colbyeast
engine rebuild
colbyeast
Looking for someone in the Northeast (New England area) that can look at my Kohler Magnum 14 ( over 2000hrs
)had rebuilt about 2 years ago (very little hours after rebuild)it's now blowing white smoke and going through oil, (checked breather :ok; cylinder has carbon build up no wear on cylinder wall) Could it be rings gone?Also needs carb work (throttle linkage very loose) Thanks in advance
Maxwell-8
rings or the valve guides
Retired Wrencher
Colby if you like and have the $$$ you can go to a dealer. Meaning where they did sell wheel horse. There is one in Amherst Ma that does good work ask for Tim. Also, there is a dealership section here to look up. Hope this helps.
Edited by Retierd Wrencher
squonk
Make sure gas isn't getting into your oil.
  • Excellent 1
ebinmaine
Can you take any video of the carb linkage?
Are you looking to do the engine work yourself or have a shop do it?
I have one here in Southern Maine I trust. Not sure if they get into internal engine repairs.
953 nut
As Mike said, a small leak in the fuel pump diaphragm can allow gas into the crank case and dilute it. Change the oil using 30 weight and fix up a gravity feed fuel tank directly to the carb. as a test. If the smoke clears up you need to replace/rebuild the pump.
  • Like 3
colbyeast
Looking for a shop to do the work . Anyone have suggestions ? Who would you trust ? Bought tractor new many years ago  want it to run for many years to come.
ebinmaine
Rick n Ray's is in Buxton Maine.
About an hour and 20 to 30 minutes from you.
Chuck there, is the fella who got me into Horses.
IIFF they'll do the work I'd bring it there.  Period.
Tell them Eric Banks sent you.
They may curse me out :ROTF:
but they'll be THE BEST recommendation I could possibly give.
pacer
From your description I dont think you have a major problem (rod loose, grenade gears, broke cam, etc) so valve guides, broken ring/s, similar shud get you back going -- cause the engine is still running with only the smoke prob and, hopefully, a relatively easy fix.
colbyeast
Here are some pictures of carburetor.  Could this be my problem? Exhaust  has rich smell of gas. Would you reccomend  one of those from isave website?Video to follow.
squonk
I would rebuild that carb before I even considered a new one. Have you checked your oil for gas yet?
ebinmaine
:text-yeahthat:
I'm not a fan of the new aftermarket carburetors. Had four.
None were any good.
I mean that literally. I'm not trying to be negative. I actually had zero out of four that went well for me.
I do realize lots of us have used them on smaller engines and had good luck. Just wasn't me.
32 minutes ago, colbyeast said:
Video to follow
That's going to be the important part.
Take a look at this video and see if your carburetor is worn at the bottom AND top?
  • Excellent 2
colbyeast
 it is wore both at the top and bottom. Was told by dealer that it couldn't be rebuilt
Jeff-C175
Oh HORSE POOP!
Any good mechanic can ream and install bushings on the shafts.  IF THEY WANTED TO.
He's just saying that HE doesn't want, or know how to, install the bushings.
ebinmaine
19 minutes ago, Jeff-C175 said:
Oh HORSE POOP!
I'll second that.
I can install bushings on the top. The bottom ones I don't have the machinery to do.
As far as getting another carburetor...
In all seriousness I would spend 10 times the money on an older one all day every day.
You can get a hold of Lincoln at A to Z Tractor in Pennsylvania and he may have one down there.
  • Excellent 2
Jeff-C175
6 minutes ago, ebinmaine said:
I'll second that.
Yeah, this one is a real mess!
I might...repeat... MIGHT consider drilling through and installing the bottom bushing from the bottom, and then closing the hole with a welch plug.
I have little doubt that the SHAFT on that carb is worn out also and that installing new bushings would be pointless unless you replaced the shaft also.
  • Excellent 1
Snoopy11
@Jeff-C175 and @ebinmaine... you guys each give me 40 lashes if you think this is a dumb comment. :teasing-whipyellow:
BUT... what about...for the bottom hole, buying a little bushing... cutting a slit in the side, so that it fits around the shaft... and pressing it down into the hole?
Not like this... but you get my idea... I hope... :)
Bushings & Bushed Bearings 1.25 Length Inch Standard ...
Maybe even split bronze bearings...
Split Bronze Bearings- Variations and Applications - National Bronze Manufacturing
Some'in like 'at... :dunno:
Don
Edited by Snoopy11
ebinmaine
9 minutes ago, Snoopy11 said:
Some'in like 'at...
I can see your idea in principle but I don't know enough about machine work to understand how to do it.
That is most likely true but it's important to remember that the shaft is made out of a much harder material.
I have had some older Kohler carbs with the top that was just garbage and the shaft was okay after the washers were installed. But I've never had one with the top AND bottom worn out like this and tried to fix it.
  • Excellent 1
rmaynard
When the top bushing is worn and you have a lot of slop, the engine will run lean because it is pulling air in alongside the shaft. Lean burn won't make smoke, but it will make the engine hotter. The hole at the bottom where the shaft sits does not have to be air tight because there is nowhere to pull air from. So, when I have a sloppy bottom hole (hold the comments), I make a shim from shim-stock just thick enough to keep the shaft centered. It won't come out because the butterfly plate will keep it in place. Also I have found that throttle shafts are pretty easy to find. 50% of used carbs that you find for sale at shows and on eBay have decent shafts.
  • Like 3
  • Excellent 2
Snoopy11
3 minutes ago, rmaynard said:
hold the comments
Okay... but...
:shifty: :silence:  :omg: :jaw:
Yep, basically what I am thinking... :whistle:
Don
Jeff-C175
I think that would certainly work.  The hardest part would be drilling out the bottom hole.
You could go through with a long bit from the top, but what if the bottome needed to be drilled LARGER than the top?  In that case you would have two choices,  drill the top as large as you need to drill the bottom and fit larger bushings.  or, drill a pilot through from the top so the two bores were aligned and then drill up from the bottom.  I'l have to look again to be certain, but as I recall, these carbs have a round flat spot on the bottom where the bottom shaft fits into a 'pocket' of sorts.  Then you could easily mill a recess on the bottom to fit a welch plug.
But yeah, a split bushing on the bottom would be fine, I'm sure, because it doesn't need to 'seal' anything, and there is zero real load to speak of.  You could probably press a split bushing in with your finger.  But if you did drill up from the bottom, you could also easily install a solid bushing too.
[edit:  might not be able to do that.  The hole would be right close to where the bowl seats, at least on this one:  image.png.013d42a240fe6c9ad7e06db0aa2bb750.png  ]
Edited by Jeff-C175
  • Excellent 1
Snoopy11
I guess it just goes to show... it can be done... you just have to "want" to do it...
Don
Wheelhorse#1
Doesn’t hurt to try fixing it.But
I would stay away from aftermarket carbs.I bought one and it wouldn’t adjust properly out of the box.
If you can’t repair buy a original used one…A To Z tractor good place to start.
oliver2-44
There is a guy that does the machine work to rebuild Kohler carbs. Go to: carbrescue.com
Ive spoke with him and he pulls all the Welch plugs and cleans passages that don’t normally get cleaned
Edited by oliver2-44
  • Like 3
  • Excellent 1
colbyeast
Replacement carburetor coming from AZ tractor.  Pics of valves and piston after light cleaning
  • Similar Content
    • Spottedeventer
      By Spottedeventer
      Hi! The shafts of my fathers old 314-8, deck number 73449 have worn to the point the blades don’t stay secured. I’ve struck out tonight trying to find a part number. If anyone can assist, I would greatly appreciate it.
      thank you,
      Patricia
    • ryobi.warrior
      By ryobi.warrior
      The belt on my Wheel Horse 314-8 mower deck (05-37SC01) appears to be contacting the deck bracket between the spindle pulleys. I am a novice when it comes to Wheel Horse maintenance (at best), but this does not seem correct.
      I recently inherited this Wheel Horse, so I do not know the maintenance history. Unfortunately, the mechanic who previously worked on it was a no-show for a scheduled maintenance visit.
      Any advice on how to address this? Thanks in advance... this seems like a great forum and I'm looking forward to spending time here!
      Photos (please forgive the dirt and grime, I plan to clean it up!): https://imgur.com/a/4PknZuJ
    • ashtonosborne2019
      By ashtonosborne2019
      I just got a 1993 toro wheel horse 314-8 today for free. It seems to be in good working order hasn't ran since last summer. Came with a mower deck, rear wheel weights, and a snow plow. My plan is to take the transaxle out if i don't like the motor and put the trans in my 520-h hopefully it works. Is there any pointers you guys could give me i would really appreciate it... thanks.
    • Fishkill-Will
      By Fishkill-Will
      My 1998 314-8 is not starting after stalling while engaging the PTO clutch for snowblowing. It started easily and warmed up well. The stalling didn't seem like a big deal but then it just refused to start. Lights light up and I hear a click. Wondering if this sounds like a PTO clutch safety switch issue and if that should be my first place to look?
      Fuses look fine.
      A few weeks ago when I installed the snowblower it stalled in the same manner. I took off the snowblower belt and put it back on and it started and ran well. No such luck this time. Maybe the switch was on the fritz? Had no issues all summer mowing.
      If it is a battery or starter issue it would seem like quite a coincidence that it happened right when I tried to blow snow. Like I said, it started like a champ.
      Seat switches have been non-functioning since I got the machine. I assume the previous owner bypassed them.
      Any thoughts appreciated. I am not at all familiar with the PTO switch or the wiring.
    • OldWorkHorse
      By OldWorkHorse
      Working on a custom light bar for the recently restored 314-8
