Countdown To Christmas!
Maxwell-8
I don't have any shop-time on coming three weeks so I am getting all my supplies needed ready.
Already got some engine oil SAE30 and tranny oil castrol 10W40
Planning on ordering new axle seals: 6449
A C-175 uses Par36 headlights as well right?
How many usable charging amps does a Kohler M16 produce? Because I want some brighter lights but still remain the old incandescent/halogeen bulb look.
Hope to not be needing a carb rebuild kit for once as they are 60$ at the dealer
Thanks for your input
Edited by Maxwell-8
ebinmaine
23 minutes ago, Maxwell-8 said:
dealer
No other good source like online or local repair shops?
  • Thanks 1
Maxwell-8
Online I can find stuff, mostly in Brittain, but with shipping costs and customs, I am looking at the same price. Nobody know here what a "Kohler" is, so no local dealers.
Maybe an the german Ebay...:eusa-think:
Damien Walker
Thanks for your
  The M series (and the K series as far as I am aware, all used the same generator hardware, giving 1.25, 3 or 15A depending upon which engine option was selected. If it is the original engine it should be 15A. You can easily tell if you take the flywheel off and look at the generator windings....the lower current versions don't have a complete symmetrical ring of coils whereas the 15A version does.
I've just fitted 12W led PAR36 lamps to my 518H and they work well, and at much less current. 12W means approx 1A each rather than the usual 30W @ approx 3A. LEDs are a bit more expensive but worth it I think...brighter too!
  • Thanks 1
ebinmaine
3 minutes ago, Damien Walker said:
12W led PAR36
Have to agree that led is the way to go on a tractor that will be working.
Brighter, whiter light. Most last longer. Less energy use as mentioned. And they run cooler which is great for the close quarters that a lot of garden tractors have.
  • Thanks 1
Maxwell-8
It is not the original engine, I even think it has only a couple of minutes on the C-175 chassis, as I it appears they made a wiring mistake after the engine swap, and blew the battery pretty much immediately. So I will have to take a look behind the flywheel. Is there a way I can measure the amps? Just with my multimeter on the amps setting?
Damien Walker
Oh yes good point, a C175 should have a KT17 twin.
Yes you can measure your amps using your multimeter on the amps setting but you need to connect it in series with a load and set your multimeter max range to greater than the load (e.g. load is 6A, multimeter set to 10A range). If the generator is only capable of 3A....that should be all you get (or thereabouts) with a 6A load. If it is a 15A machine you'll get 6A on the meter. Original headlamps would be a good load....roughly 3A each.
If you are not familiar with measuring current, you can easily blow your meter so I can send you a connection diagram if that would help...let me know!
  • Thanks 1
Maxwell-8
I know how it should be done, just never done it because i was afraid of blowing my meter, just wondered if it can be done. Will use a cheapo meter I have laying around here capable of 15-20 amps I believe.
Damien Walker
Ok well good luck! Just make sure the meter is capable of more current than the load and NEVER put the meter directly across the generator as you would with a volt meter. You also probably shouldn't run the engine with no load on the generator....the voltage can go sky high and damage the regulator. If the battery is connected, that's fine for the generator but you'll need to be sure the battery isn't powering the load when you do your test!
The procedure then probably should be:
1) Connect battery and start engine
2) Connect multimeter (on amps range) to load (e.g. connect multi meter in series and switch lights on)
3) Disconnect battery (engine running)
4) Measure current
5) Stop engine
6) Disconnect load
You can also check your generator with your multimeter set to volts.... which is safer. Just measure the voltage across the load. If the load is greater than generator can supply, the voltage across the load will not reach 12-14V.
At a quick guess: if you use two par36 head lamps taking 60Watts in total, that will give you a load of 5 Amps and the voltage should be 12-14V.
If the generator is only capable of 1.25A, (ie 1/4 of what the lamps need), you'll probably only see around 1/4 of the volts...roughly 3-4V.
Multimeters usually have a fuse inside to protect them from fools misusing the current range. If it stops working, you may have blown the fuse....which is quite a common occurrence here!
Apologies if you already know all this.
  • Excellent 1
  • Thanks 1
Maxwell-8
4) Measure current
5) Stop engine
6) Disconnect load
Thanks Damien, that is some strait up good info, I can surely work with.  probably going the voltage-methode
Edited by Maxwell-8
Gregor
Par 36 is what I ordered for mine. LED.
211623935_Screenshot_2021-05-28TP-2203-A-TP-2203-A_M8_M10_M12_M14_M16_DATE5_04pdf.png.c5b46aef6b4c0e1fc544b6dc963c2c35.png
Should have made it just a bit bigger.
1328335075_Screenshot_2021-05-28TP-2203-A-TP-2203-A_M8_M10_M12_M14_M16_DATE5_04pdf(1).png.f49b4377272b7464ad64f2c6e5978a35.png
Edited by Gregor
  • Thanks 1
ebinmaine
@Maxwell-8
Do you have any numbers off the engine itself?
Maxwell-8
2 minutes ago, ebinmaine said:
@Maxwell-8
Not at the moment sir, I will write them down as soon as I can.  Many thanks for your inputs
Maxwell-8
Had 5 minutes time to work on Amy. Took the plastic fender off ( that thing just shatterd in my hands) and replaced it with a metal seatpan of the parts 312. (not much left on that pre-toro 312 parts tractor, already kept 2 blackhood's, a 314  and another 312 going.)
Found out she has a loose hub on the right side.
removed some remaining wire. All the wiring was 'twist and taped', no wonder it blew the battery.
The Kohler model no is 711502. Any ideas on the charging amps? it has an rectifier-regulator.
Thanks in advance
Maxwell
Edited by Maxwell-8
ebinmaine
Might be able to access a spec sheet showing the amperage output.
Maxwell-8
Had a little bit of spare time today, so I ran to the shop.
Out with the plastic fender DSC_1070.JPG.69f47f5c6cb79f5149a6231d60a8f1cd.JPG
I got me a metal pan, but that needs repainting bad DSC_1079.JPG.4d3265d56270a9a3cebb235551409751.JPG
I found I had these nice brackets on the tranny. Those are for a tiller not?
Edited by Maxwell-8
Gregor
I have the same brackets on my 125. I thought they were for a snow plow, but I have no idea really.
  • Thanks 1
SylvanLakeWH
Brackets - They are for a front blade…
  • Thanks 1
Damien Walker
They are for both tiller and snow plow. If you get the opportunity to buy the equivalent from the later shape 520 (pressed steel chassis and shaft drive) it is even more versatile.
  • Thanks 1
Maxwell-8
3 hours ago, Thor27 said:
I suspect you may have an installed height problem, that "appears" to be a big base pan.  You may be able to eliminate the shaker plate, a good thing imho..
https://www.wheelhorseforum.com/topic/44945-identifying-big-block-kohler-block-styles/
Thanks, the engine looks like it's sitting high, and thanks to the article you linked, I can say it's a big block base pan. Rubbers on the shaker plate are pretty bad, and since I can't get new bushings here. She is going strait on the frame.
Many thanks for pointing that out!
Maxwell-8
Folks, we got ourself another lose/worn hub.
She moves a bit up and down. but could not get her off by hand, and had to use a puller
The setscrews were not original so I might try reuse the hub with new, good set screws. Axle seals should get in upcoming week.
Edited by Maxwell-8
ebinmaine
Cup type set screws should really only be reused a few times.
The end of the cup where it actually does the grabbing is sacrificial.
Good idea for you to replace those.
Check the axle surface to make sure there's a flat spot to "catch" the second set screw. I can't tell from the pics.
  • Thanks 1
  • Similar Content
    • Thatoneguy
      By Thatoneguy
      So I washed my rear end and sundstrand 90-1136 and now the by pass valves leaks when I screw it in past a certain point.  If I screw it all the way in I can sit there and watch the fluid start seeping past it.   I changed the o-ring with an R-04 i believe is what it was.   Do these require some sort of thread sealer? There was nothing on it when I took it out, and when I used the valve to push the tractor in my shop it worked fine and has never leaked. Any ideas would be wonderful!
    • D_Mac
      By D_Mac
      Well fellas I may be going to the dark side. Going to look at one tomorrow. You know the story, ran a couple years ago when parked. Now no spark. Has mower deck with new blades and belt. Tires have new tubes. Has the plastic rear fenders/ seat pan that's busted up. I have no experience with the kohler twin. I know you like pictures but don't have any. Any helpful suggestions on what I need to look at tomorrow? Any idea what a replacement metal seat pan / rear fender unit will run? Worth ? I'd like to save it but really don't have the room for another but that's never stopped me before. Like to hear all your input. Thanks
    • mattd860
      By mattd860
      I have developed a kit that allows a Wheel Horse / Toro hydrostatic tractor to be operated by a pedal on the right side of the tractor. The original forward/reverse lever can be retained or removed. The kit includes everything needed to install the pedal kit and installation is simple with the help of a downloadable installation manual. Additionally, only one (1) 1/4" hole will need to be drilled which can be done by a hand drill. No other drilling or cutting will be necessary. Any tractor with this kit can be converted back to stock without any visible evidence that kit was installed. However, you'll never want to do that
      The foot pedal is custom cast in Aluminum, uses brass bushings to minimize wear, and it closely matches the OEM Wheel Horse BRAKE pedal commonly found on 8-speed manual transmission tractors. Modifications were done to the pedal to add the reverse pedal and adapt the pedal to the rest of the kit. For the most part, the pedal looks like it was designed and manufactured by Wheel Horse / Toro. Additionally, a grease fitting has been adapted to the pedal to further minimize wear and tear and if the brass bushings ever wear out they are fully replaceable without having to buy a whole new pedal.
      Here is a link where you can download the installation manual: CLICK HERE
      I am selling these kits for $330 shipped to anywhere in the United States. I offer multi order discounts as well. I will also sell to other countries for additional shipping charges to be determined.
      Thanks!
    • olivertractor
      By olivertractor
      I was pulling a roller and thatch rake the other day with my c120 hydro and noticed oil on the back of the fender. On looking closer I saw the plug thing on the back of the pump leaking oil. Any advice on how serious this will be to repair? Anything helps
    • Bill D
      By Bill D
      I bought this K341 and was wondering what it came on originally.  It's a 13 fin block and has been bored .020 over already.  It has a Kohler carb which may not be original.  Bill
