oliver2-44
I want to install a Tiller & Dozer blade at the same time>
oliver2-44
I have a large dirt leveling & shaping project coming up down the road. :woohoo: Seat time!
I need to be able to loosen up high areas to push them around to level and improve drainage of a 100 ft x 150 ft back yard.  The soil is sandy/clay granite gravel. It has enough clay in it to be very hard when very dry, but will dig fairly easily when damp.
So I'm starting to think about how to install a tiller and dozer blade on my C-160 at the same time.
I wish I could even mount the Tiller and a Center Mount Grader Blade at the same time.
 But I suspect the blade would hit the front wheels when angled since it would be mounted forward of its normal position, or it would hit the front tiller pulley?
One idea I'm thinking of essentially making a double rear axle hitch, one in front of the other. The tiller would mount in the rear mount under the axle in the normal positionn so the pulleys would be in the correct location so the belt length would not change.  The dozer blade wound mount in the forward mount, and its lift link would have to be a custom length. I'm thinking I need to make some type of support bracket from each side of the front mount that would mount to the frame.  The forward mount would also have to be spaced forward enough so the end of the dozer blade arms  would not hit the tiller cross bar in the rear hitch mount.The normal hitch locks probable would not work, so I'm thinking a locking bar would be bolted on to lock both implements in place.
The other idea would be one hitch directly below the other in the normal axle position. It would also have to have some type of brace to the forward frame so as to not put a twisting force on the axle.  I  haven't figured out if there's enough ground clearance to do this type of arrangement.
The front dozer blade would be lifted by the existing hydraulic lift and the rear tiller would be lifted by a 2nd rear hydraulic cylinder.  Only one implement would be in use at one time.
I'm thinking I will make a wood mock up of both ideas to work out some basic details before I start cutting & welding.
Has anyone tried this?  I would like to learn what worked and what didn't from others. if you haven't tried it, I still like to hear your thoughts on what might work, or potential  problems that I haven't thought of yet.
Thanks
So many projects, got to find a way to make them fun!
Thisguyisnew
I think if you were somehow succesful in mounting both you'd still have clearance issues. There is also the matter of having still just one lift cylinder connection.
Edited by Thisguyisnew
wallfish
Sounds to me like you have the perfect scenario for the concept of a tractor for every attachment. Two C160s should be nice! Or, even go with a smaller engine tractor for the dozer blade.
If hell bent on both for one tractor, maybe attaching a modified blade frame to the mid Tach A Matic ?  :twocents-02cents:
Edited by wallfish
WVHillbilly520H
The xi series rear axle bracket is basically what you're talking about, but I'm still not sure it would work as you're wanting, Jeff.
953 nut
I have done a similar project but used a moldboard plow to loosen the soil then pushed it with a blade.. I didn't have them on the same tractor, but if you added a couple of chains to the mix you could chain up the one not being used and then alternate.
R. L. Addison
If you add the second valve in the stack, both would work independently, & need no chains for either.
I would look for a front mount blade, (vertical shaft?, some of the older ones?, or custom?, several ways to go,) and maybe just a little jua kali engineering might get just what you want.
Forest Road
You could do a winch to raise the tiller. Mounting the plow forward 3-6” should
be ok. Might need to weld a new lift point onto plow.
Personally I’d get another horse.
BOB ELLISON
If you had one of these type of blades.
I got this with the 520h and the guy said he used it to plow snow. So I did connect it to the front and it worked like a champ.i even posted it here to see if anyone ever seen this type setup. but I sold the 520h and kept this very heavy blade. But the one thing that you would have to overcome is the lift for both on the cylinder. You would have to put a winch on front for the blade and use the tractor cylinder to lift the tiller. To bad your so far away or I'd sell it to ya
oliver2-44
I've already added the 2nd hydraulic valve And have a cylinder awaiting a rear mount. So the lifting part is covered.
@WVHillbilly520H Thanks for the info on the XI series hitch. Is it the same width as a 3,4,5 and C series hitch. If so, maybe I could use one of them and not have to reinvent the wheel, or am I missing something?
while I like the 2nd tractor idea, I already have a non runner in the shed that needs major life support.      WH aren't the most plentiful around here.
WVHillbilly520H
@oliver2-44, yes I believe the xi hitch is the same width but a bit pricey $130 (shipped)new, and hard to find used, @BOB ELLISON, that front blade you have looks to be originally from a PowerKing as that was my first attempt on my Kioti before I went 4way hydraulic, Jeff.
Edited by WVHillbilly520H
Sarge
I've considered doing similar and even splitting the rock shaft system in half so another cylinder could be used on the right side to mirror how the left side is built for hydraulic lifts. That would separate the front and rear attachments but require some heavy solid stock and machining a coupling to hold the two halves together in the hood stand. After a lot of consideration, measurements and like - it's just not worth that much work for what it yields. Doing it this way would give it front/rear separation but the weak design of the hood stand would have to be beefed up to hold the implement weight/force during travel and using either the front or rear attachment. I wanted it for two blades, one front , one rear for dirt and snow work. Using a rear cylinder is a better setup along with a dual spool valve but you're limited at what volume the hydro pump puts out somewhat.
From your description, your weak point is going to become the frame rails themselves and transmission mounting plate. Maybe if the frame was fully boxed which limits it's attachment uses would work but you'd have to tear it down completely to do it right. Me ? I ended up with a D-180 - a C-195 would be even better but none of them can beat a D for it's frame strength from what WH built . What you're describing really needs a heavier tractor to handle that weight/stress - a D will do the job but has it's weak points like the others.
Sarge
c-series don
I often thought about this myself, I used to till the hard ground, switch attachments and put the plow on to move the material around. I have found that the easiest way to solve this is to just have a tractor for each implement. This way you can just jump from one tractor to another!!!
Sarge
From your description of work needed, might want to consider a rear box blade with ripper teeth - they are designed for what you need and it's only 1 attachment, a decently built heavy one should work fine.
Sarge
Edited by Sarge
grammar
c-series don
I have that box blade with the ripper teeth brand new. It's made by Brinly takes the Brinly hitch. I always think I'm going to take it to a show on one of my show tractors but after owning it for more than ten years and not doing that I probably would sell it. I can't believe I just said I would sell something!!!
oliver2-44
@c-series don I'd appreciate if you could post a deli tires of the box blade with a tape measure in them for reference. I have a Sears rear blade  that came with a non runner WH. I'd like to compare to see if it would be easy to make into a box bladei
WVHillbilly520H
I have the agri-fab(last 2) version it's 42" but Sears and Northern Tool sell both brands Brinly(first 2) and Agri-fab here's a couple pics from their site, anyways with enough weight it does seem to OK, Jeff.
elcamino/wheelhorse
My son purchased the brinly from Northern and it really works well. He used it to level and clear his back yard which was full of fist size rocks partially buried in the soil.
c-series don
The first picture is the exact one that I have, if you need further dementions I can get them to you.
WVHillbilly520H
Sarge
I've seen those - not a very heavy duty unit but with some mods ....or build your own.
Sarge
oliver2-44
Thanks for all the great comments. Gives me lots to think about. I'm going to did the Sears rear blade out and thinks out making it a box blade with rippers
I also have one other idea that y'all can help me out with. Y'all mentioning the rippers reminded me of a guy who had made a set of pivoting teeth on the back side of a large bulldozed blade. When he was backing up he would back drag with the blade. Just above the ground and the teeth would dig in and rip. When he pushed forward the teeth pivoted up and just slid along. I thing the teeth were pivoting on a large round bar mounted on the back of the blade.  No lost work time....pushing dirt forward and ripping backing up  If I could make that work I could use one tractor and one implement for the job
Edited by oliver2-44
Sarge
If you ask around at some of the older welding shops they will have worn out cutting edges taken off heavy equipment - I have one that is 5' long for the price of it's scrap from a local welder. 1" thick, tapered AR400 cutting edge - cannot really be welded on much without a lot of preheat but it can be bolted to a sub frame - that will be the center grader blade for the D this summer if I can get the time. You can do the same with box blade designs - but go look at the heavier tractor mounted 3pt types - it's fairly easy to build one to hang off the rear hitch or make it a tow type. The D's front blade was rebuilt using a piece of pre-beveled 1055 high carbon off Ebay - they are selling different lengths/thicknesses now pretty cheap. I doubt it's all that high of quality, but beats what those Brinly , Agri Fab and others are made from including WH's own cutting bars, most are just plain steel. Makes a huge difference in how effectively it cuts the ground - mine is easily removing frozen gravel off our parking lot pretty badly with just the weight of the blade, no down pressure.
Check out the box blade designs on modern compact tractors in Cat1 & Cat2 sizes, there is some really interesting designs and engineering in those now offered to older units - they work excellent and a buddy just got one for his big Kubota. I'll probably at least somewhat copy that one for a couple of rear box scrapers this summer, need one around here badly for leveling the ground.
Sarge
WVHillbilly520H
@oliver2-44, I use my Agri-fab brand box blade with my 520H and even with the hydraulic lift it could be at times a bit hard to lift especially with the weight bar I added, I used it to repair my parents 1/4 mile long dirt/gravel driveway several times over the past few years and it has held up just fine on severely compacted soils, the ripper teeth (1/4")can be flipped over out of the way while working it without tools, the main parts are made from 3/16" thick cold rolled steel and has worn down some on the end plates and blade itself but the beauty of it is that it can be all reversed/flipped over after it has worn too far or simply add new material/flat bar and start over, and if you are only using it occasionally should last you many years, with Sarge's idea IMHO it would be too heavy for the C160/520H size tractor on our style clevis hitch, but fine for the D series or sub compact size tractor with actual 3pt hitch where it's attached to the frame vs the trans hitch pin, even the 5' rear scraper blade on the Kioti and eMax will literally pull the tractors side ways when full of dirt/gravel or wet heavy snow it's to easy to over load these little tractors there's a reason impelements are sized accordingly, Jeff.
Sarge
That is a good point and I do tend to build things a bit on the heavy side - but I hate repairing poor quality steel parts used on some of the attachments. WH didn't even use decent steel on their cutting edges for blades/blowers/scrapers which really surprised me given how well they built every thing else they sold.
Now, that said - both the 1277 and C-160 can pick up/carry my disk when loaded with concrete blocks or iron. It has been weighted up to 300lbs to help it cut better in tough soil conditions but I have broken cables that were less than perfect - Lowell fixed that easy enough and his haven't failed yet. My rear blade has a very heavy piece of cutting edge the neighbor's welding shop installed on it since it had to be plasma cut , that blade bare is 150lbs now and will scrape ice/rock like nothing.
The one constant failure point on the long frame standard tractors is always the frame to transmission mounting plate and I've broken plenty of them. I do have the ability/tools/equipment to repair it , so heavy implement use is not a problem for what I do here - I should always add that disclaimer when giving out ideas, lol...sorry.
Some of the box scrapers are heavier than others and there is always the tow behind models designed for heavier ATV's - which have about the same capability as our tractors. The lighter duty box units from Brinly and Agri-Fab are really designed for lawn tractors or smaller garden tractors - a solid C-160 can destroy them and that was the reason for the extra heavy cutting edge on my rear blade when the original rolled steel just bent in places and wore out quickly - it was build with only 3/16" light duty steel, nothing hardened at all. The heavier built tow behind box blades cost more due to the materials used - a C-160 could easily handle it but you can hit a point where traction is going to become the limiting factor - that's a good thing to prevent damage to your frame. Weight those tires too much or ram it , now you're risking a frame plate breakage - it does sort of act like a fuse. It would be a good idea given how hard you are pushing the tractor to search for frame reinforcement threads - there are several good ways to prevent too much stress to the transmission mounting plate and some are really easy to install with no welding involved. My 1277 is parked again and out of service due to the plate shattering - it will get a new and heavier one made from better steel versus the stamped profile metal originally used on it. That even has a limit and you can rip the threads out of the cast iron trans case - so keep it to a sane level or find a much bigger piece of equipment like a sub/mid compact tractor.
These things given their size will do an amazing amount of work - if you are patient and respect it's size and capability. Many don't and have to repair them, guilty as charged here and I should have invested in something much larger years ago but I enjoy working on the Horse instead.
Sarge
  • Similar Content
    • Epayne85
      By Epayne85
      Hello all, I have a what I believe is a 36” tiller.
      i can get a few pictures of it this afternoon, it rolls freely and appears in very good condition. It’s missing the rear hinge panel. I’m mainly interested in swapping for a box blade and other items depending what you’d have for the clevis or sleeve hitch or I’ll take best offer. Thank you. Also, I have a snow plow and the frame in which someone has modified for I believe an Atv or different tractor I’d be willing to let go for $50 or throw in towards the deal. The blade is in pretty decent shape and the angle mechanism works flawlessly. Again thank you.
      edit* I will be able to get pictures Labor Day weekend, sorry for the delay if anyone is interested
    • morePEdal
      By morePEdal
      1989 Wheel Horse 520H
      Selling my 1989 Wheel Horse 520H. It has hydro transmission and has hydraulic lift. I bought this tractor last November from the original owner with the intent to use it just in the winter. I have a 416-8 that I use for cutting grass, but also have a snow blade. I am selling this because I decided I want power steering so I bought a different garden tractor. I put in a new fuel filter, fuel lines, new spark plugs and oil was changed with a new filter put in. It has 115 compression on both cylinders. The carb needs work, but it does start and run. I no longer have room for it. 1790 hours.
      I am in Germantown, Wisconsin.
      Comes with:
      -42” Deck
      -Two- Single Stage Snowblowers, one is attached.
      -Tiller
      -Snow Plow
      -Hard Top, Soft Sided Cab, in good shape
      -Hubcaps
      -Cast Iron Weights
      -Chains
      -New Battery
      -New Snowblower Belt
      Price: $1100
      Cross Posted.
    • oliver2-44
      By oliver2-44
      Anyone have any Troy Bilt  Pony Tiller Gear Box Experience?
      So about a year ago an older neighbor gave me this Troy Bilt Pony Rear Tine tiller.  Said he forgot he drained the engine oil and started it.  Bore diameter was actually good, but has a bunch of large vertical scars on cylinder walls.
      Fast forward, my wife has volunteered us to help a Youth Summer Camp that runs an  "Outdoor School" during the 9mth  school year.  They had a fairly large garden for several years, but it has been neglected & overgrown for a couple of years.  So she drives past this neglected garden daily!
      There's some scheme emerging where we have half the garden to ourselves and help with the other half where students will plant and weed and pick their produce.  I enjoy a garden, but not real keen on some of the aspects on this one...( a bunch of 6" high raised beds with paths to narrow for my big feet to turn sideways. But I've already been committed, O I mean volunteered.
      So engine is shot (aluminum block)  but I have a Predator or a K181 I could put on it.
      The wheel shaft seals looked shot and had a bunch of play so brass wheel bushings were shot. (the other 2 shafts have tapered roller bearings).
      No model number, but from the "Pxxxxx" serial number and Briggs engine I've dated it to a 1981.
      MTD now owns Troy Bilt and their "on-line manuals" go back to 2000.  Called their Tech Supports and got "Deer in the Headlite" comments regarding a 1981 Service Manual.
      Searched online and founds lots more info on the larger "Horse" model, and a 1991  Pony service manual.
      While they basically look the same, there's been several generations of re-engineering the internals to simplify manufacturing and eliminate castings it appears.
      I found this parts diagram to be the close's match to what I have.
      https://www.partstree.com/models/20462-troy-bilt-pony-i-rear-tine-tiller-sn-p001001-p101750/wheel-tiller-shaft-assemblies-7/
      I disassembled it and I think I marked everything as to what faced the front, back or R,L side.  Internals looked OK, but the wheel shaft seal area is not the greatest.
      Most parts are NLA but found bearing. seals & bushings on ebay. $130
      Reassembled everything and used the 1991 Service Manual as a "Guide" to shimming the 3 shafts end play.
      Everything turn freely in both directions when in neutral. But when I engage the Wheel Shaft "Clutch" it binds up. The clutch lets the wheels roll freely or engages them to power.  It uses belt idlers to reverse direction from a second shaft on the briggs (like a walk behind snow blower drive)
      photo from phone here
      This internal clutch actually works by using a pawl disc which is keyed to the shaft to engage the wheel
      shaft gear which is free wheeling on the shaft.
      I've loosened the bolt on the bearing end caps slightly and no change.
      This uses worm gears and I know "some" worm gears are designed where they must be "power driven"  in each direction (My boat lift is like this)
      So the rear tine gear shaft turn freely in each direction.
      The wheel shaft locks up when the clutch is engaged amd trying to turn it in what would be the forward direction.  But it will turn freely with the clutch engaged if going in the backwards direction.
      The wheel shaft gear cannot be turned backwards because of the clutch mechanism on the one side.
      The rear tine shaft bevel gear turn freely in both direction in neutral but is bound up when the clutch on the wheel shaft is engaged.??
      There is a Main Drive Shaft that has the Worm Gears on it to drive the Wheel Gear and a second worm to drive the Tines Gear.
      https://www.partstree.com/models/20462-troy-bilt-pony-i-rear-tine-tiller-sn-p001001-p101750/main-drive-shaft-gear-assemblies-4/
      This shaft is made up of a smooth shaft with the worms keyed to it and spacers in between them.  I disassembled it (and carefully laid out each piece in order) to wire brush everything clean on the grinder as there was some rust from water in the very bottom of the gearbox.
      I find it hard to believe that I could have one of the worms backwards because it seems it would not turn freely when the wheel clutch is not engaged??
      To remove it I have to disassemble everything and might ruin my seals as I have to drive them out. (dumb me, I tested everything to turn freely before I installed the seals, BUT I didn't engage the clutch)
      Just a note,, I didn't try to turn everything with the "clutch engaged" "Before" I disassembled it so I don't know how hard it should turn, but it had to turn via a belt drive verse's now totally locking up.
      Regrettable a nonworking tiller doesn't get me out being volunteered.
      Did I say I actually enjoy a garden!
      Thanks for any suggestions and listening to my rant.
      This is the input shaft from belt pulley
      Special woodruff key
      Tiller Tine Shaft
      Some one was in here before me. These are threaded holes with removable set screws to drive the bearing cone out. No set screws just filled with caulk or body putty.
    • wh315-8
      By wh315-8
      Anyone be able to measure out the Top Link Bar for the 50” D Series Tiller?
      Just finished rebuilding a tiller, have a adjustable type but would like to put a original type on like the manual has listed.
    • wh315-8
      By wh315-8
      My 50” D-series tiller input shaft has like 3/16” +\-, play pulling in or out. Anyone else have this same thing. Is it supposed to have that much play? Have it all apart and was thinking of adding a shim or 2nd thrust bearing to lessen the play to at least 1/16”.
