MainelyWheelhorse 3,208 #1 Posted October 9, 2025 Hi all, lately I’ve been working on the C-141 Automatic tying up loose ends. I’m working on the parking brake, and aren’t sure if the spring setup is like the 8 speeds, Or if it’s just the one spring like what’s on it now. I’ve looked it up online. The schematic pictures don't really show well how the brake goes together. Any assistance on figuring out the parking brake setup is appreciated. TIA. 1 Share this post Link to post Share on other sites
c-series don 12,752 #2 Posted October 9, 2025 I will try to post a picture tonight. 3 Share this post Link to post Share on other sites
953 nut 70,653 #3 Posted October 9, 2025 Take a look at this great thread from @cleat that documents his restoration, it probably has what you are looking for on page 11. 2 Share this post Link to post Share on other sites
ebinmaine 81,281 #4 Posted October 9, 2025 That thread's tractor has an Eaton trans. A C141 has a Sundstrand. Is the linkage the same? Here's a link to some of the posts in the middle of the thread for the tractor we built for my parents. As you know, we now have that so I can get you pictures if it helps. 1 Share this post Link to post Share on other sites
MainelyWheelhorse 3,208 #5 Posted October 9, 2025 @ebinmaine I’ve looked through that thread and didn’t see what I was looking for. I’m looking for the spring setup on the parking brake. Looking at some threads with similar tractors I didn’t see any noticeable springs that returned the lever to unlocked like the 8 speeds do. Since it was a parts tractor I wanted to make sure I had all the parts. @953 nut thanks for the help. @c-series don I’ll check that out once you post it. 1 Share this post Link to post Share on other sites
953 nut 70,653 #6 Posted October 9, 2025 (edited) 1 hour ago, ebinmaine said: Eaton trans. A C141 has a Sundstrand. Is the linkage the same? Eric, your pictures probably will be helpful to @MainelyWheelhorse though I think the parking brake linkage is the same on the Eaton 1100. When I changed from the Sundstrand Hydro-gear to Eaton 1100 the linkage was very different but the later piston to piston on the C-XX1 has about the same parking brake set-up as the Eaton's. 1 hour ago, MainelyWheelhorse said: I didn’t see any noticeable springs that returned the lever to unlocked like the 8 speeds do. You are looking for the spring that connects to the parking brake cam or lever inside the tunnel where the direction control lives, is that correct? I have a photo of the spring that returns the parking brake as installed on my GT-14. I had to use some 10-32 bolts in place of the Wheel Horse attachment points due to this being a modification but the hook up should be the same as yours. Just found the picture. Edited October 9, 2025 by 953 nut add photo 1 1 Share this post Link to post Share on other sites
953 nut 70,653 #7 Posted October 9, 2025 Here is a picture from @cleat's thread on page 12. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,557 #8 Posted October 9, 2025 1 Share this post Link to post Share on other sites
MainelyWheelhorse 3,208 #9 Posted October 9, 2025 I’m looking for how this (white circle) is set up. Looking at it now, It looks like it’s set up right looking at @953 nuts pictures and @gwest_cas picture. I figured there would be some sort of return like the 8 speeds but I guess not. My return spring is pretty shot though. Thanks for the help! 1 1 Share this post Link to post Share on other sites
953 nut 70,653 #10 Posted October 9, 2025 45 minutes ago, MainelyWheelhorse said: My return spring is pretty shot though. It would be a longshot but perhaps @cleat has information in the spring size and where to get a new one. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,557 #11 Posted October 9, 2025 See there are two #1230 springs in there https://www.partstree.com/models/81-14ks01-c-141-toro-lawn-tractor-1978/clutch-brake-and-speed-control-linkage-2-7/ Adding - looks like the 1230 was replaced by 83-2820 but it is no longer available either. 1 1 Share this post Link to post Share on other sites
c-series don 12,752 #12 Posted October 10, 2025 @MainelyWheelhorse just checked in and it looks like the boys already took care of it! I have to say it again, “This place is the best!” 2 1 Share this post Link to post Share on other sites
Bar Nuthin 3,645 #13 Posted October 11, 2025 The brake pedal spring is a tough one to get a picture of. 1 Share this post Link to post Share on other sites
MainelyWheelhorse 3,208 #14 Posted October 11, 2025 On 10/9/2025 at 9:03 PM, c-series don said: @MainelyWheelhorse just checked in and it looks like the boys already took care of it! I have to say it again, “This place is the best!” I definitely agree. I was able to get my C-141 to where it is because of this forum. 4 Share this post Link to post Share on other sites
