oliver2-44 11,847 #1 Posted October 9, 2025 Is the 8 speed transmission case the same as the 6 speed case? I have 2 spare 8 Speeds and wondering if I can build a 6 speed without too many replacement parts. No 6 speeds around here so far. A six speed would be nice since its directly interchangeable with some of the 3-4 speed brake linkages and the 953/1054 brake linkage. So I been studying the transmission manual, parts list, pictures and @stevasaurus videos trying to determine if a 8 speed case could become a 6 speed. I know the brakes are on different shafts, but looking at part list drawings and pictures it sure seems the angled brake band mount is the same. I'm thinking they just made the brake band a little different. I would need a couple of different gears, but a lot of them are the same. The bearing holes in the cases look the same best I can tell from pictures. @Racinbob I know you recently had a 6 speed on the bench. If you or anyone have a way to compare the 2 cases, especially the brake band mount and bearing hole sizes I would appreciate any comments you can share. The next question is can an 8 pinion differential be used in place of the Limited Slip Differential. I seem to recall reading it can, but haven't found that info again. I wouldn't mind a LSD, but I already have a good usable 8 speed diff with 1-1/8" axles. Are the 8 speed differential gear to 6 speed brake shaft gear teeth count compatable? I appreciate any info and thoughts ya'll can share. 1 Share this post Link to post Share on other sites
oliver2-44 11,847 #2 Posted October 9, 2025 Doing a little more looking, I see the 5060 parts list show a right case #7066, left case 6941 and the 103916 8 speed shows a right case as 8163 and left case as 6941 So the right case halves have different part numbers and the left case haves have the same part number. They sure look the same in pictures, so what's the difference? Share this post Link to post Share on other sites
Racinbob 13,290 #3 Posted October 9, 2025 I've wondered about that a few times but short of actually doing the change it would be nearly impossible to know for sure. Having one of each open at the same time would help. I think the cases will interchange. The obvious would be bearing changes and different shafts. The 8 speeds use a brake rod that goes over the top of the drum and has a dogleg in it. The 6 speed rod is straight and shorter. The brake bands are reversed but it might be possible to interchange. As far as the case part #'s often times Wheel Horse changed something insignificant that really doesn't affect interchangeability. I'm thinking it's possible to change an entire 8 speed for a 6 speed with nothing more than some simple linkage changes. But again.........I haven't actually done it. Share this post Link to post Share on other sites
ri702bill 13,394 #4 Posted October 9, 2025 Having done an 8 speed swap on my 854 years ago, this much comes to mind. The 6 speed is a simpler swap, the input shaft & pulley are the same, externally, as the 4 speed. The brake & parking brake are in the same location. Ask @Handy Don. The 8 speed is the opposite on these two items - the input shaft is 5/8", not 3/4". This nesessitates a special new pulley. The brake band mounting is reversed - the action of the rod goes from push to pull. I used a Raider style ros for this. I did not bother to try to come up with a solution to the parking brake, as 1st in low range is about as good. Share this post Link to post Share on other sites
ebinmaine 81,282 #5 Posted October 9, 2025 1 hour ago, Racinbob said: it's possible to change an entire 8 speed for a 6 speed with nothing more than some simple linkage changes. I believe that's true. I've had a 12?7 here in the past that was changed to a 8 by a PO. I gave up on that because of the linkage and EATING belts. But I digress..... 6 hours ago, oliver2-44 said: anyone have a way to compare the 2 cases, I could do that Saturday. I have a 6 speed disassembled on the shelf. Maybe an 8 too but that could happen anyway. Share this post Link to post Share on other sites
Racinbob 13,290 #6 Posted October 9, 2025 2 hours ago, ri702bill said: The 8 speed is the opposite on these two items - the input shaft is 5/8", not 3/4". This nesessitates a special new pulley. The brake band mounting is reversed - the action of the rod goes from push to pull. I used a Raider style ros for this. I did not bother to try to come up with a solution to the parking brake, as 1st in low range is about as good. Actually both pull the brake band tight to the drum. The 8 from over the top, the 6 from below. The 4 to a 6 swap is pretty simple. Of course provisions will have to be made for the hi/low shifter which will vary by tractor model. A 3 or 8 to a 6 requires the linkage changes but I don't see that as an issue. I thought about putting the 6 in the Reborn B-80 just for the limited slip but I decided not to. I'm thinking a young fella is going to do the 854 swap thing with it. Don't know for sure. 1 Share this post Link to post Share on other sites
ebinmaine 81,282 #7 Posted October 9, 2025 3 minutes ago, Racinbob said: . The 4 to a 6 swap is pretty simple. Of course provisions will have to be made for the hi/low shifter which will vary by tractor model. A 3 or 8 to a 6 requires You're headed down the right road but the numbers are reversed a little. Three and six are compatible. Direct bolt in. Four and eight are compatible. Direct bolt in. 2 1 Share this post Link to post Share on other sites
953 nut 70,654 #8 Posted October 9, 2025 (edited) I did the six speed in a 953 swap about twenty years ago. Two of the mounting holes did not line up so one hole in the plate had to be elongated slightly and the other hole I drilled and tapped into the transaxle case. I used the 953 differential and axles in the six speed. To use the ten pinion you would need a pair of GT-14 axles or have a machinist cut a snap ring grove into the axles because of the tight clearance in the area of the limited slip spring. I have not looked into the eight pinion but there may be enough clearance inside to use the roll pins to retain the 953 axles. Edited October 9, 2025 by 953 nut 1 Share this post Link to post Share on other sites
702854boy 1,245 #9 Posted October 9, 2025 2 hours ago, Racinbob said: I'm thinking a young fella is going to do the 854 swap thing with it. Don't know for sure I'm planning on it 1 Share this post Link to post Share on other sites
Racinbob 13,290 #10 Posted October 9, 2025 2 hours ago, ebinmaine said: You're headed down the right road but the numbers are reversed a little. Three and six are compatible. Direct bolt in. Four and eight are compatible. Direct bolt in. You are 100% correct. I had it backwards. I always do that in my head but now I done put it in writing. 2 Share this post Link to post Share on other sites
Handy Don 17,735 #11 Posted October 9, 2025 3 hours ago, 953 nut said: I used the 953 differential and axles in the six speed. To use the ten pinion you would need a pair of GT-14 axles or have a machinist cut a snap ring grove into the axles because of the tight clearance in the area of the limited slip spring. I have not looked into the eight pinion but there may be enough clearance inside to use the roll pins to retain the 953 axles. Exactly. The Limited Slip function is entirely contained within the differential/axle assembly. I have no idea if an LSD with axles would directly replace the 8-pinion differential and axles of an 8-speed. Will the bull gear mesh properly with the different final gear which is NOT carrying the brake drum in the 8-speed. Do the outer diff plates mate properly with the inner axle bearings? Are the axles the correct lengths? I believe I saw a document that instructed dealers on how to convert in the other direction, i.e. swapping an 8-pinion diff in to replace a 10-pinion LSD. Can anyone dig that up? 1 1 Share this post Link to post Share on other sites
953 nut 70,654 #12 Posted October 9, 2025 2 hours ago, Handy Don said: Do the outer diff plates mate properly with the inner axle bearings? The interchangeability of transaxle components seems limitless. Paul @pfrederi put a limited slip from a Sundstrand in an eight speed and I put the differential from a 953 into a six speed. Some 1970 transaxles had Torrington B-348 bearings because of a temporary unavailability of 1533 bearings but if you remove the race from the end plate of the differential a 1533 will fit right on there or the Torrington could be pressed into the transaxle housing. 4 Share this post Link to post Share on other sites
stevasaurus 23,892 #13 Posted October 9, 2025 A few things guys...the #5073 is a 10 pinion, Limited Slip that is considered an 8 speed transmission...soooo the brake drum and linkage will be the same and a direct bolt in as an 8 pinion differential. With that in mind, you should only have to change out the differential & the mushroom gear...or vice versa. There is a Service Billitin that explains what needs to be done to change out a 6 speed 10 pinion differential to an 8 pinion differential. This change over SB (I think) says you only need to change out both the 10 pinion differential & mushroom gear for an 8 pinion differential & mushroom gear. Again, if you go this route, you do not have to mess with any linkage or brake drum. Both of the above transformations are designed to use the same transmission case that you already have. It seems you guys want to change a 6 speed case to an 8 speed case or change out an 8 speed case to a 6 speed case. Both will bolt in directly, but now you need to deal with all the linkage and brake drum. This is not all you would need to change out though. You also need to swap the cluster gear shafts, the mushroom gears, the cap and threw bearings on the left side of case. The bull gears and the small gear of the 11/44 tooth gear will mesh, but the length of the gears cut into the mushroom gear may be an issue. The 8 speed cases have the clutch on the left and the brake on the right. The 6 speeds and 3 speeds have the brake and clutch on the left side. I am not sure what a 4 speed does with their linkage. @953 nut had to drill new holes (2) to mount a different transmission on his 953 because he has a "Heavy Duty" original transmission and those holes do not match up with the other Uni-Drives. His 3 speed trans came with 1 1/8" axles and the "Bevel Gear Differential. I hope that hejps a little. 4 Share this post Link to post Share on other sites
Racinbob 13,290 #14 Posted October 9, 2025 What I'm dealing with is a young man wanting to put a 5060 on his 854. Looking at my 854 next to the 5060 I think the hardest part will be the hi/low shifter. Definitely not trying to swap internals. 2 1 Share this post Link to post Share on other sites
Racinbob 13,290 #15 Posted October 9, 2025 That being said I don't think it would be a biggie to swap cases. Essentially removing all the components including bearings. Somewhere in this thread that's what was sorta asked. I think doing a bunch of marrying components from both a 6 and an 8 might be fun but a potential can of worms. Also a one pedal to a two pedal tractor has many more issues which is one of the reasons I decided to leave my Reborn B-80 as is. I'll be meeting the young man and his Dad tomorrow. 3 Share this post Link to post Share on other sites
stevasaurus 23,892 #16 Posted October 9, 2025 I found the Service Bullitin !!!! It's # 252 4 Share this post Link to post Share on other sites
702854boy 1,245 #17 Posted October 10, 2025 6 hours ago, Racinbob said: Looking at my 854 next to the 5060 I think the hardest part will be the hi/low shifter. I'm thinking the hardest part would just be trying to figure where exactly to drill the hole but as the saying goes, if there's a will, there's a way. 1 Share this post Link to post Share on other sites
oliver2-44 11,847 #18 Posted October 10, 2025 7 hours ago, stevasaurus said: It seems you guys want to change a 6 speed case to an 8 speed case or change out an 8 speed case to a 6 speed case. Both will bolt in directly, but now you need to deal with all the linkage and brake drum. You also need to swap the cluster gear shafts, the mushroom gears, the cap and threw bearings on the left side of case. The bull gears and the small gear of the 11/44 tooth gear will mesh, but the length of the gears cut into the mushroom gear may be an issue. Yes Steve, I have 8 speed cases and 8 pinion differentials, and want to build a 6 speed sourcing the minimum number of gears. I do recall a post where a member had to grind the end of a mushroom or 11/44 gear for clearance. @ebinmaine if you can look at you 2 transmissions and determine if the brake mounting flange is the same on both cases, I think the internals are sounding positive. 1 1 Share this post Link to post Share on other sites
ebinmaine 81,282 #19 Posted October 10, 2025 6 hours ago, oliver2-44 said: @ebinmaine if you can look at you 2 transmissions and determine if the brake mounting flange is the same on both cases, I think the internals are sounding positive. Be happy to. 6 hours ago, oliver2-44 said: want to build a 6 speed sourcing the minimum number of gears I have a small box of spares that IIRC were from a 6. >>> They are worn <<< but usable for a show cruiser. If there're any usable to you I'd be glad to send em. I wouldn't put them in a worker which is why they're shelved here. Share this post Link to post Share on other sites
Handy Don 17,735 #20 Posted October 10, 2025 21 hours ago, Racinbob said: What I'm dealing with is a young man wanting to put a 5060 on his 854. Looking at my 854 next to the 5060 I think the hardest part will be the hi/low shifter. Definitely not trying to swap internals. If you have the 5060 complete, you can readily swap it in. That is exactly what I did and I am delighted. There is no oil dipstick on the 5060 so there is nothing on top of the transaxle to interfere/accommodate. You’ll need to cut a hole in the bottom of the console base for the hi-lo shifter--I used a Milwaukee Carbide hole cutter and had a scrap of lumber clamped to the underside to guide the drill. The only real issue is that the hi-lo shifter is held on with a roll pin that must be inserted after the shifter lever and console base are installed but before the fender support/tool box gets installed. Remember to do this and you are golden! 3 Share this post Link to post Share on other sites
stevasaurus 23,892 #21 Posted October 10, 2025 @oliver2-44 Hi Jim, You should be able to do what you are looking to do. Remember that the 11/44 gear teeth is positioned different because the axles on the 8 pinion are equal length...the axles are different lengths with the 10 pinion differential. 1 1 Share this post Link to post Share on other sites
Handy Don 17,735 #22 Posted October 10, 2025 (edited) 18 hours ago, oliver2-44 said: @ebinmaine if you can look at you 2 transmissions and determine if the brake mounting flange is the same on both cases, I think the internals are sounding positive. I think you are asking if the 5060 case's brake tab is in the same place as the for 8-speeds. It cannot be. Their brake drums are on different shafts that exit the case in different places. The 6-speed (and 3-speed) drums rotate clockwise when looking from the left side of the tractor. The 8-speed rotates faster and counter-clockwise. Edited October 10, 2025 by Handy Don 2 1 Share this post Link to post Share on other sites
702854boy 1,245 #23 Posted October 10, 2025 1 hour ago, stevasaurus said: .the axles are different lengths with the 10 pinion differential Why is that? Share this post Link to post Share on other sites
ebinmaine 81,282 #24 Posted October 10, 2025 1 hour ago, 702854boy said: Why is that? The bull gears are offset from 6 to 8 speeds so the axles are unequal to make up for it. Share this post Link to post Share on other sites
702854boy 1,245 #25 Posted October 10, 2025 4 minutes ago, ebinmaine said: The bull gears are offset from 6 to 8 speeds so the axles are unequal to make up for it. Is it offset for more room for the limited slip? 1 Share this post Link to post Share on other sites
