Alrashid2 473 #1 Posted November 21, 2025 (edited) Hey guys, been a bit since I posted here! Bought my 1980 Wheel Horse 312-8 last October 2024, and have loved getting it up and running. Had a good 6 months or so before a new problem arose! When I bought this, the Voltmeter didn't work so I replaced with an aftermarket. I know when running at WOT it was showing it charging at about 14V give or take. I happened to look down today and saw the gauge was maxing out past 16V! I took a voltmeter to the connections and saw it was indeed charging at around 16.5V, though it was jumping up and down a ton. Engine off, battery is holding at 12.7V. Had I not looked at the voltmeter, wouldn't have known there was a problem. Running perfectly fine. I love working on engines and mechanical things but electrical is my weakness. I looked at every connection on the engine I could see and everything was tight. Nothing looks to be shorting anywhere either as far as I can tell. Any ideas here? Is there a simple fix/repair for this? I am concerned 16V is way too high and will fry the battery or some other components. I appreciate the advice guys! Edit: added some photos of every electrical component I could see Edited November 21, 2025 by Alrashid2 Photos Share this post Link to post Share on other sites
pfrederi 20,060 #2 Posted November 21, 2025 How old is the battery?? Have it load tested...a weak/bad battery will confuse the regulator Share this post Link to post Share on other sites
Alrashid2 473 #3 Posted November 21, 2025 Hey pal, literally just tagged you on another post back in 2016 I believe where you said yours was reading at 16V! Funny coincidence. Did you ever figure that one out? Mine is doing exactly what you said yours did in your post: starts around 14V but over a few minutes creeps up to about 16V. How do I load test one of these batteries? Or is that something an auto shop needs to do? 1 Share this post Link to post Share on other sites
Handy Don 16,055 #4 Posted November 21, 2025 6 minutes ago, Alrashid2 said: Or is that something an auto shop needs to do? Shops and parts stores normally have a load testing tool. Both will usually test for free in hopes you’ll buy the replacement there. 😁 Of course, you want to witness the testing! BTW, the rationale for load test is that it’s common for a battery at rest (or on a maintainer) to test to a useful voltage but when under load, as when cranking to start, it cannot sustain that voltage. 2 Share this post Link to post Share on other sites
pfrederi 20,060 #5 Posted November 21, 2025 Poor mans emergency load test...Hook up your multimeter to the battery should be about 12.6 pull spark plug wire...Start cranking engine voltage will quickly drop..if it goes below 9 volts battery is toast.. 3 Share this post Link to post Share on other sites
Alrashid2 473 #6 Posted November 21, 2025 Thanks guys for replying! I saw Amazon had a replacement battery for 60 bucks, free returns, and could be here tomorrow evening... So I bought it thinking why not? I'll go try a poor man's load test now! Share this post Link to post Share on other sites
Alrashid2 473 #7 Posted November 21, 2025 Interesting Update! So, I tried the poor man's load test (Thanks @pfrederi!). Voltage on battery was 12.6V beforehand. Pulled spark plug wire, and started cranking for 5-10 seconds. Started dropping and got down to 9.2V. I stopped cranking, and immediately started cranking again. Now in the low 8.0V range and dropping, and starter was slowing down. Stopped as I didn't want to drain the battery too far and have this thing stranded in the driveway! Here's where things get interesting. I was able to start her up after reinstalling the spark plug wire. Running normally, WOT, and now the charging voltage is back to normal at around 14.5V! Again, electrical is not my strongsuit, but am I thinking correctly in that, the battery was drained, so now the excess voltage is getting "used up" to recharge it? Would this confirm it is a bad battery? I ran it for 5 minutes around the property, voltage never got above 14.5V, and once I shut her down, battery was holding at 12.6V again. I'll still order a new battery, but wondering if this was some weird fluke, a battery issue, or an issue that will rear it's head again? Share this post Link to post Share on other sites
Achto 31,307 #8 Posted November 21, 2025 This problem could also be with your regulator / rectifier. Will look like one of these. 2 Share this post Link to post Share on other sites
ri702bill 11,544 #9 Posted November 21, 2025 5 minutes ago, Achto said: This problem could also be with your regulator / rectifier. Will look like one of these. And the actual issue just may be a poor (painted, oxidized, corroded or otherwise compromised) ground at the rectifier to sheet metal mounting bolts. Many of us add a secondary ground cable from the battery negative terminal to one of the rectifier bolts. It must be properly grounded, at all times while running, for it to do its job... 2 1 Share this post Link to post Share on other sites
rmaynard 16,988 #10 Posted November 21, 2025 I have found that over charging can be as a result of poor grounding of the regulator. I've had them go as high as 23 vdc. I cleaned the back where the mounting screw goes through, and cleaned where it mounts to the tractor. Problem solved. 2 3 Share this post Link to post Share on other sites
Alrashid2 473 #11 Posted November 21, 2025 (edited) Hey guys, thanks for the advice but I don't have a regularor on mine. 1980 model so it has the 3Amp charging system. (Headlights turn off when engine off) Did you guys see my update? Any thoughts on it? Edited November 21, 2025 by Alrashid2 Share this post Link to post Share on other sites
pfrederi 20,060 #12 Posted November 21, 2025 There is no diagnostic for high charging voltage in a 3 amp unregulated system. How old is the battery?? If it has been starting the tractor OK I would cover up the silly voltmeter and forget about it. I have a 310-8 with the 3 amp system no gauges (no worry ) she has worked for a long time and battery has held up well... 1 Share this post Link to post Share on other sites
kpinnc 17,491 #13 Posted November 21, 2025 If your system charges high (16VDC) for 5+ mins directly after cranking and then tapers down to 13-14VDC, that is normal operation. Your rectifier responds directly to the load applied to it, and cranking definitely zaps alot from a battery. It takes a few minutes to settle back down sometimes. If it charges high all the time, then you have a bad connection or possibly a battery going south. Share this post Link to post Share on other sites
JCM 10,984 #14 Posted November 21, 2025 1 hour ago, Alrashid2 said: 1980 model so it has the 3Amp charging system. FYI First year for a 312-8 if my memory serves me correct was 1985. A year after the Black Hoods stopped producing. 2 Share this post Link to post Share on other sites
953 nut 64,636 #15 Posted November 22, 2025 Here are the wiring diagrams for your model. Share this post Link to post Share on other sites
Alrashid2 473 #16 Posted November 22, 2025 (edited) Hey all, thank you all so much for weighing in! @kpinnc funny enough mine is doing the opposite. Start her up and get to WOT, and she charges at about 14.0V for 5 min, then once she's warmed up it slowly starts creeping up to 16+V and settles there. @JCM thanks for correcting me, ugh! I'm usually really good with numbers. I did know it was a 1985. I was just telling a friend about my Remington 870 Wingmaster I recently restored, which is a 1980, and I think I had that number stuck in my head @953 nut thanks for sharing that! I have trouble comprehending these diagrams but I'll tuck away just in case @pfrederi I think I'm going to take your advice. Hell, the voltmeter didn't even work on it originally and previous owner said he didn't notice it ha! Bothers me that it was running at 14V and recently changed, so I wonder what changed, but if she keeps chugging along I'll run with it! I'll got an update today. Got the new battery in. I also ordered a new starter solenoid. Can't remember if I posted here, but I was checking all of my connections and thought the positive lead on the starter solenoid was a hair loose. Went to tighten it, and it snapped the brass(?) bolt halfway down the threads... ugh! I was going to replace it, but then realized that the mounting bolts have nuts on the inside end I'm having trouble getting my hands into, and really don't want to pull the dash covers to get there. I ended up just removing the thicker inside nut/washer to gain more thread space, replaced it with a thin washer, and found a spare nut that was thinner and had the same threads to clamp the positive wires back down. Think there is any issue to that? It's starting fine. Figured why replace the entire thing if it's working! Attached a photo of the end result. Anyway... put in the new battery. Did the Poor Man's load test before anything. Wow, it passed! Never dropped below 11V I think, and man it was cranking much faster and staying there! I think my battery has been bad since I bought it last year because this thing is cranking maybe 3 times as faster than it ever did! I just thought these Wheel Horses were slow to crank New battery in, but unfortunately high charging still the same... after a few minutes of warmup, goes from 14.V to 15.0V and ends up at about 15.9V and stays there, within 5 min or so of running at WOT. As @pfrederi said I think I'll just roll with it. Everything working as it should. Does anyone know what symptoms would come from overcharging too long, so I can keep an eye out? Is the worst case that I just weaken the battery over time? If that's all, then no biggie to me. This battery was 60 bucks and if it lasts a few years I'm happy! Thanks all Edited November 22, 2025 by Alrashid2 Photo 1 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,066 #17 Posted November 22, 2025 Although no longer available from Toro I suspect a two-wire regulator 790292 from Briggs & Stratton would work. Share this post Link to post Share on other sites
kpinnc 17,491 #18 Posted November 22, 2025 (edited) 2 hours ago, Alrashid2 said: Everything working as it should. What does the battery itself settle at? With the tractor switched off, your battery should be about 12.6VDC. I would think anything between 12.2 and 12.8VDC would be ok. Check it with a multimeter, not through the key switch and on board voltmeter. Edited November 22, 2025 by kpinnc 1 Share this post Link to post Share on other sites
Alrashid2 473 #19 Posted November 22, 2025 8 minutes ago, kpinnc said: What does the battery itself settle at? With the tractor switched off, your battery should be about 12.6VDC. I would think anything between 12.2 and 12.8VDC would be ok. Check it with a multimeter, not through the key switch and on board voltmeter. Yup I checked with a multimeter. My dash gauge is pretty close to accurate. Off the battery is at 12.6V. will monitor! You guys think my starter solenoid is ok like this? Share this post Link to post Share on other sites
Handy Don 16,055 #20 Posted November 23, 2025 3 hours ago, Alrashid2 said: You guys think my starter solenoid is ok like this? As long as there is clean electrical contact and the cable lug stays nice and snug, it’ll do just fine. Good on-the-fly remediation! 1 Share this post Link to post Share on other sites
Alrashid2 473 #21 Posted November 23, 2025 14 hours ago, Handy Don said: As long as there is clean electrical contact and the cable lug stays nice and snug, it’ll do just fine. Good on-the-fly remediation! Thanks for weighing in! I got it nice and tight and I put a sharpie witness mark too to double check it doesn't loosen up! Share this post Link to post Share on other sites
