cat man 137 #1 Posted April 6, 2021 ok so i got my C-120 home and it needed a good preasure washing i then greesed all the fittings no i want to change the oil in the 12hp motor and the oil and filter in the rear end so its a 1973 how much oil in the motor will i need and how much and what kind in my automatic rear end and would anyone know what the filter number on the rear end is thanks 2 Share this post Link to post Share on other sites
cat man 137 #2 Posted April 6, 2021 ok so i got my C-120 home and it needed a good preasure washing i then greesed all the fittings no i want to change the oil in the 12hp motor and the oil and filter in the rear end so its a 1973 how much oil in the motor will i need and how much and what kind in my automatic rear end and would anyone know what the filter number on the rear end is thanks 2 1 Share this post Link to post Share on other sites
ebinmaine 78,271 #3 Posted April 6, 2021 From another trucker... Engine oil should be straight 30. Brand is as personal as anything. I use Kinetix and order it online by the case. Price is good. It has the appropriate amounts of zinc phosphate in it for older engines. I can send a link if your interested. Transmission filter should be Wix 51410 or Napa 1410. Fram is not preferred. Transmission fluid in a '73 is likely engine oil. Perhaps @953 nut or @pfrederi could help there. 1 Share this post Link to post Share on other sites
rjg854 12,954 #4 Posted April 6, 2021 (edited) easy to check which transmission oil you have, if it's red it's automatic transmission oil if it's tan it's regular oil don't switch from one to the other, always use what you drain out Edited April 6, 2021 by rjg854 add 1 Share this post Link to post Share on other sites
The Tuul Crib 7,354 #5 Posted April 6, 2021 (edited) T😎 Good lookin tractor! The motor oil l use is rotella 30w w T1 .The trans filter wix 1410 you can get at NAPA. Check the color of your trans fluid if it's Amber use 10W30 if it's pinkish color use ATF. Dex Merc you can also get at NAPA.Dont mix what is in the trans. Edited April 6, 2021 by The Tuul Crib 2 1 Share this post Link to post Share on other sites
ebinmaine 78,271 #6 Posted April 6, 2021 24 minutes ago, rjg854 said: regular oil Viscosity.... 10W30? 1 Share this post Link to post Share on other sites
WHX?? 56,061 #7 Posted April 6, 2021 Cat Yes 10w30. Some guys prefer synthetic for best cold weather performance. Some guys also stick with the OEM filters Part# 79-5270 or 5990 I just use the NAPA in all of mine. 1 Share this post Link to post Share on other sites
squonk 46,098 #8 Posted April 6, 2021 Napa 1410 filter. I use Mobil 1 10w40 1 1 Share this post Link to post Share on other sites
Ed Kennell 45,733 #9 Posted April 6, 2021 Tractor 1974 C-120 Auto OM Wiring Revised.pdf - 1973-1977 - RedSquare Wheel Horse Forum 1 Share this post Link to post Share on other sites
Achto 31,541 #10 Posted April 6, 2021 Looks like the gang has you covered. So I'll just say 1 1 Share this post Link to post Share on other sites
WHX?? 56,061 #11 Posted April 6, 2021 Might want to check some other things we always do on a new to us. Air filter, fuel lines & filter, electrical connections, lube cables etc. Check the manual Ed has posted for other maintenance. We also have repair manuals for the transmission and engine if needed. 1 Share this post Link to post Share on other sites
cat man 137 #12 Posted April 6, 2021 3 hours ago, ebinmaine said: From another trucker... Engine oil should be straight 30. Brand is as personal as anything. I use Kinetix and order it online by the case. Price is good. It has the appropriate amounts of zinc phosphate in it for older engines. I can send a link if your interested. Transmission filter should be Wix 51410 or Napa 1410. Fram is not preferred. Transmission fluid in a '73 is likely engine oil. Perhaps @953 nut or @pfrederi could help there. 1 Share this post Link to post Share on other sites
cat man 137 #13 Posted April 6, 2021 thanks so much and yes send me a link please mine also came with a snow blade but im not sure if it is all there or not till i try to put it on thanks again 1 Share this post Link to post Share on other sites
ebinmaine 78,271 #14 Posted April 6, 2021 2 minutes ago, cat man said: thanks so much and yes send me a link please mine also came with a snow blade but im not sure if it is all there or not till i try to put it on thanks again Will do. You're welcome. I'll get it to you later on today. Post a pic of what you have for the snow blade and we'll tell you if everything is there 1 Share this post Link to post Share on other sites
WHX?? 56,061 #15 Posted April 6, 2021 Just now, ebinmaine said: snow blade and we'll tell you if everything is there If it's a blade we'll have the IPL for that too. 1 1 Share this post Link to post Share on other sites
cat man 137 #16 Posted April 6, 2021 my uncle bob had them when i was growing up he mowed with his and also pulled with it at his co. fair Share this post Link to post Share on other sites
cat man 137 #17 Posted April 6, 2021 thanks everyone as a army vet. and a disabled biker from a crash im glad to have a place for help and new friends 2 5 1 Share this post Link to post Share on other sites
Pullstart 69,643 #18 Posted April 6, 2021 2 hours ago, cat man said: thanks everyone as a army vet. and a disabled biker from a crash im glad to have a place for help and new friends Thank you for your service! @nylyon should be able to update your avatar with the Army insignia. Sorry to hear of your crash, I just got home from an 80 mile trip for some supplies... 1 Share this post Link to post Share on other sites
ebinmaine 78,271 #19 Posted April 6, 2021 2 hours ago, cat man said: new friends We're glad to have you but we might be a bad influence 1 5 Share this post Link to post Share on other sites
cat man 137 #20 Posted April 6, 2021 1 hour ago, pullstart said: Thank you for your service! @nylyon should be able to update your avatar with the Army insignia. Sorry to hear of your crash, I just got home from an 80 mile trip for some supplies... Share this post Link to post Share on other sites
cat man 137 #21 Posted April 6, 2021 this is my last ride 02 harley road king 6 speed gear driven cams 1 2 1 Share this post Link to post Share on other sites
cat man 137 #22 Posted April 6, 2021 8 hours ago, ebinmaine said: From another trucker... Engine oil should be straight 30. Brand is as personal as anything. I use Kinetix and order it online by the case. Price is good. It has the appropriate amounts of zinc phosphate in it for older engines. I can send a link if your interested. Transmission filter should be Wix 51410 or Napa 1410. Fram is not preferred. Transmission fluid in a '73 is likely engine oil. Perhaps @953 nut or @pfrederi could help there. Share this post Link to post Share on other sites
cat man 137 #23 Posted April 6, 2021 do you no how much oil i need for each one motor and rear end? Share this post Link to post Share on other sites
ebinmaine 78,271 #24 Posted April 6, 2021 7 minutes ago, cat man said: do you no how much oil i need for each one motor and rear end? Engine is 1.5 or 2 quarts I think. Transmission I'm not sure but I want to say about five quarts. May want to confirm with others but I don't think the transmission needs to be anything special for oil usage 1 Share this post Link to post Share on other sites
The Tuul Crib 7,354 #25 Posted April 6, 2021 The sunstrand holds at least five yes. I may have put a half quart more after filter 1 1 Share this post Link to post Share on other sites
