davem1111
Oh, these pesky decks and spindles....
davem1111
I thought I'd circle back and see if I can fix a 42" deck (05-42MS05) that came off of one of my previous tractor purchases. I got the blades off and the bottoms of the spindles look good, and it needs some metal welded on where the wheel height adustment bracket bolts on. No big deal.
The problem I'm having now on this deck is that I can't get this one spindle off. I haven't gotten the others off either, but they seem to be fine. This pulley is flopping around and obviously needs help. I've tried heating it with a torch after spraying it with penetrating spray numerous times, and it won't budge.  At this point, I'm thinking that I'll just need to grind it off, right through the spindle shaft, unless I can successfully cut through the thick ring without damaging the spindle shaft. If I have to grind through the pulley, it probably doesn't matter because I think it's shot already. Anyone have any other ideas?
One question:  Is that thick ring supposed to be part of the pulley? This one is detached and the pulley spins freely (and sloppily).  Assuming I'll need to buy a new pulley, but was hoping not to have to buy another spindle shaft also. I did take the grease zirk off and have hammered on the top some, but only with a block of brass in between. It could already be damaged there.
The picture doesn't help much, but here it is:
Snoopy11
Do you have any MAPP gas handy? :confusion-confused:
Don
davem1111
Don
That's what I've been using to heat it -  MAPP + Oxygen.
Snoopy11
Oh oh... okay... sorry, I was thinking propane when you said "heating" it... :bow-blue:
Have you thought about a 3 jaw puller? :scratchead:
three-jaw-puller-4-100-mm-kb071202-1649534974.jpg.1be6c47a23a5473f0f4323b911821e82.jpg
Don
Edited by Snoopy11
davem1111
Have you thought about a 2/3 jaw puller? :scratchead:
Don
Well, thought about, yes. :eusa-think:    Okay, more than thought.  The one I have doesn't have arms long enough to reach under the pulley with the center bolt on top of the spindle shaft, and even if I did, my guess is that it would just bend the crap out of the pulley.  There's not enough room to get the teeth under that thick center ring, which is what seems to be rustwelded to the spindle shaft. Maybe I could buy a specialized puller that would work but it may cost me as much as a new spindle shaft.  Yeah, I know, tools like that will likely come in handy multiple times, but then if I damage the shaft anyway I'll be buying both. :doh:
Snoopy11
That may happen... but I've actually been surprised in the past of how --once you get some pulling juice on pulleys... they just come right off...
It may just be a matter of 1 little pull, and it will loosen and come off... :eusa-think:
Oh, and the pullers from Harbor Freight are pretty cheap...
3 pack:
8 inch puller...
Don
stevasaurus
You will bend or break the pulley with a 3 jaw puller.  You need a hydraulic press.  If you do not have access to one, you might try an auto shop or a machine shop.  Hit them on a slow day, and they might do it for nothing.  :confusion-confused:
Snoopy11
That... or an air hammer...
Don
peter lena
@davem1111  second  deck pully picture , 2 pry  bars , evenly pushing a lubricated  pulley off spindle shaft , bolt head on deck acts like a rocker with the curved bar  pushed right up against the center of pulley hub , thats the strongest lift push area , also no pulley damage . done this on a number of decks , while i,m in there , that the time to lucas green grease the bearings, no noise / failure , pete
davem1111
Pete - much appreciated, but... I've tried the 2 pry bar approach and all it does is bend the pulley.  This deck must have sat outside for a very long time. So far, multiple hits of Liquid Wrench and PB Blaster, plus MAPP + Oxygen heating, does not get this pulley to budge.
I think I'm concluding that I'll have to try to cut into that ring from the sides to split it, hopefully without damaging the shaft, but if I do I'll buy another shaft.  The deck is useless and unrepairable unless I can get that pulley off.
peter lena
@davem1111   you  must be really dealing with solid rust , done 3  decks , with easy pulley removal , if you use a power cutter wheel , be very careful dot to damage the shaft , side cuts will probably let you pry and split the rest .if you do rebuild those spindles , repack those new bearings with lucas xtra hd , hi temp 560 deg  grease . and also rebuild your mule drive bearings , same thing , no noise , no failures , pete
ineedanother
@davem1111   you  must be really dealing with solid rust , side cuts will probably let you pry and split the rest
That pulley is likely spent at this point so I agree with @peter lena, notch and chisel might be your most expedient solution at this point. Not pleasant but a product of recycling this old equipment. Simply preserving the integrity of the shaft might need to be your focus and priority now.
  • Similar Content
    • GeoC-120
      By GeoC-120
      The time has come for me to part with my trusty Wheel Horse and find it a new home. I am the second owner (since 2003) and it has always been stored in a garage.
      I am located about 2.5 hours Northeast and 140 miles from the Big Show for those who are attending.
      1975 C-120 Special, 8-speed (Model 1-0375, Ser. # 133357). Running (no smoke) 12 hp Tecumseh (Model HH120-120180E, rebuilt 1986). Rebuilt carb, new fuel pump, and new ignition module (in 2006). Good used replacement tank, original tank is included in the sale.  Brand-new battery, fuel filter, and shutoff valve installed 5/26. The transaxle case is cracked near the center flange and repaired with JB Weld.
      Solid 42” side discharge deck  (Model 5-1010) bearings replaced in 2005. Extra set of Gator mulching blades and spare hi-lift blades included.
      42” snow/dozer blade (Model 86-42bc010),  with Rear weights, tire chains and hardware.
      Parts: 4 NOS belts and 2 good used belts, NOS taillight lenses, used starter, used ignition module, more (see pic).
      1975 C Series Owner’s manual, 1975 WH accessory catalog, 5-1010 deck manual, original HH-120 manual, updated Tecumseh HH-120 technicians handbook.
      Selling entire package for $350 Or Best Offer
      Deck/Blade/Weights/Parts alone are worth that!
      Please PM to contact
      HH120_running.mp4
    • morePEdal
      By morePEdal
      *16 HP Onan Engine, 665.4 Hours
      *8 Speed Transmission
      *48” Snow Plow- Works Great! Set up and READY TO GO BEFORE THE SNOW!
      *Nice 42” Mowing Deck, no rot or welds, smooth spindles
      *OEM Wheel Weights, 50 lbs. Each
      *Chains
      *Valves adjusted this summer, runs great!
      *Good battery
      *Tires All Hold Air
      *LED lights all the way around
      *Manuals included
      Bought a Honda tractor with 4WD and 4WS with deck, plow and snowblower so I don’t need this tractor.
      Cash Only!
      *WILL NOT RESPOND TO “IS THIS STILL AVAILABLE?”
      *COMING SOON:  Also selling a Wheel Horse 520H with a 2-Stage Snowblower. Check out that listing if you want a snowblower garden tractor!
    • cJ_3D
      By cJ_3D
      Hello helpful Wheel Horse enthusiasts!
      Maybe you all could help me figure something out. I don't think I am installing the mower deck properly on my 1989 252-H and I don't know if the PTO clutch is adjusted right.
      So referencing this image here from the service manual for the mower deck (37"):
      What exactly am I doing with this adjustment knob and how does it fit into this piece?
      Also for the PTO clutch where am I sticking the feeler gauge exactly and do I need to do all 3 springs? Or does adjusting the one in the manual adjust all three?
      Much obliged for the help!
      CJ
    • rustyedge1
      By rustyedge1
      Old gear drive covers in used condition.
      PM for details
      PayPal preferred, other payments accepted.
    • lsc1257
      By lsc1257
      I have a 1996 520H Wheel Horse for sale.  The tractor has just over 800 hours on it.  It comes with a 48 inch deck.  The deck is a 1995 and has over 1,500 hours on it, as it came brand new with my 312-8 that I sold several years ago.  This 520-H has the swept front axle so it can handle a 60 inch deck.  I just replaced the battery and the deck belt this summer.  The engine is a 20HP Onan and it starts right up but requires the full choke.  The transmission is an Eaton 1100-062, hydrostatic.  The deck is in rough shape but the spindles appear to be in good working order.  The right rear tire has some cracking.  The original operator's manual for the 520H is included, as is the original operating and maintenance instructions for the deck, plus the installation instructions for the deck.  Also included is a new PTO belt and several miscellaneous deck wheels and rollers.  Additional pictures available upon request.  Asking $500.
