Greentored 3,220 #1 Posted May 6, 2020 Lets have some fun eh? If you could build your ultimate Horse, what frame, engine, trans, hitch, lift, colors, etc.. would you use? what mods would you perform? Im still a bit green to the red (no pun intended ha!) but am noticing certain models catching my eye more than others. At this stage of the game, id build a long hood/long frame like my 1277 and keep the foot rests for sure, 520 gear reduction steering, stuff a 20hp Onan in it, stacked of course (love that big block Kohler but love the sound of those Onan twins more) 8 speed trans geared just slightly to run 8-9mph, tall, skinny tires up front, 8.5-12 ATVs out back all loaded, most likely an electric lift, Brinly hitch of course, 48" deck is enough. Maybe even a set of round rear fenders and traditional metal 'tractor' seat...... all in traditional red/almond wheels of course! Dont put it past me to get a wild hair and try this Excited to hear what you all come up with....or maybe already have! 4 1 Share this post Link to post Share on other sites
Pullstart 70,049 #2 Posted May 6, 2020 I kind of have built some of my ultimates... but the ones that bring the most smiles from my ladies are the best! Putt Putt 502, with 8 hp, 8 gears, ‘64 chassis and lately a 10” plow. Frank, Mrs. P’s “1073” 5 6 1 Share this post Link to post Share on other sites
ebinmaine 79,077 #3 Posted May 6, 2020 Great thread idea! Colossus. 3 1 Share this post Link to post Share on other sites
Pullstart 70,049 #4 Posted May 6, 2020 Screamin! Jimmy came from @12 hp Kohler Robbie at the 2018 Bog Show with an intake valve issue. We got that fixed up, made him wider in the front, added a second pedal, swapped out the hood and built a pretty nifty exhaust system. 4 8 Share this post Link to post Share on other sites
Pullstart 70,049 #5 Posted May 6, 2020 Barney Fife, the 857 mock 1045. I might not be done, it would be cool to add a 10 horse Kohler still. 7 4 Share this post Link to post Share on other sites
oliver2-44 11,504 #6 Posted May 6, 2020 @Achto built a huge favorite of mine. Since your asking what would be my ultimate Catallic of a WH be, I would add an Eaton 1100 Transmission and gear reduction steering. I also though about building an identical frame out of 2" square tubing. That would allow a loader subframe with a quick attach to be a minimal addition. 8 7 1 1 Share this post Link to post Share on other sites
Sam Pasch 450 #7 Posted May 6, 2020 (edited) If I could afford to build an ultimate wheel horse, I would start with a 1277. Then I would replace the 12 hp kohler with a later kohler v-twin, probably around 20 hp. Then I would add an ark FEL and find a way to adapt a side discharge 48" deck. I would convert it to hydraulic lift and make a custom cat-0 3 point for it. I would also add running boards off of a later model wheel horse. Wide rib tires up front, 25x12-12 ags in the back. Ultimate work tractor. Edited May 6, 2020 by Sam Pasch 8 Share this post Link to post Share on other sites
squonk 46,773 #8 Posted May 6, 2020 Short frame square hood. Big block Kohler. Round fenders and lowered 11 Share this post Link to post Share on other sites
tom2p 2,394 #9 Posted May 6, 2020 (edited) 17 minutes ago, oliver2-44 said: @Achto built a huge favorite of mine. Since your asking what would be my ultimate Catallic of a WH be, I would add an Eaton 1100 Transmission and gear reduction steering. I also though about building an identical frame out of 2" square tubing. That would allow a loader subframe with a quick attach to be a minimal addition. tractor pictured above (Achto's) is one of my all time favs and John Voss recently completed liquid cooled 3 cyl diesel (pic and link below) two examples of ultimate for me Edited May 6, 2020 by tom2p 4 7 1 Share this post Link to post Share on other sites
ebinmaine 79,077 #10 Posted May 6, 2020 30 minutes ago, squonk said: Short frame square hood. Big block Kohler. Round fenders... Trina and I had talked about doing that same thing. 3 1 Share this post Link to post Share on other sites
71_Bronco 1,072 #11 Posted May 6, 2020 Start with a short-frame, square-hood tractor like my Commando 8 - modify frame (if needed) to fit a 16 hp Kohler K381 under the hood - add forward swept 520H axle w/ gear reduction steering - 8-speed rear end w/ posi - dual wheels on rear - fabricate battery mount under seat pan (make room for Kohler) 7 Share this post Link to post Share on other sites
71_Bronco 1,072 #12 Posted May 6, 2020 47 minutes ago, pullstart said: I like the final look of those fenders on that one 5 1 1 Share this post Link to post Share on other sites
Sam Pasch 450 #13 Posted May 6, 2020 48 minutes ago, Sam Pasch said: If I could afford to build an ultimate wheel horse, I would start with a 1277. Then I would replace the 12 hp kohler with a later kohler v-twin, probably around 20 hp. Then I would add an ark FEL and find a way to adapt a side discharge 48" deck. I would convert it to hydraulic lift and make a custom cat-0 3 point for it. I would also add running boards off of a later model wheel horse. Wide rib tires up front, 25x12-12 ags in the back. Ultimate work tractor. I would basically create a 2077.☺ 4 1 Share this post Link to post Share on other sites
Lee1977 7,638 #14 Posted May 6, 2020 (edited) I haven't built one, but I have modified a couple. C-120/180 I bought it new it's been rebuilt slowly over the years . Axle repair with new pin and additional support. Both tractors have had the frame brace. Edited May 6, 2020 by Lee1977 10 1 Share this post Link to post Share on other sites
bc.gold 3,406 #15 Posted May 6, 2020 (edited) Onan twin coupled to a Sundstrand hydro driving a selective low, medium and high range three speed trans-axle, hydraulically operated three point cat 0, live rear pto shaft, front pto and a front end loader. Must not forget limited slip differential. Recirculating ball steering box, ribbed front tires with loaded Ag rears. Edited May 6, 2020 by bcgold 4 Share this post Link to post Share on other sites
Achto 31,886 #16 Posted May 6, 2020 (edited) @oliver2-44 & @tom2p thank you both for the complement on Radpferd. He was a concept in my head for about 2yrs, I'm very honored to see it considered as a choice on this post. With Radpferd I accomplished a look that I was going for and also ended up with a very capable worker. One other plus to diesel power - I logged 22hrs on the clock last year and only used 2.5 gallons of fuel. One of my next dreams involves a long frame, 8 speed, hydraulic lift, and most definitely no spark plugs. Edited May 6, 2020 by Achto 6 5 Share this post Link to post Share on other sites
PeacemakerJack 10,998 #17 Posted May 6, 2020 (edited) This is tough—so many cool customs on this site: I’m gonna give another shout out to my buddy @Achto for Radpferd. You think it looks good in the pictures, wait till you see it, hear it, and especially drive it—IN PERSON! Well done Dan! Kevin has done a lot of cool custom work but I have to give him props for Frank: I mean...a big wheel hydro round hood...nuff said! My buddy @19richie66 has done some cool stuff for sure and has several neat ones in progress, however can I say that Skittles is an awesome concept: Eaton 1100, custom wheels, custom hood latching/hinge mechanism, custom dash and controls, and much, much more! I also feel like @Shynon knocked it our of the park with his 1054 monster plow mule he built last year. He took an already capable machine and made it even better with a more powerful engine, heavier diff, etc. He will have to list the details if he cares to. Furrow plowing aside, if I was to build an ultimate all around—mowing, blowing, blading, scraping, tilling, kick butt machine, I would love to get my hands on a 520HC someday (solid mechanically but rough cosmetically) and swap the sheetmetal with and square hood long frame tin work. I understand that would be a lot easier said than done, however I have the afformentioned “maestro of metal work” only about 15 miles from my house 😉. It would be kinda like an LS drivetrain with custom frame and a vintage muscle car body on top😎😎😎 Dan talking diesel power made me think of another one that has floated in the back of my brain for awhile as an awesome plow machine: a D250 with Cat O hitch, full hydraulics, but upgraded with either a Perkins or Kubota 4 cylinder diesel! Definitely not the “sexiest” looking tractor but something tells me that would make short work of the JD 430’s at big plow days😂 Keep the ideas comin’ boys, this is a fun thread Edited May 6, 2020 by PeacemakerJack 7 4 2 Share this post Link to post Share on other sites
19richie66 17,889 #18 Posted May 6, 2020 (edited) I think if I could build anything I wanted it would the same as skittles but the diesel engine/Eaton hydro or an 8speed conversion. I built my favorite already. Just need to finish it. The “2054” for my wife will be another favorite completed when I get it going. 1054 on a GT14 frame, Eaton 1100 hydro and 20 hp magnum twin. Edited May 6, 2020 by 19richie66 8 5 Share this post Link to post Share on other sites
C-85 800 #19 Posted May 6, 2020 I love this thread too! I love my C-85, so what could be done to improve it? 1) A locking rear end 2) Front hubs with tapered roller bearings, like many have upgraded to. 3) I'm a big Black Hood fan, but a cast iron grill like some of the old GTs would be nice too! I really like my little 8hp tractor, the little tractor that can! I couldn't be much happier with it! C-85 9 2 Share this post Link to post Share on other sites
Goofey 89 #20 Posted May 6, 2020 (edited) I like the diesels a lot. The one in post 6 is soooooo nice. But for me it would be to try and do the same as Skipper did to his 195. I mean it could use some paint but mechanically that is just sweet and big and tough. Edited May 6, 2020 by Goofey 6 2 Share this post Link to post Share on other sites
Herder 2,356 #21 Posted May 6, 2020 The Raider 12 became a Raider 16. Big Blocks Rule 5 2 1 Share this post Link to post Share on other sites
PeacemakerJack 10,998 #22 Posted May 6, 2020 1 hour ago, Goofey said: I mean it could use some paint but mechanically that is just sweet and big and tough. Those tires have so much floatation that Kevin @pullstart would glide over top of the water and mud!!!😎 1 1 3 1 Share this post Link to post Share on other sites
ebinmaine 79,077 #23 Posted May 6, 2020 11 minutes ago, PeacemakerJack said: Those tires have so much floatation that Kevin @pullstart would glide over top of the water and mud!!!😎 And he'd be laughing all the way across... 1 1 Share this post Link to post Share on other sites
WHX?? 56,795 #24 Posted May 6, 2020 (edited) 4 hours ago, Achto said: One of my next dreams involves a long frame, 8 speed, hydraulic lift, and most definitely no spark plugs Yup that right there..... round hood style fenders & tool box, square pan set, stirrup foot rests …. end result would be the ultimate plow rig. Wow I don't think I ever saw Skipper's 195... that is a beast I don't think you could slip a dollar bill between the tire & fender! I'm this pic Jack.... that tractor is one of the best plow rigs I ever used.... Betcha this young lady would agree.... Edited May 6, 2020 by WHX24 1 1 4 Share this post Link to post Share on other sites
Tractorhead 9,217 #25 Posted May 6, 2020 6 hours ago, pullstart said: I kind of have built some of my ultimates... but the ones that bring the most smiles from my ladies are the best! Putt Putt 502, with 8 hp, 8 gears, ‘64 chassis and lately a 10” plow. What an outstanding Pic, looks a coworker climbs onto you rear Tyre.. 😂😂😂😂 5 Share this post Link to post Share on other sites
