Wheel Horse 3D
Custom 3d printed badges, ornaments etc.
Wheel Horse 3D
54 minutes ago, oliver2-44 said:
@Wheel Horse 3D If these tanks work out,  the tanks for the WH Suburbans and RJ’s should be next on your list.  Used ones are selling for over $100 on Evil Bay and are usually so rusty you have to seal them. The Suburban and RJ tank are the same size and shape, but inlet and outlet are in slightly different locations. Also they are a lot smaller,   I’ll try to find some pictures.
Unfortunately the long print times on these won't allow them to be uber inexpensive, but judging from the weight of the tombstones and how hefty they are, the final product should be very heavy and durable. If I recall, the suburbans and RJ's shouldn't be nearly as large and heavy, so hopefully we can get those down to a more reasonable price. I'll be doing all tanks in a gray color as it is much less expensive and easy to paint.
Edited by Wheel Horse 3D
oliver2-44
@Wheel Horse 3D
There are lots of ideas of things you could make for our Wheel Horses.
Is there a filament that would make good replacement rubber engine mounts?
Something that would be firmer than the rubber, but maybe absorb a little vibration better that the solid mounts.
Could they be made at a lesser cost that Zacks $45 solid steel mounts?
https://www.zkbrmachine.com/product-detail/wheel-horse-solid-engine-mounts-pt-num-1099--551
Wheel Horse 3D
8 hours ago, oliver2-44 said:
@Wheel Horse 3D
Replacement rubber engine mounts?
Ya know that's a great idea. I had been wanting to eliminate the shaker mounts on Dug due to too much flex and my brain was fixated in machined ones, but I dont know why good solid plastic ones wouldnt work.
sjoemie himself
On 11/27/2023 at 6:26 PM, oliver2-44 said:
@Wheel Horse 3D
Seems to be a hot topic these engine mounts.
Here's what I made for my 512-D. Made from polyurethane and scrap steel.
More durable and a bit harder than rubber but more forgiving than solid mounts.
  • Excellent 7
Wheel Horse 3D
A collection if custom ordered grandkid stuff!
  • Heart 3
ebinmaine
Stitch!!
Wheel Horse 3D
Tombstone headed across the pond!
  • Excellent 5
gt14rider
How does one got on your site? Won't let me sign in. @Wheel Horse 3D
Edited by gt14rider
Wheel Horse 3D
Sent ya a message!
953 nut
:text-coolphotos:        If you have any plans to make a dinosaur i bet a big kid like @stevasaurus would like to have one to add to his collection.      :handgestures-thumbupright:
  • Haha 1
Wheel Horse 3D
The Smithsonian actually had a bunch of 3d files of different dinosaur dinosaur bones. Always wanted a custom painted Sinclair concrete dino out in the yard. Spent some time in Utah for work out by Dinosaur National Monument very cool! Wish I'd have scanned a bunch of stuff.
Achto
For some reason I have developed a liking towards Sinclair memorabilia. Have a fair collection of tin signs, hats, etc. A bit weird considering Wisconsin does not have any Sinclair stations.
Neighbor has an 8ft concrete Sinclair dino, kinda jealous. :D
Edited by Achto
Wheel Horse 3D
Engine mounts modeled! This is of course to eliminate the rubber shaker mount. It'll have a little flex  but not much. We could find a nice 3/8 ID hose to put in the center and expand our center hole to accommodate.
Wheel Horse 3D
First gt 14 tank bottom half! About halfway done.
  • Excellent 2
8ntruck
What kind of joint between the tank halves are you planning on?  Half lap?
Wheel Horse 3D
Pretty much. I added an inside rib that sticks up above the joint. The top then nests down onto the base.
  • Like 4
  • Excellent 2
Wheel Horse 3D
Still going!
  • Excellent 2
gt14rider
How many hours pur tank?
8ntruck
Mucho mas, lots and lots and lots.
Wheel Horse 3D
To this point machine says 3d 6h 42min
  • Confused 1
Wheel Horse 3D
Ok bottom done! Top starting!
  • Excellent 4
Wheel Horse 3D
And you thought watching paint dry was fun!...1 day later.
  • Haha 3
Wheel Horse 3D
I did make one change to the bottom. I shifted the outlet down a little more. So future bottoms the hole is right down level with the inside bottom surface.
8ntruck
Just out of curiosity, have you filled the bottom half of the tank with water to check for leaks?
This was a few years back, but a couple of the younger engineers at work made a print with maybe 20% infill.  When it was done, they mixed up some resin and poured it into an opening they had left in the print.  There were enough leaks that they had a had a real mess on their hands, and table, and floor......
Wheel Horse 3D
Lol. I haven't checked yet. This was done at 100 percent infill, but I would still recommend a tank sealer. Just knowing how these layers lay down even with extra wall layers etc.i'd still use a tank sealer.
  • Similar Content
    • sjoemie himself
      By sjoemie himself
      Soo.. yet another idea that floated around in my head for way too long was to build a wheelbarrow with a 'big' wheel.
      We're hauling horse manure from several places, some more muddy than others. When doing so with a 'normal' wheelbarrow the frontwheel tends to cut through the mud instead of rolling on top. My idea was to mount a single wide wheel to have more flotation so the wheelbarrow would be easier to push through the mud.
      To start things of I convinced my SO to donate her wheelbarrow to the good cause.
      This is what I started out with:
      Solid, narrow, single wheel. Yes it is crooked because the bearings are gone.
      More in next post.
    • Donavon1
      By Donavon1
      Project black Betty the diesel 1054
    • Wheel Horse 3D
      By Wheel Horse 3D
      Our customized ornaments have a base identical to our version of the original style ornament, but can be topped with 3 different styles of horse head and 3 different styles of wheel! Each is available unfinished, primed, or fully painted.
      They also include the pictured mounting hardware and the base spacer for a clean finished look. Can be ordred here https://greystone-3d.square.site/product/customizable-wheelhorse-hood-ornaments/10
    • Wheel Horse 3D
      By Wheel Horse 3D
      Welcome, and thanks for visiting our vendor area.
      We got our start in 3D printing for customers right here on Red Square!
      If you'd like to see how every thing gets developed and the contributions of Red Square members, please visit the thread that started it all and browse through our progress to date.
      We love our clients' input and work closely to turn ideas into reality. If you have an idea, request, or questions, you can post to that thread, message us or tag us here on Red Square, or visit our online store and reach out to us through there.
      Https://greystone-3d.square.site
