ebinmaine 81,146 #1 Posted September 4, 2018 Curious to see how you have added steps to your pre 68 tractors... 1 Share this post Link to post Share on other sites
953 nut 70,344 #2 Posted September 4, 2018 Are you talking about the running boards that started being used in '68 or '69? If that is it all you need is a second piece of 3/4" round stock on each side near the back of the running boards to support them. 3 Share this post Link to post Share on other sites
RandyLittrell 3,946 #3 Posted September 4, 2018 Eric, someone bought a tractor recently that had put the running boards on an earlier tractor I wish I could remember who that was. 1 Share this post Link to post Share on other sites
ebinmaine 81,146 #4 Posted September 4, 2018 2 hours ago, 953 nut said: Are you talking about the running boards that started being used in '68 or '69? If that is it all you need is a second piece of 3/4" round stock on each side near the back of the running boards to support them. I guess I'm not really sure what I want. I was thinking of something that was just a flat step without the vertical portion. I don't want the tractor to look like I'm trying to imitate the later models. 1 hour ago, RandyLittrell said: Eric, someone bought a tractor recently that had put the running boards on an earlier tractor I wish I could remember who that was. Maybe they'll chime in..... Share this post Link to post Share on other sites
JAinVA 4,638 #5 Posted September 4, 2018 The c120 had running board foot rests and no 3/4" rear bars.There was a bracket bolted to the hood stand and the rear portion of the rests bolt to this bracket. Go to parts tree and look up the c120 parts list. 1 Share this post Link to post Share on other sites
JAinVA 4,638 #6 Posted September 4, 2018 If you just want a short rest then a fabricated angle iron bracket could be bolted to the frame on each side.For obvious reasons the support can't go completely across the frame. 1 Share this post Link to post Share on other sites
Pullstart 71,520 #7 Posted September 4, 2018 (edited) 1 hour ago, RandyLittrell said: Eric, someone bought a tractor recently that had put the running boards on an earlier tractor I wish I could remember who that was. I bought an 857 at the big show that most guys said belonged to a set of stirrups originally but came with running boards... it doesn’t have the second round bar out back but considering her weight, I doubt that is a concern. The rear of the running board bolts to the front fender support/latch bar. Edited September 4, 2018 by pullstart Wrong picture, but kept the Commando 800 for comparison 5 Share this post Link to post Share on other sites
RandyLittrell 3,946 #8 Posted September 4, 2018 Yup, that's the one I was thinking about!! Randy 1 Share this post Link to post Share on other sites
RandyLittrell 3,946 #9 Posted September 4, 2018 @ebinmaine, if my 1277 didn't have a loader on it, I would need something too. I have short legs plus "all gut, no but" syndrome so I can barely reach the pedal. Don't really need to since it doesn't have brakes anyway. I rest my foot on the loader mount. 2 Share this post Link to post Share on other sites
Mikey the Monkey 701 #10 Posted September 4, 2018 3 Share this post Link to post Share on other sites
ebinmaine 81,146 #11 Posted September 4, 2018 1 hour ago, JAinVA said: The c120 had running board foot rests and no 3/4" rear bars.There was a bracket bolted to the hood stand and the rear portion of the rests bolt to this bracket. Go to parts tree and look up the c120 parts list. I have several B and C series rigs here to compare. I'd like something flat but without the rear attachment point I'm going to be pretty limited I think... Main issue is. Well ... Me. EACH step needs to support over 250 pounds when I'm getting on/off the tractor. 2 Share this post Link to post Share on other sites
Machineguy 877 #12 Posted September 4, 2018 44 minutes ago, ebinmaine said: I have several B and C series rigs here to compare. I'd like something flat but without the rear attachment point I'm going to be pretty limited I think... Main issue is. Well ... Me. EACH step needs to support over 250 pounds when I'm getting on/off the tractor. We have the same concern with structural support. 1 Share this post Link to post Share on other sites
ebinmaine 81,146 #13 Posted September 5, 2018 3 hours ago, Mikey the Monkey said: Mike thanks for posting that pic. Those wooden running boards could be the ticket.... Plain varnish.... Share this post Link to post Share on other sites
RandyLittrell 3,946 #14 Posted September 5, 2018 (edited) 3 hours ago, Mikey the Monkey said: My concern would be just how much weight that would hold? Its strap bent at an angle bolted to angle iron. I am closer to 280 and I am thinking it would go to the ground with me. How about it @Mikey the Monkey, whats the rating? I think if you used some 1" tubing that went all the way across underneath, that would be pretty sturdy. Would it be in the way if it did? I don't have a deck on an older Horse. But if I take the loader off my 1277, I am gonna want to do something like that. Randy Edited September 5, 2018 by RandyLittrell Share this post Link to post Share on other sites
JAinVA 4,638 #15 Posted September 5, 2018 It depends on how long you want foot rest to be.If far enough back you could fab something that goes all the way across.It would only have to clear the mower lift arm.If you are 250 plus it might be a good thing to have a foot rest to take pressure off the steering column when mounting. 1 Share this post Link to post Share on other sites
ebinmaine 81,146 #16 Posted September 5, 2018 2 minutes ago, JAinVA said: It depends on how long you want foot rest to be.If far enough back you could fab something that goes all the way across.It would only have to clear the mower lift arm.If you are 250 plus it might be a good thing to have a foot rest to take pressure off the steering column when mounting. I have no mowers here so that clearance isn't an issue. 1 Share this post Link to post Share on other sites
JAinVA 4,638 #17 Posted September 5, 2018 (edited) If mowers are not an issue then lets us what you come up with.If you are like the rest of us and you wrench on them you should be able to come up with what works best for you.Let us see some photos when you get done. Edited September 5, 2018 by JAinVA 2 Share this post Link to post Share on other sites
Racinbob 13,286 #18 Posted September 5, 2018 I've never really thought about this but I'm thinking like @pullstart that the rear bar isn't needed. I had to pull up a picture of the Commando 800 I restored for my grandson and it doesn't look like there's a rear bar unless I can't see it in the picture. That tractor was original when we got it in the early 80's and still going strong today with no stress issues. Then again, it hasn't had a 'full grown' operator as all of us are in the mid 100's. Having the bar would certainly add strength. 3 Share this post Link to post Share on other sites
Racinbob 13,286 #19 Posted September 5, 2018 (edited) I just looked at a picture of my 76 and don't see one there either. I should know because I just had that one apart but I'd have to look to make sure. Edit: The parts manual doesn't show a rear bar on the 76 so apparently it isn't needed. My 2005 does have one so I guess it's based on the year and how the sheet metal is attached to the frame. Edited September 5, 2018 by Racinbob 1 1 Share this post Link to post Share on other sites
RandyLittrell 3,946 #20 Posted September 5, 2018 @ebinmaine, I bet if you went to the hardware store, picked up a length of square tubing, oak stair tread, and some hardware, you could build you some running boards pretty easy! Randy 2 Share this post Link to post Share on other sites
ebinmaine 81,146 #21 Posted September 5, 2018 6 minutes ago, RandyLittrell said: @ebinmaine, I bet if you went to the hardware store, picked up a length of square tubing, oak stair tread, and some hardware, you could build you some running boards pretty easy! Randy You may have yourself a pretty neat idea right there Randy. I have plenty of wood scraps around already but I'm not sure if I have any Square stock that is smaller than about 2 in. @Racinbob @pullstart I'm thinking I'd like to add some that do not have the vertical portion at the back. Kind of keep with a unique look of the tractor. 3 Share this post Link to post Share on other sites
Mikey the Monkey 701 #22 Posted September 5, 2018 (edited) The steel is 1.5 inches wide by 1/4 inch thick. I can put all 199 lbs on it no problem. I like how they look. Interesting add on by original owner who's been gone a long time. Edited September 5, 2018 by Mikey the Monkey 1 Share this post Link to post Share on other sites
Mikey the Monkey 701 #23 Posted September 5, 2018 20 hours ago, RandyLittrell said: My concern would be just how much weight that would hold? Its strap bent at an angle bolted to angle iron. I am closer to 280 and I am thinking it would go to the ground with me. How about it @Mikey the Monkey, whats the rating? I think if you used some 1" tubing that went all the way across underneath, that would be pretty sturdy. Would it be in the way if it did? I don't have a deck on an older Horse. But if I take the loader off my 1277, I am gonna want to do something like that. Randy Share this post Link to post Share on other sites
Chris G 3,401 #24 Posted September 6, 2018 You could use some old cub foot rest as I did. Then I just fabricated a bracket holding the rear of them up and bolted to the frame. I made the bracket to hold them at the position I wanted. I'm only around 185 pounds and they hold up to me pushing on them and all the abuse I put to them. 3 Share this post Link to post Share on other sites
