19richie66 17,936 #26 Posted March 22, 2022 I knew that spare transmission would be good for something. 2 1 Share this post Link to post Share on other sites
JPWH 6,544 #27 Posted March 22, 2022 @Skipper I have not considered support to the frame as well. I figured I am adding the axle and top of transmission supports as well as using the factory clevis connection point. I am only going to be using garden implements with it. @19richie66 The spare transmission has made this project much easier. 3 Share this post Link to post Share on other sites
stevebo-(Moderator) 8,742 #28 Posted March 23, 2022 I have been here before. I would suggest a linear actuator rather than connect to rock shaft unless you don’t care to use any other attachments with that machine. What you are doing is great work👍 2 1 Share this post Link to post Share on other sites
JPWH 6,544 #29 Posted March 23, 2022 @stevebo Thanks for the suggestion and the compliment. All my attachments will be used on this hitch. I'll have the lift and a fixed receiver to pull my trailers. I thought about moving the hydraulic cylinder like @953 nut did on his project, but this seemed to be the easiest and less expensive way for me. Jay 2 Share this post Link to post Share on other sites
953 nut 69,481 #30 Posted March 23, 2022 The connection from the rock shaft to the three point will need to be very stout. Perhaps some one inch schedule eighty mechanical tubing or some square tubing with a three sixteenth wall. Anything lighter probably will bend over time. Probably want to beef up the extension on the rock shaft too. 2 1 Share this post Link to post Share on other sites
kpinnc 18,972 #31 Posted March 23, 2022 14 hours ago, stevebo said: I would suggest a linear actuator For simplicity, I completely agree. Otherwise the only way to not take away functionality from other implements would be a dual hydraulic spool and second cylinder. Unless you have those items, it can be expensive. An electric actuator can get expensive, but not as much as secondary hydraulics and all those hoses and fittings. 2 Share this post Link to post Share on other sites
Horse Newbie 7,405 #32 Posted March 23, 2022 Yeah… but I’ve seen your set up with the dual hydraulic spool… awesome ! 1 Share this post Link to post Share on other sites
JPWH 6,544 #33 Posted March 23, 2022 7 hours ago, 953 nut said: The connection from the rock shaft to the three point will need to be very stout. Perhaps some one inch schedule eighty mechanical tubing or some square tubing with a three sixteenth wall. Anything lighter probably will bend over time. Probably want to beef up the extension on the rock shaft too. I have 3/4 x3/4 or 1x1 solid square stock, just have to see which one I'll need. Also will reinforce the rock shaft after I test the lift with the hydraulic cylinder. 3 hours ago, kpinnc said: For simplicity, I completely agree. Otherwise the only way to not take away functionality from other implements would be a dual hydraulic spool and second cylinder. Unless you have those items, it can be expensive. An electric actuator can get expensive, but not as much as secondary hydraulics and all those hoses and fittings. Functionality for other implements will not be needed. You are correct about hydraulics being expensive. I built a hydraulic system on my custom 12hp round hood but it was not 3 point. 2 Share this post Link to post Share on other sites
Pullstart 71,291 #34 Posted March 23, 2022 @Skipper keep in mind too that the frames on 953’s, 1054’s and GT14’s have a 3/8” plate bolting to the transmission and a thicker frame as well. The frame is also welded more center of the transmission mount plate than to top, because of the taller wheels. I’m not saying there won’t be stress on the frame, just not as much as what would stress a smaller tractor’s frame. 4 Share this post Link to post Share on other sites
kpinnc 18,972 #35 Posted March 23, 2022 1 hour ago, JPWH said: Functionality for other implements will not be needed. You are correct about hydraulics being expensive. I built a hydraulic system I used a dual-spool valve on my Bronco and cylinder from a D-series. I used the 3-point arms from it as well. I found a local seller who was parting one out for cheap. Otherwise I probably would have gone with a linear actuator. I'm currently toying with a 3-point on a manual tractor. It may get the linear actuator treatment as well. 1 1 Share this post Link to post Share on other sites
JPWH 6,544 #36 Posted March 25, 2022 The last two pieces tacked up and fitted. Even tried the top center link to get an idea for the height of the 3 point to sleeve adapter. Now to make some more bushings and pins and final welding. 3 7 Share this post Link to post Share on other sites
19richie66 17,936 #37 Posted March 25, 2022 You do nice work 👍 1 1 Share this post Link to post Share on other sites
Horse Newbie 7,405 #38 Posted March 26, 2022 8 hours ago, 19richie66 said: You do nice work 👍 1 Share this post Link to post Share on other sites
JPWH 6,544 #39 Posted March 27, 2022 (edited) Made some progress today. I installed the modified rock shaft and tacked up the link from the hydraulic cylinder to the lift. I also tacked the frame together for the sleeve hitch to see what adjustments might be needed. I have a few adjustments to make but it is working. Still a couple hours of final welding to do. Edited March 27, 2022 by JPWH 5 7 Share this post Link to post Share on other sites
JPWH 6,544 #41 Posted March 28, 2022 What would you do? While I was working on the pins and bushings and sort of making up a completion list I realized I had not built in a float mechanism. I think I have an idea but I want to hear your ideas. Jay 1 Share this post Link to post Share on other sites
Pullstart 71,291 #42 Posted March 29, 2022 When plowing, it seems the plow itself will set the depth. However, when I worked on the 3 point for my friend’s kids, it never had a foot no worked just fine. Great work Jay! 3 Share this post Link to post Share on other sites
Tractorhead 9,217 #43 Posted March 29, 2022 Great Work 👍 1 1 Share this post Link to post Share on other sites
Handy Don 17,486 #44 Posted March 29, 2022 This one made me curious so I went to the 'web to do some research! Seems that down pressure is very rare in 3-points and that most use a linkage between the (upper) lift arm and the (lower) drag arm that allows the drag arm to move independently by anywhere from a couple inches (using a slotted link bar or nested pipes/tubes) to a lot (using chains). The discussion was that most rear implements find their own level (plows, harrows, cultivators, moldboards, etc.) and that don't have an operator-controlled "bottom" (trailers being the most commonly cited example). Seems there is also variation on whether the drag arms are interconnected, and by what means, to keep an implement "level" within a set range. Some JDs (and others?) have a rate control that, as near as I can tell, throttles the speed of the lift/drop separately from tryin to feather the control lever. So bottom line to you, @JPWH, seems that you would change the lift-to-drag arm linkage mechanism to suit how you want the attached implement to behave. 1 1 Share this post Link to post Share on other sites
JPWH 6,544 #45 Posted March 29, 2022 Thanks for that suggestion about the pipes @Handy Don. That is better than my idea and I think I have a plan to make it work. Jay 1 Share this post Link to post Share on other sites
Handy Don 17,486 #46 Posted March 30, 2022 (edited) On 3/29/2022 at 6:37 PM, JPWH said: Thanks for that suggestion about the pipes @Handy Don. That is better than my idea and I think I have a plan to make it work. Jay There isn't a "you're most heartily welcome" emoticon. Words will have to do. Edited April 6, 2022 by Handy Don 1 Share this post Link to post Share on other sites
JPWH 6,544 #47 Posted April 5, 2022 (edited) I made some bushings and pins. Jigged these up to keep them aligned and tacked them in place. Aligned the bushings and pins and tacked the bushings in place. Main hitch frame. Edited April 7, 2022 by JPWH 7 2 Share this post Link to post Share on other sites
JPWH 6,544 #48 Posted April 7, 2022 Bottom picture in post #47 shows the frame that bolts to the transmission. Was showing two pictures before editing. Jay 1 Share this post Link to post Share on other sites
19richie66 17,936 #49 Posted April 7, 2022 Nice. 1 1 Share this post Link to post Share on other sites
kpinnc 18,972 #50 Posted April 7, 2022 On 3/23/2022 at 1:34 PM, Horse Newbie said: Yeah… but I’ve seen your set up with the dual hydraulic spool… awesome ! Thanks Tim. I got lucky and it all worked! 2 Share this post Link to post Share on other sites
