Horse Newbie
48 inch Side Discharge Deck Restoration
8ntruck
@Jeff-C175   - you just jinxed yourself with that statement, ya know.........
Edited by 8ntruck
  • Haha 2
Blasterdad
Should have said the break was at a 45 degree angle so it did hold the housing down when bolted back down.
Jeff-C175
I saw one about a decade ago that a friend had where a PO had machined an 'L' bracket that fit nicely over the broken piece and clamped it down gudentite.
He's still running it like that AFAIK.
Blasterdad
28 minutes ago, Jeff-C175 said:
 gudentite.
Guess it shows that I'm German... :ROTF:
  • Haha 2
Horse Newbie
I bet I put this thing together and took it apart 6-8 times…
Center spindle wouldn’t take grease…
Took all 3 spindles apart and checked them. Added a hole where the grease would come out both sides of the spindle shaft.
Then I noticed the end bolt on the slide bar was moving… took it back apart to tighten that.
I got it back to where I had it before the center spindle wouldn’t take grease…
  • Excellent 2
kpinnc
I got a 60 here that needs that level of consideration! :P
Just kidding! But that 48 looks better than new! :bow-blue:
  • Thanks 1
Horse Newbie
@kpinnc… I’ve been hankering to bring the boys ( 520H, and Work Horse ) up to see you and Don / @Lee1977.
If you can set a date that’s agreeable to you both, after the Big Show, I’ll come up there to visit, and let you two aw me with y’all’s knowledge of Wheel Horses.
Horse Newbie
5B5018AF-D3DB-4CE5-A41E-5E3EF77CC856.jpeg.f5ea01a2a3a0f5b47b550bb5b6bfcd42.jpegSo shortly after inviting myself to Kevin’s, I went out to the Custom Hot Rod and Tractor shop to piddle with the 48 inch SD deck some more…
got the deck carriage bolted on.
Somebody during the course of this thread suggested all new hardware, and I am so glad I did that… like they said… really makes it pop !
So anyhow, does anybody know if this decal goes on a 1994 48 inch SD deck ?
( first pic)
I already have some of the decals on as shown in the following pics…
Edited by Horse Newbie
  • Excellent 1
Horse Newbie
I need to have @Vinylguy / Terry to make me up the OPEI silver triangle…
What I have left to do:
1. Paint topside of deck chute and apply yellow warning decal.
2. Clean, and maybe paint the rubber bumpers that hit the floorboards when you raise the deck.
3. Install deck chute.
4. Adjust those two bolts on the front of the carriage guide brackets.
5. Shine up the rod from the carriage to the gauge wheel bar.
Horse Newbie
Can anybody shed some light on how to adjust these bolts ? Do you adjust to keep the carriage bars off the deck shell, or is it something else ?
Horse Newbie
Here’s a few pics…
  • Excellent 2
Blasterdad
The manual answered both your questions, (I was curious too). Shows decal locations & refers to the bolts as "Transport Level Stops" :thumbs::)
Edited by Blasterdad
  • Thanks 1
Blasterdad
In your last pic please put a stainless fender washer behind that cotter pin, (my OCD kicking in). :rolleyes: That deck is so beautiful, MUST KEEP COTTER PIN FROM SCRATCHING PAINT! LOL. :text-coolphotos:
kpinnc
You know you and Don are welcome anytime! :thumbs:
On that steeker, it actually goes on the Eaton hydro transaxle right side axle housing. Zoom in on the pic below.
  • Thanks 1
Horse Newbie
Thanks @kpinnc… I had it in the wrong envelope… threw me off. No telling how long it would have taken me to figure that out. Maybe I’ll mask off the 520H rear axle and put some paint on it, then the decal…
You make me feel welcome every time I’ve been there… just don’t wanna be the “Pop-in” guy…
Horse Newbie
Well I reckon since the mule drive/ front attach-a-magic runs the deck I can slide this in with the 48 inch deck restoration thread…
I wanted to repaint and “once over” the mule drive while I was redoing the deck.
Can any of you fellows or ladies tell me if the pulleys on the mule drive is pressed onto the shaft ?
I figured they would just slide right off.
Are they probably stuck on from brown weld, or crud build up ?
Jeff-C175
No, sorry, they should slide freely...
  • Thanks 1
cleat
Yep, just brown welded.
You might get lucky by screwing the nut on until it is flush with the end of the shaft then hang on to the first pulley and strike the end of the shaft repeatedly with a dead blow hammer.
This has worked on most of mine.
Horse Newbie
What’s a dead blow hammer ?
cleat
Like a soft face (which might work also) but it has steel shot inside for more striking force.
A brass hammer might work as well.
By holding the pulley in your hand you prevent it from being damaged.
  • Thanks 1
tunahead72
10 hours ago, Horse Newbie said:
Now that you have that assembly removed...
I had good luck a while back by supporting the pulleys underneath with wood blocks and shims, just high enough that the main part of the hitch assembly was off the floor.  Then sprayed a liberal amount of PBlaster on the threads (which should be at the top) and let it soak into the bore of the pulleys overnight.  The next morning I gave it one or two light taps with a rubber mallet and both pulleys slid right off.
  • Thanks 1
peter lena
@Blasterdad referring to your  upper deck picture during tear down , did you replace the belt tension idler pulley ? notice that was the original small bearing type , have replaced all mine with same size / type , but larger bearing with wide rubber side shields , for easy grease replacement, that pulley is known for early failure .  easily matched up on the net , hi temp grease , 560 deg , will stand up in deck bearings , they get very hot and start whining early in use , pete
peter lena
peter lena
@Blasterdad  dare I ask , what did you use for the deck bearing grease ?
  • Similar Content
    • Rob R
      By Rob R
      I have a  WH 310-8 Mower Deck, Tach-a-Matic 42” Toro Model 05-42MS-05, Triple Blade (1981-83). One of the Mandel's (outer) will NOT take grease at the Zerk fitting have removed the Zerk tapped on it made sure hole and opening good etc. but to NO avail any suggestions here. Thanks
    • Horse Newbie
      By Horse Newbie
      So for the last 5 to 6 months I have been working on getting my 1994 520H up to operating condition after buying it from a friends backyard a few years ago...now that I'm 99 percent done with the tractor I want/ have to get the 48 inch SD deck that came with it up to operating condition also.
      As you can see by the pics I have a lot of work to do/ full restoration...I have a few questions before I get started...
      1. Do the two wheels on the back of the deck control the cutting height ?
      2. Where/ who is a good source for parts ?...I would like to go back with as much new parts as possible, but some of the pricier parts I will probably be willing to use used if my budget forces me to ( spindle are my main concern here).
      As you may be able to see from the pics, the front center of the deck has been knocked back quite a ways ( looks like PO centered a concrete driveway/ sidewalk edge, or one stout survey corner stob.
      Any suggestions about straightening the front edge would be greatly appreciated.
      Also if any of you would have the center front wheel bracket on a junk deck that you would be willing to cut off and sell to me, it would be greatly appreciated.
    • woodbird007
      By woodbird007
      Thinning Herd
      2) 1974 B80 4 speeds
      both run, one in need of rebuild
      sd 36” deck
      rd 36” deck
      short frame dozer blade and mount
      extra wheels and tires
      $300 takes all
      Kalamazoo, Mi area
    • ToddA
      By ToddA
      I am Trying to find out if the Toro Deck 78353 will Fit On my 1975 C-160 Thanks For any Info Todd
    • jay1
      By jay1
      I just noticed that my b80 (1975) deck is rusting out.  Is there a replacement deck that fits the B80.  Tractor is in great shape--had the engine replace several years ago.
