chipwitch
Unveiling: tub style chicken plucker implement
dcrage
Geez Chip -- That thing does a great job of cleaning the feathers!! -- Where do the feathers end up at and how do you clean it out?
chipwitch
While we did find alcohol to be an essential element in processing the chickens, we found a far more beneficial use for it than setting it afire!
:beer:
When I was a boy ....
we had to do this by hand,
and burn off the pin feathers over a saucer of burning alcohol !
You kids with your new-fangled contraptions !!D
chipwitch
Thanks Dave!  The feathers are being constantly flushed away by spraying water.  They simply slide down the sides and end up on the ground where they're easily raked up (there's no bottom in the tub).  That's how I designed mine, but some people opt for the bottom in the tub that directs the feathers out a chute. If you've never seen one of these pluckers, the "whizbang" is a popular incarnation of it.  A google or youtube search will reveal dozens of them in use.  The trick is the rubber fingers.  The rest is pretty simple.
chipwitch
                                                             That thing has to be quite noisy.    :happy-bouncymagenta:  :happy-bouncyblue:
                                                             Those  birds will really cackle  when get tickled by those magic fingers.
What's noisy about a 12 HP Kohler?  Besides, idle speed is fast enough.  It takes about a minute at that speed.  I found about 1/3 throttle was ideal, 220 rpm or so.  That's the speed in the video.
You are using actual feather pluckers in the drum!
Is there a viable alternative?
chipwitch
Love it! I have the whizbang plucker book and had thought of using a horse. I'm glad to see the idea works. Thanks for the video
Did you ever build one?
posifour11
No, its on the ever growing list. But yours looks better.
KC9KAS
I don't know....My wife works for a turkey processing plant (distribution assistant manager) and she told me what they were!
Ed Kennell
No,I know the Kohlers are quiet.  I was referring to all the noise the chickens would make when they were being tickled by all those magic fingers.
Now I understand...they are deadly silent when you put-em in the plucker.
chipwitch
Oh, that is just SOOO WRONG!  I'm picturing getting the order of steps backwards.... pluck before killing?  I don't know whether to laugh or cry!  Hope PETA isn't listening.
Wishin4a416
I like it!
Geno
That is fast as lightning, I LIKE IT!  :text-woo:   :text-+1:   :text-+1:
chipwitch
You will need some potatoes to go along with that chicken,
http://www.youtube.com/watch?v=Qsh-BI2LDD8
Nice job on the video! :woohoo:
That's pretty slick too!  Where can I get me one of those?  Chicken and potatoes sound good to me...
Now.... if I scale that up and run it off the Horse, I could feed a couple small countries.  Sounds like another cool project :)
Ed Kennell
What was that on the end of that spud peeler?
boovuc
I can't help thinking about the wood-chipper scene in the movie, Fargo.  Sorry! That is quite the creation. I have to hand it to you!
chipwitch
I appreciate all the kind words, but I can't accept credit for the contraption.  Someone far smarter than me invented the thing in the 40's as I understand it.  I merely thought it would be neat to mount it to the tractor.
Geno
If it wasn't on a :wh:  before then it's original to us.   :handgestures-thumbsup:
Save Old Iron
:beer:
I figured when I saw your posts on the other site and the word chicken and Arduino were mentioned in the same thread, something like this would not be too far behind.
RMCIII
It's just a small brush is all.
Rob
chipwitch
I must confess, I have long suspected I may be a direct descendant of Rube Goldberg's love child.  :dunno:
Coadster32
Way cool. Never seen anything like this. Thanks for sharing, and great way to attach it to a WH. :handgestures-thumbupright:
meadowfield
that is just awesome!
KyBlue
What a awesome job!!   Have a friend who is raising chickens this coming year ... might have to make one of these ... certainly beats other methods I've seen/Done!
My Hats off to you!
DotheDoo
GOD, That is so funny! SHowed a co-worker and just laugh. It's incredible how clean it comes out. Need something similar for us guys who have even amount of hair on our chest and back. HAHAHAHA
Geno
Oh that's just wrong Do.  :laughing-rolling:
  • Similar Content
    • the jeep driver
      By the jeep driver
      My daughter was using the Wheel Horse rider to mow, I was push mowing.  She drives over to me and says, "Dad, the blades aren't turning." I look at the mower, she's got the blades engaged (lever forward) but nothing is moving.  I disengage the blades, and re-engage... nothing.  No movement from the belt nor clutch.  Then I notice the smell, and look closer, the belt is so hot is melting on the clutch.  Or rather, the clutch is so hot it's melting the belt.  Melting occurred.
      While the clutch is disengaged, I can spin the clutch freely; and whilst it's engaged, it won't move.
      So, what did I do now?  Peter told me to lube that needle bearing, but I couldn't find a write up/how to anywhere, so I was putting it off until after the leaves were done falling in the Fall.  I haven't taken anything off yet, other than the pins that hold the pinion and such, and the little brake pad.  I see there are two snap rings, assume they come off, and then the assembly slides out as a whole?
      Some pictures of the clutch, can anyone tell if it's usable from them?
    • decvt79
      By decvt79
      My 1999 270H with 48” deck is having an issue getting power to PTO.   Checked PTO with jumper to battery and it worked fine and I’ve actually been cutting grass using the jumper for awhile.  I checked power from PTO switch to PTO and there is none.  I checked PTO switch and it appeared OK but I replaced it anyway and still no power to PTO.   Then checked brown/tan wire leading to switch and there is none.   Could the issue be the NMIR module and is there a good way to check it.  If bad, where is the best place to get a replacement and do other brands/models have NMIR a modules I can use.    Also, would suppling battery power directly to PTO switch and bypassing NMIR result in switch working.
    • trident
      By trident
      Need some help. My 800 Special has an electric PTO. It is not working. Checked Ohms - nothing. My questions are 1) how does the PTO come off and 2) can they be rebuilt? I took the bolt out that I thought holds it on but no luck. Must be something more?
    • BMW1
      By BMW1
      What direction does the front PTO Pulley turn on a wheel horse D180 with a Kohler K482 as you face the front of the tractor?
      I want to get a hydraulic pump for a Johnson 10 loader I will be mounting to tractor and want to make sure I get a pump that rotates the correct direction.
    • DMB41
      By DMB41
      Hi All,
      My first post on here so apologies in advance for any rookie mistakes.
      First off, I am the proud owner of a "new to me" 312-8. I took it out for a spin yesterday and when I engaged the PTO, currently there is a 42 in side discharge mower deck on it, there were sparks flying from the disk directly below the muffler (maybe the flywheel or clutch?). Any idea what that may be and what needs to be addressed?
      Thank you !!
