squonk 43,714 #51 Posted June 6, 2022 Best guess is 150-200 lbs. With border crossing fees you better be sitting down! 1 Share this post Link to post Share on other sites
ebinmaine 72,380 #52 Posted June 6, 2022 20 minutes ago, squonk said: They are heavy enough! I'd say that's pretty close!! I'm putting in a guestimate of around 100-125 lbs NOT including the pump. 1 Share this post Link to post Share on other sites
Pullstart 66,595 #53 Posted June 6, 2022 42 minutes ago, squonk said: If there's a member " Up Nort in NY " we can do a shuttle from Wisc maybe @WHX?? to @Pullstartto show( me ) to ??? (NY North border) I don’t plan on seeing Uncle Jim in the next two weeks…. But I shipped a hydro transmission in a heavy wooden crate to CT (?) for about $150 via FedEx a year or two ago… 1 Share this post Link to post Share on other sites
WHX?? 51,690 #54 Posted June 7, 2022 3 hours ago, Mike C160 said: much trouble to put other members too. Not at all be happy to. My back hurts about thinking how much it weighs. Easily a hundred pounds. I can find out. I can get it to the Pullhosen but not till after the BS when he's here for the rally of red. Bad news is Mike I have no idea if it drives or what shape it's in. Came off a 160 carcass that had no motor when I got it. I can look it over closer and get some pics if you wish. It's not buried too far in the parts shed. 1 Share this post Link to post Share on other sites
rjg854 12,151 #55 Posted June 7, 2022 9 hours ago, WHX?? said: It's not buried too far in the parts shed. you mean the garden shed don't you 3 Share this post Link to post Share on other sites
squonk 43,714 #56 Posted June 7, 2022 1 hour ago, rjg854 said: you mean the garden shed don't you " garden" or "She" 2 Share this post Link to post Share on other sites
pfrederi 18,633 #57 Posted June 7, 2022 On 6/5/2022 at 9:14 PM, Mike C160 said: Question I have found a complete transaxle off a wheel horse Automatic 12. ( havent yet bought ) Is this the same transaxle that is in the C160? I do see some minor differences. Right side case has a different Part #, 2 different differentials... Maybe someone knows if it will work for me. That would be fantastic. Cheers Since you C-160 doesn't have the external brake the swap should not be hard. You will be going from a piston to piston to maybe a hydro gear (as i said the 12 auto came with two different hydros.) but it wil bolt on and teh motion control linkages wold be the same. The hydro lift will take some tweeking as output ports are different. Tow valve will be in a new location also. 1 Share this post Link to post Share on other sites
Mike C160 251 #58 Posted June 7, 2022 (edited) 20 hours ago, WHX?? said: Not at all be happy to. My back hurts about thinking how much it weighs. Easily a hundred pounds. I can find out. I can get it to the Pullhosen but not till after the BS when he's here for the rally of red. Bad news is Mike I have no idea if it drives or what shape it's in. Came off a 160 carcass that had no motor when I got it. I can look it over closer and get some pics if you wish. It's not buried too far in the parts shed. Well, Lets do this. If it ever stops raining, I will pull it out and split the case. Bearings gaskets and seals i can get from Lowell. My big concern is damaged gears anywhere in that unit. If that happens maybe i will get you to part it out. It would be cheaper to ship a few parts, rather than the whole thing. Although I would be over the moon to have a spare. We'll do a Radar O'Reilly and Mail an entire Jeep home from Korea ..... one part at a time. Cheers Edited June 7, 2022 by Mike C160 6 Share this post Link to post Share on other sites
Mike C160 251 #59 Posted June 7, 2022 2 hours ago, pfrederi said: Since you C-160 doesn't have the external brake the swap should not be hard. You will be going from a piston to piston to maybe a hydro gear (as i said the 12 auto came with two different hydros.) but it wil bolt on and teh motion control linkages wold be the same. The hydro lift will take some tweeking as output ports are different. Tow valve will be in a new location also. Thanks This is great info. I will get photos. This way we can see which unit it is by where the hydro lines are. Cheers 1 Share this post Link to post Share on other sites
ebinmaine 72,380 #60 Posted June 7, 2022 17 minutes ago, Mike C160 said: My big concern is damaged gears anywhere in that unit. If that happens maybe i will get you to part it out. It would be cheaper to ship a few parts Keep me posted on what you need. I have a few gears out of a 1970 Charger Hydro. Don't know if they're the same. 1 Share this post Link to post Share on other sites
Mike C160 251 #61 Posted June 8, 2022 Ok, Here are some photos from the Automatic 12 transaxle. Anyone know which one this is? Early? Late? 1 Share this post Link to post Share on other sites
953 nut 59,743 #62 Posted June 8, 2022 You have the later Piston to Piston Sundstrand, here is some great information on it (probably more than you need) posted by our number one Sundstrand go-to guy, @daveoman1966 2 Share this post Link to post Share on other sites
Mike C160 251 #63 Posted June 9, 2022 This transaxle is about a 2.5 hour drive for me to pick up. Havent committed to that yet. Is it just me? Or do i see a broken drive flange and the other flange with 2 locking bolts? Cheers 1 Share this post Link to post Share on other sites
oliver2-44 10,679 #64 Posted June 9, 2022 It sure looks like it has a broken right hub. There is a lot of black on the right axle which might indicate a bad axle seal. A bad axle seal could also indicate a worn bearing. There are several open ports on that pump and motor than could be letting dirt into them. Dirt/grime is a hydros worst enemy. This would make me Leary of that unit. To me, that transaxle looks like one to buy and go through, not one to bolt right on. Im not a hydro pro, so hopefully some others @pfrederi @daveoman1966 will comment on these items. Going through yours with the option of getting some parts from Whx sure seems like a good route to go. 2 1 Share this post Link to post Share on other sites
ebinmaine 72,380 #65 Posted June 9, 2022 3 hours ago, oliver2-44 said: It sure looks like it has a broken right hub. There is a lot of black on the right axle which might indicate a bad axle seal. A bad axle seal could also indicate a worn bearing. There are several open ports on that pump and motor than could be letting dirt into them. Dirt/grime is a hydros worst enemy. This would make me Leary of that unit. To me, that transaxle looks like one to buy and go through, not one to bolt right on. Im not a hydro pro, so hopefully some others @pfrederi @daveoman1966 will comment on these items. Going through yours with the option of getting some parts from Whx sure seems like a good route to go. I'll second that. I'd avoid it if looking for a quick bolt-on repair. 1 Share this post Link to post Share on other sites
pfrederi 18,633 #66 Posted June 9, 2022 I can't view the pictures of your potential purchase... 1 Share this post Link to post Share on other sites
WHX?? 51,690 #67 Posted June 9, 2022 No issues here Paul. That passenger side hub look to be an older "star " type... The two set screws would be the correct one believe I think your decision to open the one you have is the best route. We have parts so the only thing you are lacking is tools. 1 Share this post Link to post Share on other sites
Mike C160 251 #68 Posted June 11, 2022 (edited) A wise man once said; ( @ebinmaine ) Being an automatic, the hubs may very well be removable without extreme effort. I was thinking of an automatic with the old red ATF, not the engine oil such as in this one. ATF is prone to seeping past the seals and is a wonderful penetrant. As it turns out, he was exactly correct. There was enough seal seep that one hub just slid off without any fuss whatsoever while the other side lightly tapped off. Easy peazey Lets see where the rest of the day takes me. Maybe i will get it split. Next is to remove the hydro assy. Lets hope the rain holds off. all its done here is rain. Cheers (yes jack stand = old air conditioner Its all i had that would stop the rockin' and rollin') Edited June 11, 2022 by Mike C160 2 2 Share this post Link to post Share on other sites
Mike C160 251 #69 Posted June 11, 2022 Working in the driveway. Pick up tail gate bench 3 2 1 Share this post Link to post Share on other sites
pfrederi 18,633 #70 Posted June 11, 2022 No matter how long/carefully you drained it as you disassemble it will puke oil on the ground.... 2 Share this post Link to post Share on other sites
Mike C160 251 #71 Posted June 11, 2022 20 minutes ago, pfrederi said: No matter how long/carefully you drained it as you disassemble it will puke oil on the ground.... Yep, I put a pan under it before i split it. I could not get the hydro / motor off the case. All 4 bolts undone and a few gentle love taps with a knock-ometer and it did not wish to split. So I left well enough alone and left it on. Split the case while in the frame. Failures now known. Pictures and report to follow. 2 Share this post Link to post Share on other sites
Mike C160 251 #72 Posted June 11, 2022 Ok :: Damage report. So i got off very lucky. The case, the diff and the mushroom gears are not damaged at all. No serious part failures. Failures - 2 bearings. 1) Left side inner axle bearing 1533 Partial failure / full on failure in progress. 2) Right side mushroom gear needle bearing. 7 Share this post Link to post Share on other sites
ebinmaine 72,380 #73 Posted June 11, 2022 1 hour ago, Mike C160 said: wise man once said; ( @ebinmaine ) @WHX?? Jimbo ya see that?? Oh... I got this poor Mike fella buffaloed ain't I .... Seriously though.... Good to see you tear right into this thing and get the actual issues figured out before a serious mushrooming of catastrophic events. 1 3 Share this post Link to post Share on other sites
ebinmaine 72,380 #74 Posted June 11, 2022 Mike while you've got that thing apart, disassemble the differential to confirm that there are no spare parts, so to speak, in there. Shavings. Pieces of gears. Whatever. Can anybody confirm or deny that this brake pawl is whole or broken? Is this actually a rock? 1 Share this post Link to post Share on other sites
SylvanLakeWH 28,311 #75 Posted June 11, 2022 A Haiku… Confucius wise man @ebinmaine claimed so Consult Colossus 3 Share this post Link to post Share on other sites
