midpack 1,148 #1 Posted June 6, 2022 FYI, I was at NAPA picking up some of this and the counter guy said they can't get any more. Made it sound like it's NLA. 1 Share this post Link to post Share on other sites
adsm08 5,153 #2 Posted June 6, 2022 I've been running into that as well. Can't find the stuff anywhere. I've gone to the Valvoline red, which is similar, but not as thick. Share this post Link to post Share on other sites
ZXT 2,402 #3 Posted June 6, 2022 11 minutes ago, midpack said: FYI, I was at NAPA picking up some of this and the counter guy said they can't get any more. Made it sound like it's NLA. May not be NLA, but it could be supply chain issues.. We're still having trouble getting electrical supplies and usually have to go to 4-5 parts houses before we can get what we need for a job. My local O'reillys has been out of copper coat for 6 months. Share this post Link to post Share on other sites
SylvanLakeWH 32,598 #4 Posted June 6, 2022 @peter lena you got this unacceptable situation under control? 1 1 4 Share this post Link to post Share on other sites
squonk 48,152 #5 Posted June 7, 2022 My Wal-Mart shows it in stock Share this post Link to post Share on other sites
peter lena 10,076 #6 Posted June 7, 2022 @midpack https://www.autozone.com/greases-and-gear-oil/multi-purpose-grease/p/lucas-oil-products-red-n-tacky-grease-14oz/693860_0_0 , they have it in stock , napa , usually is not up to date with a number of things , eliminated them for higher pricing and lack of stock. , also on line . Walmart has it in stock , Walmart super stores , has a larger stock , of everything , even ROTELLA 5-30 OIL . like the red aerosol , with spray tube extension , CRC also makes it .@ SYLVANLAKEWH , thanks for the heads up, scary , when there is an uncontrolled lubrication situation , greasy ,pete 1 3 Share this post Link to post Share on other sites
rjg854 13,376 #7 Posted June 7, 2022 11 hours ago, squonk said: My Wal-Mart shows it in stock they might show it in stock, but I haven't seen it on the shelves in months Share this post Link to post Share on other sites
squonk 48,152 #8 Posted June 7, 2022 10 minutes ago, rjg854 said: they might show it in stock, but I haven't seen it on the shelves in months Napa shows 6 tubes available for afternoon. 5 in Macedon. 10:30 order cut off Share this post Link to post Share on other sites
peter lena 10,076 #9 Posted June 7, 2022 @rjg854 when I was on the hunt weeks back , auto zone had just about every lucas lube in stock ! every grease , gear oils , etc . when you find it , get it , find lubrication is the life of these old units , or death with lack of / neglect / wrong rating lubricant . that hi temp bearing grease , is vital , with clean out of original grease , its 560 temp , in that mule drive area / spindle bearings , get very hot , and fail , the other neglected needle bearing in the pto end cone, outer edge area , also needs the upgrade . think about it , insuring a stay with it lubricant , to every hi stress part , I also detail the pto lever rod area , that rusty trundle gets washers to firm it up . converted mine over to heim joint , use a 3/8x 24 die nut over existing 3/8x16 threads , oil lubrication , heim joint screws right on , easy ! also washered up lever starting point , next to battery , eliminated sloppy play , of course grease , solid smooth , pete Share this post Link to post Share on other sites
