TonyToro Jr. 2,539 #24926 Posted November 12, 2025 Hauled some brush with the C-121 today 8 4 Share this post Link to post Share on other sites
Blue Chips 855 #24927 Posted November 13, 2025 (edited) I'm almost done refurbishing my GT18. I added fresh fuel today, changed all of the oil and filters, and took it for a longer test drive. The fresh fuel eliminated the slight lag from idle to a sudden wide-open throttle, and it's running great. I slipped an old seat cover over the original seat, which is still in pretty good shape, with only a couple of small hairline cracks that don't go all the way through. I may try some vinyl conditioner on it to see if it softens up a bit. There are still a few tweaks left to do on it: I need to make the final adjustments to the brake and motion-control linkages. The battery light is always on (it's charging fine) so I need to address that, either with a different battery light module or going to a voltmeter instead of a warning light. There's a wobble in the left front wheel, which I plan to replace with a rim that I got from @JoeM. I haven't decided about decals yet. It's a GT18, but I believe I've bumped up the CH18 to 20HP, so I don't know if I want a GT18 decal or not. Maybe I'll just skip the decals. Edited November 14, 2025 by Blue Chips 2 4 Share this post Link to post Share on other sites
Handy Don 17,474 #24928 Posted November 13, 2025 GT-18+ 3 Share this post Link to post Share on other sites
JoeM 10,268 #24929 Posted November 13, 2025 1 hour ago, Blue Chips said: I'm almost done refurbishing my GT18. Nice work Chips! 1 1 Share this post Link to post Share on other sites
kpinnc 18,967 #24930 Posted November 13, 2025 1 hour ago, Blue Chips said: haven't decided about decals yet. It's a GT18, but I believe I've bumped up the CH18 to 20HP, so I don't know if I want a GT18 decal or not. Maybe I'll just skip the decals. Terry (Vinylguy in the vendor section) can make you some decals any way you like, and everyone here can vouch for his work and how nice the decals are. Almost everything I've purchased from him has been custom work. I think he has some 5xi stuff anyway, so he already has size templates to work with. Your tractor looks great! Even if it isn't red it is still a beauty! 3 1 Share this post Link to post Share on other sites
JoeM 10,268 #24931 Posted November 14, 2025 (edited) I got new shims and gasket for the M12 that was leaking oil. Reinstalled the bearing cover and checked the end play, Made some dowels to hold the 4 shims and gasket. Shims were .003 and gasket was .010. Used longer bolts to pull cover in while I tapped on it with a plastic dead blow. Whet smooth until the purple wire decided it wanted in on the action and drooped in between. I removed it probably going to reroute anyway. I did notice once the plate was seated there was no end play, I tapped the crank with the dead blow back and forth a few times and that loosened her up. Total was .008 I checked it before I took it apart and it was .004. I did add the same number of shims. Edited November 14, 2025 by JoeM 9 Share this post Link to post Share on other sites
Sodaking27 1,358 #24932 Posted November 14, 2025 Heart beat replacement for the C175. Met up with Lincoln from A to Z and picked up this KT17 series 2. Most likely will be after the holidays before I get the chance to install it. Looks to be a 1995. 6 7 Share this post Link to post Share on other sites
pfrederi 21,151 #24933 Posted November 14, 2025 1 hour ago, Sodaking27 said: Heart beat replacement for the C175. Met up with Lincoln from A to Z and picked up this KT17 series 2. Most likely will be after the holidays before I get the chance to install it. Looks to be a 1995. I have a Gray KT17-2 also. same spec number (Wheel Horse) but by serial number 1987. Always figured WH ordered replacement engines to go in place of failed KT-17-1... 5 Share this post Link to post Share on other sites
kpinnc 18,967 #24934 Posted November 14, 2025 (edited) Built my FIL a locking swivel seat for his Charger. He has a little difficulty getting on and off the tractor, so this will let him sit and swivel to center. Had to make two different adapters while trying to raise the seat as little as possible. But it worked out nice. Now we gotta figure out a latch for the fender pan. I have rebuilt the area under the seat that wears and allows rapid dismount over the rear of the tractor but I think it needs one more safety added. May use a hood latch from a semi between the fender and footrest on the left side. Can't load a pic for some reason. I'll add it later. Edited November 14, 2025 by kpinnc 5 Share this post Link to post Share on other sites
ebinmaine 80,714 #24935 Posted November 14, 2025 8 minutes ago, kpinnc said: hood latch from a semi between Like the 300/400 hoods? Share this post Link to post Share on other sites
kpinnc 18,967 #24936 Posted November 14, 2025 1 minute ago, ebinmaine said: Like the 300/400 hoods? No, he said he has one from a semi truck hood latch. Almost like an old toolbox latch. 2 Share this post Link to post Share on other sites
ebinmaine 80,714 #24937 Posted November 14, 2025 34 minutes ago, kpinnc said: No, he said he has one from a semi truck hood latch. Almost like an old toolbox latch. That's OLD truck hood latch.. I ain't seen a LATCH for a hood in many years. Share this post Link to post Share on other sites
Bar Nuthin 3,243 #24938 Posted November 15, 2025 Today, I changed the name of the tractor, formerly known as Frankenhorse, to Johnny Cash. It's a '73 16-auto, with a '72 14 Horse Kohler, a '74 (or later) Sundstrand Hydro, and a '71 hydraulic lift. Even though I knew the Sundstrand was newer, I brain farted when looking up the mounting gasket to the transaxle and ordered the gasket for a 1973 (#5955) from @daveoman1966, who even noted that they were for hydrogear only, but it didn't register in my tiny brain. To make it more confusing you can substitute the #102759 for the #5955, but not the other way around. Additionally, there's a seller on eBay listing #5955 gaskets as #102759 - so my first picture reference was misleading I'm only out a few bucks, but having to wait on parts is torture. Anyone needing gasket #5955 let me know. 3 1 Share this post Link to post Share on other sites
Ed Kennell 47,362 #24939 Posted November 15, 2025 I saw this 48" long frame plow on FBMP for cheap, so I made the 1 hr RT this morning. I never saw this warning decal before. Wheel Horse? 6 2 Share this post Link to post Share on other sites
AlexR 3,115 #24940 Posted November 15, 2025 Got them washed up and parked in the barn for winter, still need to get the snow blower on one sometime. 4 9 Share this post Link to post Share on other sites
WHGuy413 2,859 #24941 Posted November 16, 2025 @WheelHorse_Kid and I have been working on getting stuff squared away for winter. Had these 5 out of the garage so decided to snap a photo. 3 8 Share this post Link to post Share on other sites
Ed Kennell 47,362 #24942 Posted November 17, 2025 On 11/15/2025 at 5:26 PM, Handy Don said: @Ed Kennell your JPG image isn’t visible. Karl fixed the problem. 1 Share this post Link to post Share on other sites
kpinnc 18,967 #24943 Posted November 17, 2025 On 11/14/2025 at 5:41 PM, kpinnc said: Can't load a pic for some reason. I'll add it later. Karl @nylyon fixed it. My pics load again. Here is the swivel setup. Locks about every 30 degrees of rotation unless the handle is pulled. 12 Share this post Link to post Share on other sites
JoeM 10,268 #24944 Posted November 17, 2025 On 11/15/2025 at 12:34 PM, Ed Kennell said: I never saw this warning decal before Just another sticker for the dumb asses, contrived by law suits. And drives the cost up for us. 1 Share this post Link to post Share on other sites
ebinmaine 80,714 #24945 Posted November 17, 2025 On 11/15/2025 at 12:34 PM, Ed Kennell said: warning decal 1 hour ago, JoeM said: Just another sticker for the dumb asses, contrived by law suits. And drives the cost up for us. Not sure on the date those were on Wheelhorse plows. We've seen that decal wording several times here. Share this post Link to post Share on other sites
Ed Kennell 47,362 #24946 Posted November 17, 2025 2 hours ago, JoeM said: On 11/15/2025 at 12:34 PM, Ed Kennell said: I never saw this warning decal before Just another sticker for the dumb asses, Why Joe, shouldn't we let them drive their snow plows into tall structures at high speed? 7 Share this post Link to post Share on other sites
953 nut 69,339 #24947 Posted November 17, 2025 Safety first! 1 1 6 Share this post Link to post Share on other sites
ebinmaine 80,714 #24948 Posted November 17, 2025 @OldWorkHorse came byfor a visit. 3 YEARS ago he and I had @Pullstart send us a chunk of pvc to make dual wheel spacers. Steve and I used a table saw and some patience to cut several slices about 2.25" wide. 6 3 Share this post Link to post Share on other sites
OldWorkHorse 3,156 #24949 Posted November 17, 2025 19 minutes ago, ebinmaine said: @OldWorkHorse came byfor a visit. 3 YEARS ago he and I had @Pullstart send us a chunk of pvc to make dual wheel spacers. Steve and I used a table saw and some patience to cut several slices about 2.25" wide. Like @ebinmaine said we finally remembered to finish a project only took 3 ish years . The spacers fit nice and came out good. Thanks to @Pullstart for the material to make them. Going to clean them up a bit and fine tune them but had to see what the C-170 could possibly look like after all this time! 5 1 Share this post Link to post Share on other sites
8ntruck 9,301 #24950 Posted November 18, 2025 Morgan, the 14-8 got tapped for lawn sweep towing duty today. The neighbor just obtained an older, but lightly used Agri Fab sweeper (for free!), so he came over with his 60" Cub Cadet zero turn hitched to his new toy to help me and sort out the sweeper setup - his leaves are pretty much taken care of through his 60" deck into the grass collected bags. The job went pretty quickly with both of us working. Once our burn area was filled up, I tended the fires and used the leaf blower to do the detail work around the fences and flower beds. We had a 'controlled burn' into the lawn at one point. I'm claiming that it was an experiment to see if that patch of grass will be healthier next year, what with the 'regenerative' properties of a forest or prairie fire are supposed to give. At one point I got caught in a sudden wind shift that singed a bit of hair off. I was raking around the edge of the fire, and must have been in some superheated smoke that flashed off when the wind shifted. 3 Share this post Link to post Share on other sites
