Berco
Help! What is making the oil leak?
Berco
I have an oil leak on my Kohler CH22 in my Toro 522XI (see video). I put in new head gaskets to remedy low compression. Then upon first start i had a large oil leak. It seemed to come from the aft oil seal. So i pulled the engine again and replace the seals. I re-installed the engine again today and the leak is still there. This is the leak now: https://youtu.be/pi382fXVXPQ What could cause it? I did blow out the air line from the fuel pump with compressed air into the crank case to clan out any debris. Could that have caused a leak this bad on the oil pan gasket? or another location? thank you all in advance!
bc.gold
have you done a compression test maybe the piston rings need replacing.
Edited by bcgold
Berco
I have. I get 110 and 120 psi for the cylinders. It is not bad but not great. But it starts right up. The previous reading was 60 and 90. There is not any smoke when running and the oil level doesnt drop, so i feel the rings are good for now. I do not think bad rings could cause oil to pour out as seen in the video, but i am def a noob.
Darb1964
Not over filled with oil?
953 nut
Depending on how much pressure was applied you may have blown out a seal or gasket.
Hard to tell from the video, I don't own any CH Kohlers but they do have a pressurized lubrication system and are OHV engines, is the valve cover gasket the point of the leak?
bc.gold
Berco
It is not. I filled it up slow and checked often to ensure no over fill.
Berco
I cannot determine exactly the location of the leak. It is not the valve cover. It just replaced both oil seals and head gaskets, so maybe the oil could be leaking from the crank case seal. I am running out of options of where oil could leak from so rapidly. I do have a new breather valve on order and will be replacing that ASAP as that is the prime suspect now.
bc.gold
Why order a new PCV valve before inspecting the old one, when a simple reed adjustment might cure the problem..
Edited by bcgold
Berco
This engine has 1000 hours on it and i do not really want to pull it out again if the reed needs replacement shortly after. More of a do it while i have the engine out kinda thing.
  • Similar Content
    • Berco
      By Berco
      Hello all. My battery in my 520LXI was going out, the lights would come on but the engine would not turn over. I put a 1.5 amp truckle charger on the battery when i left for a 4 days trip. I come back and the same. I also noticed i left the key in the run position (the hour meter did not run). I swap out batteries and now the mower is completely dead. When i turn the key - nothing. I verify the battery it good (13.04v), negative is connected to the engine block, voltage is good on the solenoid side of the starter. I out the key to run and try to jump to see if i can start and nothing. Not even a spark. I have used this mover for years and has 500 hours. Could the ignition switch or brake switch be bad? The seat switch is jumped.What else could cause my mower to be dead? Thank you in advance.
    • gfullz
      By gfullz
      Hey guys! new wheel horse owner here. I picked up a 2001 523xi that came with a berco subframe. I happened to find a 40" compact berco that was hardly used to slap on it only I'm not sure where to start as there are no resources for this that I can find. I'm mechanically inclined, rebuilt the injection pump, injectors etc... as I purchased it non-running as it wasn't receiving any fuel to the injectors (it runs amazing now btw).
      so for starters I'm going to go out on a whim here and say that this will require the mule drive or "pulley box". and I've got the rest of the parts in the picture. The parts of the subframe that look to bolt up seem so narrow compared to the hookups on the rest of the tractor. Any help is greatly appreciated.
    • woodbird007
      By woodbird007
      Need help adding oil drain piping to Koehler K241 with 1/2” drain plug
