41chevy 74 #1 Posted December 10, 2021 When restoring what order do you use? I’ve taken my B 80 completely apart and stripping everything but the frame. I’ve got a couple questions I plan on painting inside and outside on each piece, and hopefully not scratch anything putting it back together. Correct? What do you do with bolts? I’m removing paint from bolts, nuts, and flat washers, and replacing any that need to be. What procedure do you use to get the bolts red again? If I paint them before hand the wrench’s will take the paint off and I won’t be able to paint them afterwards, unless I paint with an artist brush. Your thoughts please. 1 Share this post Link to post Share on other sites
Achto 32,844 #2 Posted December 10, 2021 (edited) 8 minutes ago, 41chevy said: Your thoughts please. It can get pricey but I like to replace all visible hardware with stainless. This allows you to service the tractor without having to touch up hardware every time. Other wise, paint your hardware with one or 2 coats of paint and then brush touch them after installation. Edited December 10, 2021 by Achto 8 Share this post Link to post Share on other sites
953 nut 69,824 #3 Posted December 10, 2021 3 minutes ago, 41chevy said: If I paint them before hand the wrench’s will take the paint off and I won’t be able to paint them afterwards, unless I paint with an artist brush. What you have described is the way to go, a small brush at the end of assembly works fine. When painting both sides of sheet metal I always paint the inside first, let it dry a day and then sand overspray off the topside and paint it. If you paint both sides of sheet metal at the same time the evaporation of solvents from both sides at the same time can cause one side or both to blush. 4 Share this post Link to post Share on other sites
ri702bill 13,196 #4 Posted December 10, 2021 What I found works pretty well is to take a piece of corrugated cardboard and using a tapered t handle reamer make snug fitting holes to push the fasteners into up to their heads - a 2 inch spacing allows you to paint all 6 sides of the hexbolts - and not the threads. Bill 4 Share this post Link to post Share on other sites
WHX?? 58,307 #5 Posted December 10, 2021 Like Dan I tend to favor stainless on my restos. We use a lot of those 1/4-20 bolts with the 3/8 head much like the orginals. Get them mail order from Wally world of all places! A neat trick he taught me is with those or any bolt for that matter is use a nylon washer under the head to protect. I wash my decks a lot so they get all stainless fasteners. Another trick on painted hardware is put a shop rag between the head and the socket. Helps but some touch up is always gonna be needed. 5 Share this post Link to post Share on other sites
41chevy 74 #6 Posted December 10, 2021 Thanks guys, some good advice! Steve 2 1 Share this post Link to post Share on other sites
Achto 32,844 #7 Posted December 11, 2021 21 hours ago, 41chevy said: Thanks guys, some good advice! Steve One note : If you decide to go the stainless route, avoid using a stainless nut with a stainless bolt. Often times this will end up giving you some thread binding issues and make it difficult if not impossible to remove them at a later date. 6 2 Share this post Link to post Share on other sites
lynnmor 9,051 #8 Posted December 11, 2021 36 minutes ago, Achto said: One note : If you decide to go the stainless route, avoid using a stainless nut with a stainless bolt. Often times this will end up giving you some thread binding issues and make it difficult if not impossible to remove them at a later date. The problem is real, but the use of a stainless steel assembly paste should prevent the problem. 6 Share this post Link to post Share on other sites
41chevy 74 #9 Posted December 11, 2021 Good point about ss, I learned that the hard way a few years back but had forgotten. Thanks 3 hours ago, lynnmor said: The problem is real, but the use of a stainless steel assembly paste should prevent the problem. 3 hours ago, lynnmor said: The problem is real, but the use of a stainless steel assembly paste should prevent the problem. 1 Share this post Link to post Share on other sites
c-series don 12,524 #10 Posted December 11, 2021 I’ve heard about putting a couple of drops of oil on the bolts before assembly of stainless hardware to prevent that? 1 Share this post Link to post Share on other sites
Achto 32,844 #11 Posted December 11, 2021 9 minutes ago, c-series don said: I’ve heard about putting a couple of drops of oil on the bolts before assembly of stainless hardware to prevent that? Believe it or not a little blue Loctite will prevent this as well. 3 Share this post Link to post Share on other sites
Horse Newbie 7,405 #12 Posted December 11, 2021 On 12/10/2021 at 8:04 AM, ri702bill said: What I found works pretty well is to take a piece of corrugated cardboard and using a tapered t handle reamer make snug fitting holes to push the fasteners into up to their heads - a 2 inch spacing allows you to paint all 6 sides of the hexbolts - and not the threads. Bill This is my method also… 1 Share this post Link to post Share on other sites
WHX?? 58,307 #13 Posted December 12, 2021 (edited) 13 hours ago, Achto said: One note : If you decide to go the stainless route, avoid using a stainless nut with a stainless bolt. Often times this will end up giving you some thread binding issues and make it difficult if not impossible to remove them at a later date. The Squonky @squonk calls this galling and as much as I hate to admit he is right......he is right. Even the small amout of heat generated by two pieces of raw stainless sliding together can sieze the the fasteners together forever. Especially with the larger sizes 5/16 and above. I use antisieze but think any lubricant would be ok .... what say you lube police @peter lena? Joke here @Achto if any thing over 1/4" grease her up like @Pullstart s plow handle ! Edited December 12, 2021 by WHX?? 1 Share this post Link to post Share on other sites
Achto 32,844 #14 Posted December 12, 2021 16 minutes ago, WHX?? said: Joke here @Achto if any thing over 1/4" grease her up like @Pullstart s plow handle ! 2 Share this post Link to post Share on other sites
JCM 11,419 #15 Posted December 12, 2021 I use the cardboard method myself for hardware with 1 coat of primer and 2 coats of finish. Good results with small artist type brush for touch ups if needed @41chevy 3 1 Share this post Link to post Share on other sites
peter lena 10,091 #16 Posted December 12, 2021 @WHX?? agree with the stainless never seize lubricant , the stainless I use is the real thing , 316 -food grade stainless , left over from my work days , not the Chinese garbage they sell today , always flat washer it during build , no galling at any point , smooth threading , no problems, pete 4 Share this post Link to post Share on other sites
peter lena 10,091 #17 Posted December 12, 2021 @JCM nice lay out there , regularly detailing the hell out of any set up I use makes it work easier / better . that lucas x-tra heavy duty , green chassis grease would save every part of that , also use in the pto inside needle cone bearing , like butter. OPPORTUNITY for you to enhance the pto lever handle ,at your build state . look at the sloppy end of the pto lever , under battery area ground rail mount hole. added 3/8" or more washers and lube to firm up the play at lever end , 3 of mine are very solid and smooth in the lever engagement , also enhanced all related movement areas , also added heim joint at foward lever end , scary how easily that lever set up works , just what I do, keep it greasy , pete 5 Share this post Link to post Share on other sites
kpinnc 19,012 #18 Posted December 13, 2021 Everyone has given good pointers. So I'll add a few more: I love stainless too, but take care where you use it. It isn't a good electrical conductor, so don't use it where you're grounding, or around the engine. When in doubt, grade 8 is your friend. Buy by the pound at TSC. Wheel Horses use 3/8, 1/2, and 1/4 on dang near everything. Another tip to help prevent marring paint as well as protecting decals: turn flat washers concave side up. Won't dig into paint as much, and won't wrinkle decals nearly as much. Use anti-sieze on everything. If you have to go back into something, makes life better! 3 Share this post Link to post Share on other sites
Southern_Secret 464 #19 Posted December 13, 2021 On 12/11/2021 at 7:13 PM, WHX?? said: what say you lube police @peter lena? @WHX?? I'm not sure @peter lena is knowledge in this area 1 Share this post Link to post Share on other sites
peter lena 10,091 #20 Posted December 13, 2021 @Southern_Secret, there is a specific stainless ,never seize, should help, its the lack of real stainless in the " stainless fasteners " today , that creates the problem , Chinese standards are anything they can make and sell , bolt standards do not exist for them . my friends repair shop , has nut / bolt problems every day , nothing fits , threads curl off retainers , nuts are deformed on the sides to lock onto threads , so now you cannot repair that again , great idea. the real industrial 316 ,food grade stainless , hardware I have left is , bombproof , you will probably have to try and find anything old / new stock , deal . get new steel bolts and never seize them , experiment , remember that today is the good old days , for people coming up , very scary , pete 3 Share this post Link to post Share on other sites
WHX?? 58,307 #21 Posted December 13, 2021 10 hours ago, kpinnc said: I love stainless too, but take care where you use it. It isn't a good electrical conductor This I did not know Share this post Link to post Share on other sites
kpinnc 19,012 #22 Posted December 13, 2021 1 hour ago, WHX?? said: This I did not know Yep- check continuity on a SS bolt with any old multimeter and compare with regular old steel. Then put a magnet to both and see which one sticks... Don't get me wrong- stainless bolts on a battery are great if used to hold terminals and lugs together. Just make sure stainless is NOT the conductor itself. 2 Share this post Link to post Share on other sites
WHX?? 58,307 #23 Posted December 14, 2021 6 hours ago, kpinnc said: Don't get me wrong- stainless bolts on a battery are great if used to hold terminals and lugs together. Guilty as charged but I seldom do a connection with out a star washer between the lug and battery post no matter the fastener material. 1 Share this post Link to post Share on other sites
kpinnc 19,012 #24 Posted December 14, 2021 36 minutes ago, WHX?? said: Guilty as charged but I seldom do a connection with out a star washer between the lug and battery post no matter the fastener material. That's perfectly fine- so long as the star washer is regular steel. 1 Share this post Link to post Share on other sites
Southern_Secret 464 #25 Posted December 14, 2021 16 hours ago, peter lena said: there is a specific stainless ,never seize, should help, its the lack of real stainless in the " stainless fasteners " today , that creates the problem , Chinese standards are anything they can make and sell , bolt standards do not exist for them . my friends repair shop , has nut / bolt problems every day , nothing fits , threads curl off retainers , nuts are deformed on the sides to lock onto threads , so now you cannot repair that again , great idea. the real industrial 316 ,food grade stainless , hardware I have left is , bombproof , you will probably have to try and find anything old / new stock , deal . get new steel bolts and never seize them , experiment , remember that today is the good old days , for people coming up , very scary , pete @peter lena The info you have stuffed in that head of yours never stop amazing me! This is your wprld and we are all just living in it P.S. im sure you know i was in my last post 2 Share this post Link to post Share on other sites
