Horse Newbie 7,405 #801 Posted February 12, 2022 8 minutes ago, kpinnc said: If they use a tire machine? Not likely. They didn’t even put a scratch on the 520H wheels…this is a large lawn equipment sales and service center… they most likely have a top notch tire machine. 1 Share this post Link to post Share on other sites
Lee1977 7,690 #802 Posted February 12, 2022 I mounted all mine except the 25's on the 312. They had a few problems getting the 25's to seat on the rims they just didn't want to pop out there. The 4 ply 8" can give some trouble but I got them on. 1 Share this post Link to post Share on other sites
Horse Newbie 7,405 #803 Posted February 12, 2022 8 minutes ago, Lee1977 said: I mounted all mine except the 25's on the 312. They had a few problems getting the 25's to seat on the rims they just didn't want to pop out there. The 4 ply 8" can give some trouble but I got them on. You’re a better man than me… I’m tired of fighting tires… Share this post Link to post Share on other sites
Lee1977 7,690 #804 Posted February 12, 2022 15 minutes ago, Horse Newbie said: You’re a better man than me… I’m tired of fighting tires… You're 21 years younger then I am, are you already giving up. 5 Share this post Link to post Share on other sites
Horse Newbie 7,405 #805 Posted February 12, 2022 1 hour ago, Lee1977 said: You're 21 years younger then I am, are you already giving up. I reckon so… I might still give it a shot on wheels that was not freshly powder coated… Share this post Link to post Share on other sites
ebinmaine 79,519 #806 Posted February 12, 2022 Be sure to request/remind them to use proper tire lube. Just in case the installer is new or impatient... The wheels look excellent!! 1 Share this post Link to post Share on other sites
Horse Newbie 7,405 #807 Posted February 12, 2022 At the lawn equipment dealer getting my tires put on the rims…as the mechanic was helping me unload them I asked how much $$$… he said “ Oh a tire repair is $15 plus valve stems at $2.50 a piece. I smiled inside… 15+15+15+15+2.50+2.50+2.50+2.50= $70, add the guvments cut…not too bad I thought. Carried the tires and wheels inside… He asked me to step inside the service department office and have the nice young lady write me up. She filled out the ticket and shoved it towards me to sign… I said “ How much?”, before I signed it… $90.00 she says… See what happens guys?… Guy says 60… not bad… Gal says 90… See what I’m saying ?… they gonna cost you ! But, in reality, throw in the valve stems and tax, and I can see how it would jump up… 4 Share this post Link to post Share on other sites
Horse Newbie 7,405 #808 Posted February 12, 2022 She’s a roller ! 1 7 Share this post Link to post Share on other sites
Horse Newbie 7,405 #809 Posted February 12, 2022 Had my tires put on my rims… a little disturbed that they scratched my wheels a little… the man warned me that they may get scratched. Oh well it’s a tractor, not a trailer queen… Not gonna try to touch them up… that would probably look worse… On the fronts… are those black plastic spindle caps supposed to just snap on the large washer, or slide down on the wheel hub a little ? 3 1 Share this post Link to post Share on other sites
Horse Newbie 7,405 #810 Posted February 12, 2022 May have a little too much toe-in… take a look at these pics… What do you think @ebinmaine, @kpinnc, @Lee1977, @squonk, @WHX??, @Pullstart ? When I push it across the Hot Rod & Custom Restorations Shop floor, it sounds like a new pair of basketball shoes on a basketball court … 1 Share this post Link to post Share on other sites
squonk 47,276 #811 Posted February 12, 2022 that RH side needs to be toed out some 2 Share this post Link to post Share on other sites
SylvanLakeWH 31,669 #812 Posted February 12, 2022 37 minutes ago, Horse Newbie said: On the fronts… are those black plastic spindle caps supposed to just snap on the large washer, or slide down on the wheel hub a little ? Mine touch the wheel… 1 Share this post Link to post Share on other sites
Lee1977 7,690 #813 Posted February 12, 2022 (edited) The tires should toe in 1/8" to max 1/4". The new tires with sharp edges are going to make noise on that slick floor until they get worn a little. Doesn't look that far off is the steering wheel centered. That's usually the hard part of getting the toe in right. Edited February 13, 2022 by Lee1977 2 Share this post Link to post Share on other sites
Horse Newbie 7,405 #814 Posted February 13, 2022 3 hours ago, squonk said: that RH side needs to be toed out some I’m thinking adjust both sides so that I sorta do both, instead of a “big” adjustment on one side only. 1 Share this post Link to post Share on other sites
ebinmaine 79,519 #815 Posted February 13, 2022 Just now, Horse Newbie said: I’m thinking adjust both sides so that I sorta do both, instead of a “big” adjustment on one side only. Center the steering wheel and the underside flag of the steering system. Then adjust each side as needed. 2 1 Share this post Link to post Share on other sites
Jeff-C175 7,209 #816 Posted February 13, 2022 3 minutes ago, ebinmaine said: Center the steering wheel and the underside flag of the steering system. Then adjust each side as needed. If you don't center the wheel before adjusting you will steer more in one direction than the other. NASCAR anyone? 1 1 Share this post Link to post Share on other sites
Horse Newbie 7,405 #817 Posted February 13, 2022 2 hours ago, Lee1977 said: The tires should toe in 1/8" to max 1/4". The new tires with sharp edges are going to make noise on that slick floor until they get worn a little. Doesn't look that far off is the steering wheel centered. That's usually the hard part of getting the tor in right. When I was first reinstalling the steering, I tried to get the “spokes” in the steering wheel centered when the wheels were straight, but… I would go one gear tooth one way and it would be off… one gear tooth the other way and it would be off… So I had to settle with the spokes not centered on the steering wheel like a “Y”. But I definitely need to adjust that toe in. I could tell one front wheel was fighting the other, even considering the new tires being “sticky” on the epoxy floor. Share this post Link to post Share on other sites
Horse Newbie 7,405 #818 Posted February 13, 2022 5 minutes ago, ebinmaine said: Center the steering wheel and the underside flag of the steering system. Then adjust each side as needed. That’s what I did @ebinmaine… I just gave it a “big” toe ! Share this post Link to post Share on other sites
Horse Newbie 7,405 #819 Posted February 13, 2022 (edited) 5 minutes ago, Jeff-C175 said: If you don't center the wheel before adjusting you will steer more in one direction than the other. NASCAR anyone? If I want to turn left real good, I’ll just run a lower air pressure in the left side tires to reduce the circumference of the left tires… I learned that trick when I ran on the “Outlaw” circuit… I wouldn’t lie… Edited February 13, 2022 by Horse Newbie 1 2 Share this post Link to post Share on other sites
kpinnc 18,723 #820 Posted February 13, 2022 4 hours ago, Horse Newbie said: She’s a roller ! She looks great! Those ag tires locked up nicely! 4 hours ago, Horse Newbie said: Not gonna try to touch them up… that would probably look worse… I would touch them up. You do not want raw steel exposed with powder coat, trust me. Just get yourself a little fine brush (model kit stuff at wally world), and a white can of Rust-Oleum. Spray a little in the cap and dip the fine brush in it. Dab it in the center of the scratch. Capillary action will draw it into the scratch, and even if it looks like a blob it will shrink as it dries. Several of my tractors have touch ups like that, and it works well. 3 Share this post Link to post Share on other sites
Horse Newbie 7,405 #821 Posted February 13, 2022 38 minutes ago, kpinnc said: would touch them up. You do not want raw steel exposed with powder coat, trust me. Thanks… will do ! Share this post Link to post Share on other sites
Lee1977 7,690 #822 Posted February 13, 2022 If you can't get the steering wheel line up. most likely the triangle was off center when it was welded. We have seen them way off, the welded must have came in on Monday with a hang-over. 2 1 Share this post Link to post Share on other sites
Stormin 9,988 #823 Posted February 13, 2022 6 hours ago, Lee1977 said: If you can't get the steering wheel line up. most likely the triangle was off center when it was welded. We have seen them way off, the welded must have came in on Monday with a hang-over. My C-125 is like that. 1 Share this post Link to post Share on other sites
SylvanLakeWH 31,669 #824 Posted February 13, 2022 (edited) Just an observation @Horse Newbie, your page count on this thread is catching up with @ebinmaine’s Colossus build thread… people are gonna start to talk… and then you’ll need to make up sunset threads, wood chopping threads, gardening threads and such to divert attention… Make wise choices… Edited February 13, 2022 by SylvanLakeWH 9 Share this post Link to post Share on other sites
Stormin 9,988 #825 Posted February 13, 2022 5 hours ago, SylvanLakeWH said: Just an observation @Horse Newbie, your page count on this thread is catching up with @ebinmaine’s Colossus build thread… Catching up!! He'll be well past and up and running long before Colossus. 1 2 Share this post Link to post Share on other sites
