Burnerman
7 hours ago, The Freightliner Guy said:
Did you make a golf cart out of a rj?
Nope. This is my first big tractor project..
Nice:handgestures-thumbupright:
Burnerman
I have no idea what I’m gunna do with this..
It does have cool stickers, lights and a good seat. EDEC6F9B-8F9D-40DB-9927-7A0FFE9EFD69.jpeg.f32ad34b0119326169bb09fe64c6e065.jpeg
I’ve never seen a Wheelhorse seat that wasn’t cracked. Until today. 55DC689A-B7DB-4A21-87A9-5960CD361DC7.jpeg.308a398031410417e863fa4bef8fdb8e.jpeg
🤔 That pulley looks kinda big.
side by side
Edited by Burnerman
  • Excellent 2
Snoopy11
@Burnerman ...Snoop will be following along... a little late to the party... but I certainly am interesting in how this turns out for you... particularly how you overcome the rear wheel to fender clearance issue... :greetings-waveyellow:
Don
Burnerman
I am always thinking about how that’s gunna work too. Lol.
I’m hoping to find a trans with 11/8” axles and add wheel spacers. My son thinks he might be able to tub the original seat pan/fender. I’m thinking more along the lines of a steel seat and spring with round fenders
Ed Kennell
Just massage the seat pan and sit on the tranny.IMG_6890.JPG.1b3ba9014f2a0a45ea35992a9e04950d.JPG
  • Excellent 3
Heatingman
side by side
If your willing to part with it, Id find a real nice home for that seat, and the head light assembly.
Burnerman
That’s a really slick setup but that’s a lot of bodywork and not something I’m good at. My son thinks he might be able to do it though. The other issue I have is the the trans I have has 1” axles and the hubs are tight to the trans. There’s not enough width for fenders and a seat.
I’m going to the junkyard (aka parts store) Saturday. I’m going to see if there’s any fender and transmission options laying around. 😁
Burnerman
I’ll let you know about the light but I’m pretty sure I’m keeping the seat😁
 The headlight assembly is in rough shape.
Ed Kennell
I used an 8 speed tranny with stock hubs and wheels without any spacers. It is  pretty tight fit between the tires and did require some body work.
peter lena
@Burnerman  noting your heim joint / threaded rod steering set up , been road testing my set up for years ,in original design set up areas , for a durability test . never had a failure or problem  with the heims or threaded rod . also added heim to pto lever rod  at forward trunnion spot , also added one to my clutch rear linkage rod , for a test , nothing but smooth / no failures , why not  ?  also looking at your fuel pump to carb  vertical run , installed https://www.bing.com/images/search?  evil energy 5/16  one way fuel check valve , in the same spot on my  3 horses , clear vinyl fuel line , vertically , always holding a quick fuel start charge , lots of hours , no problems , use dark green squeeze clamps on hose / valve , dielectric oil / grease , light swipe on male end for easy hose slide on , pete
Edited by peter lena
wrong member
Burnerman
Peter, I think you’re looking at the picture of @Ed Kennells tractor. I’m using stock components on mine so far.
peter lena
Burnerman
@Heatingman
seat pan is roached.
headlight housing has been painted red and the lens is thin plexi and electrical tape. Lol
C00E53FD-4C4E-405D-87BB-1970C85104D1.jpeg.cf268cf5030b4f07a22ea426d06378c1.jpegC1F168C5-5702-437F-B841-E1FF073A3AC8.jpeg.05d4b8bf4c0eafc4f2b753e95a37245c.jpeg
This thing had very little going for it.
  • Haha 1
Heatingman
@Burnerman
My seat pan is fine, I mainly want that cover. I have plans to make a new cover for mine, but Ive never done it, so it shall be a learning experience.
The light fixture looks repair able, but what material is it made from? Plastic or metal? I may still be interested if its metal.
Cant even find a part number in any of the parts break downs to look for one for my B80. So, Im working up a plan to make my own.
By the way, Im curious about your user name.
Are you a fellow HVAC / boiler/burner tech?
Edited by Heatingman
ineedanother
1 hour ago, Burnerman said:
@Heatingman
That'll probably buff out :eusa-think:
  • Haha 3
Burnerman
@Heatingman  The headlight assembly is cast aluminum I think. It held in with 2 pop rivets. You’ll need to make or find a good lens. That’s easy to send out to you. The seat idk.
Yeah I’m an HVAC guy. 35yrs of it and still at it but I’m not on the road 24/7 anymore. Working in a hospital now maintaining all the equipment.
Burnerman
Buff and polish. 😂😂😂
Heatingman
Ive been at it for 25 years. Still sorta on the road, but not the first line of defense anymore. Became a superintendent 4 or 5 years ago.
Figure out a price you think is fair for the light assembly and send me a private message - wait is that a thing on this site?
Snoopy11
I think @squonk did that at one time... but I can't remember if it was in the mental ward or the morgue... :scratchead:
Either way... 'das a little scary...  :lol:
Don
squonk
Worked in a hospital for 14 years. Beds to Boilers and everything in between. Working on the morgue cooler and the hematology flow hood was a hoot! There was a historical landmark on campus that was an old funeral home and they built onto it and made offices out of it. I had to go in there at night once a month and do emergency light tests which means I had to go up to the attic and turn off breakers. Ran into a ghost in the stairwell one night and told him/her I didn't have time for it's nonsense! :)
Edited by squonk
  • Haha 3
squonk
Don
Both. In the mental ward you had to have someone with you at all times. They were always trying to steal your tools. One lady thought I was her doctor!
  • Haha 2
Burnerman
We’ve got our haunted hallway here to in the original 1932 bldg. lol.
Same here. Haha. Most of the people we get here wanna get out real bad.
Burnerman
We put this guy in the window of one of the old dormers. It was there for a couple of days till our boss saw it.
he didn’t think is was as funny as we did. 😂😂😂😂
  • Haha 3
  • Heart 1
squonk
We had a lady who cleaned the OR'S  at night. She was scared to death up there. If we went up there to work she would say " is that a ghostie? We hung a skeleton up there and yes, management wasn't happy! :lol:
  • Haha 3
  • Similar Content
    • sjoemie himself
      By sjoemie himself
      Soo.. yet another idea that floated around in my head for way too long was to build a wheelbarrow with a 'big' wheel.
      We're hauling horse manure from several places, some more muddy than others. When doing so with a 'normal' wheelbarrow the frontwheel tends to cut through the mud instead of rolling on top. My idea was to mount a single wide wheel to have more flotation so the wheelbarrow would be easier to push through the mud.
      To start things of I convinced my SO to donate her wheelbarrow to the good cause.
      This is what I started out with:
      Solid, narrow, single wheel. Yes it is crooked because the bearings are gone.
      More in next post.
    • Donavon1
      By Donavon1
      Project black Betty the diesel 1054
    • Wheel Horse 3D
      By Wheel Horse 3D
      Our customized ornaments have a base identical to our version of the original style ornament, but can be topped with 3 different styles of horse head and 3 different styles of wheel! Each is available unfinished, primed, or fully painted.
      They also include the pictured mounting hardware and the base spacer for a clean finished look. Can be ordred here https://greystone-3d.square.site/product/customizable-wheelhorse-hood-ornaments/10
    • Wheel Horse 3D
      By Wheel Horse 3D
      Welcome, and thanks for visiting our vendor area.
      We got our start in 3D printing for customers right here on Red Square!
      If you'd like to see how every thing gets developed and the contributions of Red Square members, please visit the thread that started it all and browse through our progress to date.
      We love our clients' input and work closely to turn ideas into reality. If you have an idea, request, or questions, you can post to that thread, message us or tag us here on Red Square, or visit our online store and reach out to us through there.
      Https://greystone-3d.square.site
    • Donavon
      By Donavon
      Need ideas to convert my 1054 A Frame plow into a snow blower
      Any idea's?
