Handy Don 14,633 #26 Posted February 25, 2022 3 minutes ago, JCM said: Right side rear axle looks like she's out a hair past the hub ? EB Maybe we should pull them anyway and replace the seals on this one. Appears to be enough lube on the whole tractor they may slide right off with any luck. Mismatched and missing lugs, too. Look sharp! 1 Share this post Link to post Share on other sites
JCM 10,295 #27 Posted February 25, 2022 @oliver2-44 Exactly, baked on finish when built. 1 Share this post Link to post Share on other sites
ebinmaine 74,531 #28 Posted February 25, 2022 2 minutes ago, Handy Don said: Mismatched and missing lugs, too. Look sharp! We did that when moving it around 1 1 Share this post Link to post Share on other sites
oliver2-44 10,976 #29 Posted February 25, 2022 So I'm going to side track and say am I seeing that ya'll have a turquoise blue panzer blade in that load? Did ya'll get any other panzer stuff? 1 Share this post Link to post Share on other sites
ebinmaine 74,531 #30 Posted February 25, 2022 6 hours ago, oliver2-44 said: any other panzer stuff No sir, that was it. The PO told us a fella had come and picked up some other Panzer things but never come back for that. She figured I'd put it to good use. The plow is bent some but certainly repairable. Likely I'll just sell it the first good opportunity. 1 1 Share this post Link to post Share on other sites
Oldskool 6,666 #31 Posted February 25, 2022 It's going to be a great project. I'll be followin along. 2 Share this post Link to post Share on other sites
Pullstart 68,171 #32 Posted February 25, 2022 12 hours ago, oliver2-44 said: turquoise blue panzer blade good eye on the color! I was curious, then SQUIRREL! happened. 2 Share this post Link to post Share on other sites
oliver2-44 10,976 #33 Posted February 25, 2022 5 hours ago, ebinmaine said: No sir, that was it. The PO told us a fella had come and picked up some other Panzer things but never come back for that. She figured I'd put it to good use. The plow is bent some but certainly repairable. Likely I'll just sell it the first good opportunity. EB if you come across someone heading from Maine to Texas I would be interested....So far away. 2 Share this post Link to post Share on other sites
ebinmaine 74,531 #34 Posted February 25, 2022 21 minutes ago, oliver2-44 said: EB if you come across someone heading from Maine to Texas I would be interested....So far away. Give me a bit here and I'll PM you some pics so you know exactly what you're up against... And then let's see if we can get this figured out. 1 Share this post Link to post Share on other sites
Sparky-(Admin) 23,766 #35 Posted February 25, 2022 At this rate anyone that attends Jims Meet/Greet can show up without a tractor as he’ll have enough to go around. Maybe I won’t have to haul up my truck and loaded trailer…hmmm. Maybe drive my 4 cylinder car (“is that your wife’s car” is how Jim once referred to it ) and save a bunch on fuel 1 3 Share this post Link to post Share on other sites
ebinmaine 74,531 #36 Posted February 25, 2022 4 minutes ago, Sparky said: car (“is that your wife’s car” is how Jim once referred to it Don't feel bad Mike. My daily driver is a "Soul"... It looks like the box it came in. 2 Share this post Link to post Share on other sites
ebinmaine 74,531 #37 Posted February 26, 2022 Here's a pile o pics for our own documentation and your own viewation. 5 1 1 Share this post Link to post Share on other sites
JCM 10,295 #38 Posted February 26, 2022 I am already super impressed with you two hillbillys. Looks like a flanged bearing is in order. 1 3 Share this post Link to post Share on other sites
ebinmaine 74,531 #39 Posted February 27, 2022 1 hour ago, JCM said: Looks like a flanged bearing is in order Yepp. We can start getting a parts list together. We're down to the hydraulic system now... 1 2 Share this post Link to post Share on other sites
ebinmaine 74,531 #41 Posted February 27, 2022 (edited) Folks how's the starter internals look here. It does work. Wasn't noisy. Small bushing good. Large bushing I'm replacing. Brushes have a ton of life left. @squonk @pfrederi @stevasaurus and whoever knows starters can you chime in here ... Note the cracks in the (insulation?) Edited February 27, 2022 by ebinmaine 1 Share this post Link to post Share on other sites
ebinmaine 74,531 #42 Posted February 27, 2022 @JCM Jim was here for a visit today. Between the 3 of us we got more disassembly and cleaning done. The entire steering tower/shifter tunnel is off. Engine tins off and great headway towards cleaning that all out. Grass dirt oil muck. Just. Covered. Wow. Everything. Rest of the starter is torn apart and I began cleanup on that. 4 1 Share this post Link to post Share on other sites
squonk 44,599 #43 Posted February 27, 2022 (edited) I've never seen a starter commutator gooped up like that! I couldn't tell you if that's normal for that starter or not. I'm more used to something like this. Your looks like it got hot and melted! Edited February 27, 2022 by squonk 1 Share this post Link to post Share on other sites
ebinmaine 74,531 #44 Posted February 27, 2022 12 minutes ago, squonk said: starter commutator gooped up The 2 I did just recently were also like that but I don't remember seeing the cracks in those. 1 Share this post Link to post Share on other sites
JCM 10,295 #45 Posted February 27, 2022 I know where we could find 3 more if we need to compare. 3 Share this post Link to post Share on other sites
ebinmaine 74,531 #46 Posted February 27, 2022 17 minutes ago, JCM said: I know where we could find 3 more if we need to compare. Get em up here! Let's do some starter rebuilding Man! 1 1 Share this post Link to post Share on other sites
JCM 10,295 #47 Posted February 27, 2022 This is one that could use your delicate touch, Not going to tell you what model it is . You will have to figure that out for yourself. 2 2 2 Share this post Link to post Share on other sites
SylvanLakeWH 29,313 #48 Posted February 27, 2022 Oohh… chrome… Nice cover… 2 1 Share this post Link to post Share on other sites
ebinmaine 74,531 #49 Posted February 28, 2022 47 minutes ago, JCM said: This is one that could use your delicate touch, Not going to tell you what model it is . You will have to figure that out for yourself. '69 Chevelle??? 3 Share this post Link to post Share on other sites
