Bill D 2,587 #1 Posted September 26, 2021 Has anyone used the double drive pulley for the power flow bagger to increase the blade speed on their 48" deck? If I have the right part number its 110-6502. I was thinking about using it in place of the center pulley to increase blade tip speed to be more inline with the commercial decks. I believe it has a smaller diameter pulley on the top. Thanks. Bill 1 Share this post Link to post Share on other sites
Bill D 2,587 #2 Posted October 6, 2021 Doesn't anyone have an opinion about this idea? Good or bad? Thanks. Share this post Link to post Share on other sites
Cee245 852 #3 Posted April 5, 2022 @Bill D haven't tried or thought of that, but I'd be interested to see how it works out. Did you end up trying it out? Share this post Link to post Share on other sites
Bill D 2,587 #4 Posted April 5, 2022 I have a pulley, but I haven't tried it yet. I haven't had time. 1 hour ago, Cee245 said: @Bill D haven't tried or thought of that, but I'd be interested to see how it works out. Did you end up trying it out? Share this post Link to post Share on other sites
John c 135 #5 Posted April 9, 2022 I've kinda thought along the same line as this to increase the blade speed on a 42"SD on my 314-8 to archive a better cut. I too would be interested in hearing what others have tried or any thoughts they have to share Share this post Link to post Share on other sites
Bill D 2,587 #6 Posted June 29, 2025 (edited) On 4/4/2022 at 10:11 PM, Cee245 said: @Bill D haven't tried or thought of that, but I'd be interested to see how it works out. Did you end up trying it out? I finally tried it out. Works great! It will require use of a 102" belt instead of the regular 103" belt. Probably not the safest idea though. Edited June 29, 2025 by Bill D 2 Share this post Link to post Share on other sites
cleat 8,716 #7 Posted June 29, 2025 That is how I am running my 48" deck right now. Blade speed is about the same as the new zero turn mowers so I think safety is fine. The Onan is happy running around 3000 to 3200 rpm so that is where the engine speed normally is when I Mow so the pulley change works well for me. Share this post Link to post Share on other sites
peter lena 9,720 #8 Posted June 30, 2025 @Bill D @JOHN C. what did you do to enhance / insure bearing life ? have any belt bounce support on , long unsupported belt run ? how easily does it move , from initial engine to unit , by hand ? replace trunnion , with a heim joint ? just a couple of things regularly added , to my belt driven anything . no whyining bearing noise or belt bounce , always testing / trying for improvement , pete Share this post Link to post Share on other sites
Bill D 2,587 #9 Posted July 2, 2025 On 6/30/2025 at 9:50 AM, peter lena said: @Bill D @JOHN C. what did you do to enhance / insure bearing life ? have any belt bounce support on , long unsupported belt run ? how easily does it move , from initial engine to unit , by hand ? replace trunnion , with a heim joint ? just a couple of things regularly added , to my belt driven anything . no whyining bearing noise or belt bounce , always testing / trying for improvement , pete Keeping the bearings filled with Lucas Green grease. No real signs of belt bounce. Keeping the pivot points lubed up. Tractor only shows 150 on the clock. Nothing really worn out yet, so I can't justify mods to the clutch linkage. 1 Share this post Link to post Share on other sites
kpinnc 17,030 #10 Posted July 3, 2025 On 7/1/2025 at 10:57 PM, Bill D said: Keeping the bearings filled with Lucas Green grease. I've been thinking about this for a while. So long as the drive pulley is no smaller than the pulleys on the 42 inch deck, the spindles won't spin faster than what they will on any 42. What will increase is the tip speed of the blades, which is desirable for increasing the quality of cut and clippings distribution- at least to a point. And Bill you are correct: today's commercial mowers spin the blades at crazy high RPMs. My Scag sounds like I'm pulling up to a 3 foot hover sometimes. Just make sure you use high quality blades and you should be fine. 1 Share this post Link to post Share on other sites
cleat 8,716 #11 Posted July 10, 2025 Here is my 520 with the 48" deck with the power flow bagger pulley used as a center drive pulley. Blade speed is definitely increased but still seems well within limits. I just got finished mowing, that is why the machine is dirty. 1 Share this post Link to post Share on other sites
kpinnc 17,030 #12 Posted July 11, 2025 15 hours ago, cleat said: just got finished mowing, that is why the machine is dirty. Good grief @cleat!!!! I've never seen one of your machines dirty before! 1 1 Share this post Link to post Share on other sites
Lee1977 7,544 #13 Posted July 11, 2025 That's not dirty down here. when it's dry down here our Wheel Hoeses turn brown. Share this post Link to post Share on other sites
