608KEB 829 #1 Posted Thursday at 08:27 PM I need some help disassembling Sunstrand Hydro and reattach clip that holds each shaft together in center of transmission. Also what would a suggestion be as how to place transmission, so it's easy to work on Share this post Link to post Share on other sites
608KEB 829 #2 Posted Thursday at 08:29 PM I'm not a expert on this... I hopefully can handle it with some advice. Thanks! 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,259 #3 Posted Thursday at 08:51 PM Need a service manual? 1 1 Share this post Link to post Share on other sites
squonk 46,692 #4 Posted Thursday at 08:56 PM You can mount the transmission on an engine stand 1 Share this post Link to post Share on other sites
ebinmaine 79,033 #5 Posted Thursday at 11:12 PM 2 hours ago, 608KEB said: I'm not a expert on this... I hopefully can handle it with some advice. Thanks! If you can tell a closed-end wrench from a chainsaw you should be able to ratchet your way through this. When we did the full restoration project on my 1975 C160 Automatic I had to split the case. THESE PARTS ARE HEAVY. Please use appropriate cautions, tools, and PPE. I had the pump off for cleaning. Set it aside on the bench. The lower case is similar to the Wheelhorse Unidrive manual transmissions. Just less gears in there. All parts are readily available from one of us or our vendors. I like @squonk's engine stand idea. Be prepared for thorough cleaning outside and inside of everything anything those things and all things. After that clean it more. Here's the thread from that. Let me know what gaskets you need. I may have them here. @pfrederi @daveoman1966 and @953 nut were very helpful on that. 3 1 Share this post Link to post Share on other sites
953 nut 66,350 #6 Posted Thursday at 11:39 PM 3 hours ago, 608KEB said: reattach clip that holds each shaft together in center of transmission. Also what would a suggestion be as how to place transmission, so it's easy to work on There is a HEAVY DUTY snap ring on each axle that retains them in the differential. You should mount the snap rings with the sharp edge toward the opposite axle when installing them. You would be well advised to replace Flex Top lock nuts on the differential bolts, McMaster-Carr is a good source if you don't have a good local source. https://www.mcmaster.com/products/nuts/locking-type~flex-top/ Engine stand mounting would be good for cleaning but once you are beyond that point it is a table top project because the housing needs to be split. 2 Share this post Link to post Share on other sites
squonk 46,692 #7 Posted yesterday at 01:08 AM You can mount the trans in the engine stand and remove the hydro part. Then take out the 2 bolts holding the right side of the trans axle. it will hang there with no issues as it's not real heavy without the hydro parts. Or build a wooden box with a hole in the top so you can drop the left side axle through like a work stand. 3 1 Share this post Link to post Share on other sites
Achto 31,879 #8 Posted yesterday at 01:14 AM I recently replace the axle bearings & seals on one. I use a table that the top two pieces separate on, this allows the tranny to be placed with the right hand side up. 4 1 Share this post Link to post Share on other sites
oliver2-44 11,502 #9 Posted 23 hours ago (edited) With a hydro cleanliness is paramount. Clean the outside to a sparkle before you split it open. @squonk @Achto Does he have to take the pump off? don't I recall talk of being able to remove the right side if you just need to remove the differential. @608KEB While you have it open check and clean the screen suction filter Edited 23 hours ago by oliver2-44 3 1 Share this post Link to post Share on other sites
Bar Nuthin 2,507 #10 Posted 21 hours ago 1 hour ago, oliver2-44 said: don't I recall talk of being able to remove the right side if you just need to remove the differential. I've pulled the right side casing off two different Sundstrands while still on the tractor. One to replace the differential/axles and the other just because it leaked faster than you could fill it. On that one I discovered this tragedy inside. 3 1 1 Share this post Link to post Share on other sites
Achto 31,879 #11 Posted 15 hours ago (edited) 9 hours ago, oliver2-44 said: Does he have to take the pump off? don't I recall talk of being able to remove the right side if you just need to remove the differential. You will be able to remove the right hand side without removing the pump. There are two bolts that go through the pump housing and case halves, and two bolts that just hold the pump housing to the left hand side of the case. I was easily able to remove the right hand side to replace axle bearings without removing the pump. Edited 14 hours ago by Achto 1 1 1 Share this post Link to post Share on other sites
953 nut 66,350 #12 Posted 14 hours ago 29 minutes ago, Achto said: I was easily able to remove the right hand side to replace axle bearings without removing the pump. I started with this method once while replacing a broken axle. The taking apart portion was fine, but the reassembly and keeping the gasket in place while getting shafts into the needle bearings while finessing the heavy casting into place just wasn't my cup of tea. The "Work Mate" like Dan @Achto pictured above is a much better way to do it. 9 hours ago, oliver2-44 said: With a hydro cleanliness is paramount. Clean the outside to a sparkle before you split it open. Any dirt that gets inside will shorten the life of any hydro. If you don't have a pressure washer at home load it up and take it to the self-service car wash. 2 2 Share this post Link to post Share on other sites
Achto 31,879 #13 Posted 13 hours ago (edited) 38 minutes ago, 953 nut said: The "Work Mate" I use and abuse that little table A LOT. It's handy as heck, has a good work height, and stores small. I have had to replace the top boards once or twice in it's 15+yrs of service, mainly do to abuse. https://www.walmart.com/ip/BLACK-DECKER-WM125-Workmate-Portable-Project-Center-and-Vise/8054746 Edited 13 hours ago by Achto 2 Share this post Link to post Share on other sites
squonk 46,692 #14 Posted 11 hours ago I got my first work mate by inheritance when my Mother in Law died some 30 years ago. It was pretty pristine then but most of the wood is gone now. Maybe this winter I'll "Restore " it We had a Black & Decker outlet store near here a while back. I bought a brand new Workmate. Not even close to the original 1 Share this post Link to post Share on other sites
pfrederi 20,619 #15 Posted 10 hours ago Another vote for workmate with a custom jig the hole in the vertical is for the brake arm shaft. These are what yo want for bolts (180,000psi) nuts and rings. 2 1 1 Share this post Link to post Share on other sites
Handy Don 16,698 #16 Posted 10 hours ago 14 hours ago, Achto said: Wow, that WorkMate bench has been worked! 2 Share this post Link to post Share on other sites
608KEB 829 #17 Posted 3 hours ago I'll pick up a workmate bench this weekend...Thanks for the comments! 2 Share this post Link to post Share on other sites
Handy Don 16,698 #18 Posted 1 hour ago 1 hour ago, 608KEB said: I'll pick up a workmate bench this weekend...Thanks for the comments! Do a little research and check out Craigslist in your area. I have two of these and have seen them for as little as $30. Also check the reviews. I’m told that recent models are not as strong/stable as older ones. One permanently set up in my shop has the front jaw that tilts to vertical making it very helpful for some wordworking projects. 1 Share this post Link to post Share on other sites
