Eric857
Transmission problems
Eric857
Hello red square,
I restored an 857 last year and I have been having a blast with it but I have noticed a bit of a problem this past summer and and winter with the transmission. There seems to be a bit of a hesitation in the machine when it is running in 3rd gear while going up hill. The best way i can describe the problem is that it is like the tractor has oval wheels, it seems to pull then let off, pull then let off, pull then let off. I cannot for the life of me figure out the problem with it. It seems to really only happen in 3rd gear.... The other issue is that occasionally i am getting a bit of a knock on something that sounds hollow, like if i were to knock on a metal door or a hollow oil drum.
Has anyone had this issure before? Is this something that is fixable?
When I did this restoration I did not take the transmission apart at all, the only thing I did was take it off of the machine, strip it and paint it. I think that would eliminate any mechanic's error but that doesn't mean I didnt knock something out of place in any of the times I moved out around in the garage. The only other thing I did to it is put in new gear oil, it ran.
I am frustrated and puzzled, it never had an issue like this before it was restored....
Please comment whatever you think may be the issue and thanks for the help
--Eric Gell
stevasaurus
Check the usual stuff outside the transmission first.  Make sure the hubs are tight on the axles and not slipping.  Pull off the hubs and check the key ways and wood ruff keys.  Take off the belt guard and check the belt for wear, and check and clean the pulleys (with mineral spirits).  I would say that you can expect a certain amount of your 1st issue just because these horses are belt driven and there is some natural slack because of that and the tension pulley.
Your 2nd issue is more concerting.  Anything that is worn or broke inside the transmission could cause the hollow knock.  A broken tooth on an axle gear or (like I had one time) a 1533 bearing that had let loose a couple of the 1/4" steel balls from the race and they are getting popped around the trans case when they get picked up by a gear.  What ever it is...it is fixable.  :)  Check the things above 1st...but it sounds like you may want to open the transmission anyway.  If something is wrong like I stated in the trans, you could do more damage by driving it around.  You should have the #5053 transmission...not hard to go into and put back together.  Here is a link with some videos, maybe you can spot something that is making your noise.
http://www.wheelhorseforum.com/topic/25103-5085-trans-rebuild-videos-pics/
KC9KAS
That sure sounds like a hub slipping on the axle....The oval feeling is when the hub groove lines up with the key then slips over it....again and again.
Hub and axle both probably have issues and need replaced.
DennisThornton
What's already been said twice.
Going up hill is a dead giveaway!   You have a key on one hub slipping under the heavier load of climbing.  Catch it now before it gets any worse!
  • Similar Content
    • Bach-Ed
      By Bach-Ed
      I need a little part number help.   I'm looking for the part number of the idler pulley that tensions the drive belt on my 857.  The diagram shows the left side of the tractor.  And I can't seem to locate the pulley on the parts drawing.  The bearings have gone out on my tractor's idler.
    • Bach-Ed
      By Bach-Ed
      I needed to disassemble the brake/cluch linkage on my 857.   Am I missing something or do 2593 Clutch Rod, 5544 Parking Brake Lever and 3935 Brake Rod all need to be in place on 4899 Clutch Rod Pivot Arm  before I can struggle to align the holes with that of the 3950 Idler Arm Shaft to insert the roll pin?  I'm using up all my naughty words trying to get this back in place.  I'm hope someone can suggest a better way.  Or all you can do is extend your sympathies?
    • WHX??
      By WHX??
      Sadly Dan @Achto informed me the the other day of a 857 and a C-120 that was deposited at his local county dump. Dump rules are  such that once it hits the ground it stays due to junkyard dogs going to fisticuffs over scrap steel. Understandable  Despite some hastily made plans of bribery,  chicanery and/or hook or crook to rescue them we failed miserably. We may get drummed out of the Mafia for that one.
      I'll let Dan fill you in on the details if he has the stomach.  I would like to believe that that our beloved  ones would be smelted down to produce more tractors but then I wake up from that dream. Sorry no bone yard pics not that we would want to see them.
      Dan asked me if he had a problem over grieving over these lost gems. You decide... So in memoriam I feel it is quite nescessary to post pics of our lost loved ones. Since I don't have a C-120 here's what I have of a 857.  Please post your pics of either models. True story, I wouldn't hose you guys and not just fishin  for
    • Bear G
      By Bear G
      Sold all three to one guy today..
      Sad to see them go, but...
      One of the reasons I’m selling is because I’m thinning my personal collection down to custom, modified only. So,  I’m selling all my “stock” tractors.
      Ilk still have a few “flip tractors”, but hope to get down to about 4 I’m my personal collection.
      We’ve been up around a dozen for a year now.. too much to keep up with..
        I think these are going to a good home.
    • Bear G
      By Bear G
      Getting the 1st two of eight total ready to go to the show in New London, Oh. This weekend.
      the 857 and the 1054 still need some minor cleaning but they’re ready to load.
      Show is 7-27-18 to 7-29-18. Hope to see you there!!
