Pullstart 70,447 #101 Posted January 12, 2021 (edited) @OldWorkHorse @AMC RULES here is the build for Rylee’s “Screamin’ Jimmy”. The pipes are functional and it has a muffler too. I decided her ears don’t have to suffer for it to look cool. She truly learned to weld for this project. Even though I helped finish many, many joints, she was there in the shop helping! Edit... WRONG THREAD! try this one... Screamin’ Jimmy Edited January 12, 2021 by pullstart 2 1 Share this post Link to post Share on other sites
OldWorkHorse 3,153 #102 Posted January 12, 2021 I think I just said the other day I'll order all that header pipe and end up just going with a stack that's awesome your kids are into helping work on the projects. I know as soon as my little one is old enough I'll be bringing her right into the shop with me. Never a bad thing to know what tools are and how to use them! Awesome work again! 2 1 Share this post Link to post Share on other sites
Pullstart 70,447 #103 Posted January 13, 2021 We took a trail ride of a different sort today... with a tow behind snowmobile sled. 1 2 2 Share this post Link to post Share on other sites
Maxwell-8 4,371 #104 Posted January 13, 2021 1 minute ago, pullstart said: We took a trail ride of a different sort today... with a tow behind snowmobile sled. Just lovely! 2 minutes ago, pullstart said: She is enjoying it! 1 Share this post Link to post Share on other sites
Pullstart 70,447 #105 Posted January 13, 2021 1 minute ago, Maxwell-8 said: Just lovely! She is enjoying it! They both love a good tractor ride! 2 Share this post Link to post Share on other sites
BeninCT 451 #106 Posted January 13, 2021 @pullstart just went through this what a great story. Beautiful family you have too. Lucky man. 1 1 Share this post Link to post Share on other sites
Pullstart 70,447 #107 Posted January 13, 2021 59 minutes ago, BeninCT said: @pullstart just went through this what a great story. Beautiful family you have too. Lucky man. Thank you, it was a great adventure and you’re right I am a lucky man! 1 Share this post Link to post Share on other sites
Pullstart 70,447 #109 Posted July 11, 2021 A HUGE thanks to Rob @oldiron613 for some carb advice this weekend... he tweaked “Jackie’s” carb and got the little hiccup out of it... then suggested a 1/4 turn more fuel on the Senior. Now, they are both one pull cold/no choke runners! 4 4 Share this post Link to post Share on other sites
953 nut 67,240 #110 Posted July 12, 2021 OK Kevin, so what is the next project? Looks sorta like a Model A Ford front axle there, you holding out on us. Share this post Link to post Share on other sites
Pullstart 70,447 #111 Posted July 12, 2021 14 minutes ago, 953 nut said: OK Kevin, so what is the next project? Looks sorta like a Model A Ford front axle there, you holding out on us. Spare parts $10 for the pair at auction, now I have a spare differential, lever steer handle, and maybe tie rods too. I get to kind of reverse engineer things to see if more than just transmissions and rear ends were scavenged 5 Share this post Link to post Share on other sites
Pullstart 70,447 #112 Posted April 28, 2022 I entered this machine into Steiner Tractor’s photo contest. Here’s a link to the contest.. http://wshe.es/IwZAsBnK 4 7 Share this post Link to post Share on other sites
WHX?? 57,278 #113 Posted April 29, 2022 You might have a shot. Had mine out last weekend... second pull after long winter nap. 2 5 Share this post Link to post Share on other sites
Pullstart 70,447 #114 Posted August 5, 2022 Momma’s got some brand new shoes! 4 Share this post Link to post Share on other sites
Pullstart 70,447 #115 Posted August 6, 2022 I want to thank @Wild Bill in VA for the guidance in this next step! I decided to e-tank the front wheels and repaint them inside and out. The rears will be cleaned, sanded, high build primered and block sanded, then primed and painted to match. I was hung up on how in the world to pull that pretty much flush mounted cap without wrecking it. To quote Bill, he said “ What you're going to have to do to remove the bearing cap is take a metal putty knife (or scraper whatever you call it) and tap the blade in between the wheel and cap and work the blade all the way around till it comes out. Remember the cap is thin but malleable and can be formed back into shape .... but don't hit it too hard.” Here’s what we’re up against: 4 Share this post Link to post Share on other sites
Pullstart 70,447 #116 Posted August 6, 2022 The caps are basically inverted automotive freeze plugs. They need to be tapped in on one side to rotate the other side out! Share this post Link to post Share on other sites
Handy Don 16,917 #117 Posted August 6, 2022 23 minutes ago, Pullstart said: Here’s what we’re up against: While tapping away carefully from the back edge with a thin, blunt tool, a gentle persuasion using a belt-style oil filter removal tool wrapped around the outermost end would give you a way to apply some twist at the same time 1 Share this post Link to post Share on other sites
Pullstart 70,447 #118 Posted August 6, 2022 Before assembling, I’ll give the front end the ole’ Greasy Pete and clean/repack the bearings too. @peter lena you’d be proud, I even found some vertical slop in the right side spindle I can shim out! 2 1 Share this post Link to post Share on other sites
Pullstart 70,447 #119 Posted August 6, 2022 2 minutes ago, Handy Don said: While tapping away carefully from the back edge with a thin, blunt tool, a gentle persuasion using a belt-style oil filter removal tool wrapped around the outermost end would give you a way to apply some twist at the same time There’s no back edge to speak of… but both sides are apart, cleaned and ready for fresh reassembly! 1 Share this post Link to post Share on other sites
Handy Don 16,917 #120 Posted August 6, 2022 Just now, Pullstart said: There’s no back edge to speak of… but both sides are apart, cleaned and ready for fresh reassembly! Seeing it disassembled, I realize that the cap is inset into the hub. What were they thinking?! Nice job getting it out! 1 1 Share this post Link to post Share on other sites
Pullstart 70,447 #121 Posted August 6, 2022 1 minute ago, Handy Don said: What were they thinking?! Simplicity, strength and longevity apparently 3 Share this post Link to post Share on other sites
Pullstart 70,447 #122 Posted August 6, 2022 (edited) Found the E-tank! Remember when setting up an electrolysis tank, keep your cookin’s in a well ventilated space (outside) and polarity matters! Always keep your anodes POSITIVELY charged to PULL the garbage away from the NEGATIVE charge! Edited August 6, 2022 by Pullstart Details 2 Share this post Link to post Share on other sites
ineedanother 2,523 #123 Posted August 7, 2022 3 hours ago, Pullstart said: Found the E-tank! I have to say, those are the BIGGEST anodes I've ever seen in an e-tank 1 Share this post Link to post Share on other sites
stevebo-(Moderator) 8,735 #124 Posted August 7, 2022 Glade to see you got them done. You gonna paint them red like were originally or go with white? Now you know you need to do the back wheels right? 1 Share this post Link to post Share on other sites
Pullstart 70,447 #125 Posted August 7, 2022 6 minutes ago, stevebo said: Glade to see you got them done. You gonna paint them red like were originally or go with white? Now you know you need to do the back wheels right? I’m going to keep the color. Though red is correct, the Antique White wheels tell a story of it’s late 70’s restoration at a dealership in northern Indiana. 3 Share this post Link to post Share on other sites
