have been a perfect fit and look great.
      This is a Universal fitment seat; it has multiple mounting holes and mounting patterns for fitment on most Graden Tractors and Riding Mowers.
      $49.00  Call Tim @ 1-313-460-8858     (Local Pick-Up Only, No Shipping)
