Similar Content
By sjoemie himself
Soo.. yet another idea that floated around in my head for way too long was to build a wheelbarrow with a 'big' wheel.
We're hauling horse manure from several places, some more muddy than others. When doing so with a 'normal' wheelbarrow the frontwheel tends to cut through the mud instead of rolling on top. My idea was to mount a single wide wheel to have more flotation so the wheelbarrow would be easier to push through the mud.
To start things of I convinced my SO to donate her wheelbarrow to the good cause.
This is what I started out with:
Solid, narrow, single wheel. Yes it is crooked because the bearings are gone.
More in next post.
By Rick3478
- SOLD - Moderator may remove at will
0736TL04 tiller and fitments needed to mount on many long frame, C series, 300/400/500 series tractors.
Notable details:
Gearbox and tines have low hours. Tarp had blown off mid-mount idlers and got rusted up, probably need penetrating oil and new idlers.
Axle mount is rusty/restorable/useable. Lift cable has nylon worn through on one side (they tend to do that). One rear jackshaft bushing
has couple ears broke off, and jackshaft e-clips are lost (edit: found those). Belt is original.
Pick up in my back yard near Elida, Ohio. Bring help to load, or ramps or something.
I think it may be worth $100.
- or -
Would consider trade for a used car or truck hood that I can use for a sled to drag firewood and equipment around on, something kinda
rounded without points or ridges to catch. Have been using an S-10 hood for years, and it's wearing through becoming less useable.
What 'cha got?
By Epayne85
Hello all, I have a what I believe is a 36” tiller.
i can get a few pictures of it this afternoon, it rolls freely and appears in very good condition. It’s missing the rear hinge panel. I’m mainly interested in swapping for a box blade and other items depending what you’d have for the clevis or sleeve hitch or I’ll take best offer. Thank you. Also, I have a snow plow and the frame in which someone has modified for I believe an Atv or different tractor I’d be willing to let go for $50 or throw in towards the deal. The blade is in pretty decent shape and the angle mechanism works flawlessly. Again thank you.
edit* I will be able to get pictures Labor Day weekend, sorry for the delay if anyone is interested
By Wheel Horse 3D
Our customized ornaments have a base identical to our version of the original style ornament, but can be topped with 3 different styles of horse head and 3 different styles of wheel! Each is available unfinished, primed, or fully painted.
They also include the pictured mounting hardware and the base spacer for a clean finished look. Can be ordred here https://greystone-3d.square.site/product/customizable-wheelhorse-hood-ornaments/10
