squonk 47,801 #126 Posted April 22, 2021 If you are going to use a sealer on a gasket on cast iron, I think Permatex Aviation Sealant is best. Just a light coat. No rubbery flakes in the hydro. Share this post Link to post Share on other sites
Gregor 4,848 #127 Posted April 22, 2021 1 minute ago, squonk said: Permatex Aviation Sealant I use that on Lawn Boy engine cases. Stuff is great. But it's a lot like anti-seize, it wants to stick to everything. And it does STICK! Share this post Link to post Share on other sites
cafoose 3,793 #128 Posted April 22, 2021 When it was rebuilt the shop used something that I had to remove with my air operated gasket scraper, that stuff was tough but it didn't leak Share this post Link to post Share on other sites
stevasaurus 23,786 #129 Posted April 22, 2021 It is the ease of re-entry that I do not use a sealer...and I love copper-coat. Copper-coat is great for doing vertical gaskets...like thermostats. @Gregor, I would almost bet your leak is from a seal. Any oil leak in these transmissions always looks like a case gasket, but it rarely is. 2 Share this post Link to post Share on other sites
cafoose 3,793 #130 Posted April 22, 2021 (edited) @stevasaurus@pfrederi I got the parts from NAPA. The bolts I got are grade 8 3.5 inches long. They are a little longer than the original bolts. Does that matter? Also the new axle keys wiggle about 1/64" to 1/32" in the shaft. Does that matter? Edited April 22, 2021 by cafoose Share this post Link to post Share on other sites
Gregor 4,848 #131 Posted April 22, 2021 24 minutes ago, cafoose said: Also the new axle keys wiggle about 1/64" to 1/32" in the shaft I have tigtened up woodruff keys in the past, with coil stock. Share this post Link to post Share on other sites
pfrederi 21,005 #132 Posted April 22, 2021 When in doubt I tend to follow the manual. it calls for 5/16 3-1/4" bolts.... (The other version of the older Wheelamatic with a bevel gear differential did use 3-1/2" Share this post Link to post Share on other sites
stevasaurus 23,786 #133 Posted April 22, 2021 Do not use longer bolts then what you pulled out. I know Paul likes to change out his bolts, but it is really not necessary. New nuts are a must. It seems like Wheel Horse never used the length of bolts that you can readily buy. If you have to use them, put a regular nut on them and then saw to the same length as the ones you pulled out. Back that nut off to fix the thread. 3 1 Share this post Link to post Share on other sites
squonk 47,801 #134 Posted April 22, 2021 You try some Loctite bearing and sleeve retainer on the axle keys 1 1 Share this post Link to post Share on other sites
cafoose 3,793 #135 Posted April 22, 2021 7 minutes ago, Gregor said: I have tigtened up woodruff keys in the past, with coil stock. Like this? Share this post Link to post Share on other sites
squonk 47,801 #136 Posted April 22, 2021 WOW! I edited my post to add a word and it posted another one! DOO DO DOO DO! 1 1 Share this post Link to post Share on other sites
Gregor 4,848 #137 Posted April 22, 2021 (edited) 15 minutes ago, cafoose said: Like this? Yep. Unless you want to have the axles re-cut. It's only money. I have also used tin cans. They are steel. Edited April 22, 2021 by Gregor 1 Share this post Link to post Share on other sites
cafoose 3,793 #138 Posted April 22, 2021 On 4/20/2021 at 6:53 PM, cafoose said: NAPA wanted $16 for a filter and I got a Wix from Fisher for less than half the price Turns out the guy at Fisher Auto Parts misunderstood me and ordered a 51310. I told him it's wrong I need a 51410 He ordered me the 51410 and it was comparable to NAPA price at $14.84 when NAPA wanted $16.99! Share this post Link to post Share on other sites
Gregor 4,848 #139 Posted April 22, 2021 19 minutes ago, cafoose said: 51410 Box will probably say, 1410 1 Share this post Link to post Share on other sites
pfrederi 21,005 #140 Posted April 22, 2021 3 hours ago, Gregor said: Box will probably say, 1410 Napa 1410 Wix 51410 same filter 1 1 Share this post Link to post Share on other sites
WHX?? 57,650 #143 Posted April 27, 2021 (edited) Never try to tie your horse up when moving! Edited April 27, 2021 by WHX24 4 Share this post Link to post Share on other sites
cafoose 3,793 #145 Posted April 28, 2021 I got it finished! 1 5 Share this post Link to post Share on other sites
rjg854 13,277 #146 Posted April 28, 2021 Congrats on the accomplishment 1 1 Share this post Link to post Share on other sites
Ed Kennell 46,817 #147 Posted April 28, 2021 WTG Chuck ! 1 Share this post Link to post Share on other sites
cafoose 3,793 #148 Posted April 28, 2021 44 minutes ago, Ed Kennell said: WTG Chuck ! @Ed Kennell for a great deal on the parts! to everyone for all the help and instruction to make my project a success helping me to save another truly is one of the best forums on the internet with some of the friendliest and most helpful people on the internet and I'm proud to be a supporting member! 1 6 1 Share this post Link to post Share on other sites
