Wheel Horse 3D
Custom 3d printed badges, ornaments etc.
Wheel Horse 3D
Theres a ton of files already out there for lego, it might be possible to design and print a WH set!
DennisThornton
How in the world are these done?  All the measurements!
ebinmaine
I'd love to see a model of the 1974 to '77 C Series and mid sixties square hood.
Not Lego stuff but a decent representation with close scale proportion.
  • Heart 1
SylvanLakeWH
There’s someone who does them... I’ve seen posts on here... not sure who?
Wheel Horse 3D
I just got my hands on an original ornament, and have re-scaled the original replacement.
Gonna have to use even smaller screws. But have eliminated the extra in all dimensions.
For now ill leave the little extra on the horsies, just feels right lol.
Edited by Wheel Horse 3D
Wheel Horse 3D
Even an inch to mm conversion(60in down to 60mm) would make a nice model. If someone can get me detailed schmatics, im sure i can come up with a reasonable likeness.
Where i work they would simply die for a scale model of some of our equipment lol.
Wheel Horse 3D
More requests......
ebinmaine
9 hours ago, Wheel Horse 3D said:
More requests......
My 1974/77 Cinnamon Horse C160 has a steering center like that. What do you need?
Wheel Horse 3D
Ive got these in hand, so I should be good lol
Just have to make time to get the models done!
DennisThornton
How?
Wheel Horse 3D
49 minutes ago, DennisThornton said:
How?
A pair of calipers goes a long way! If ya know one dimension you can come pretty durn close to one ya dont know. Say ya know the rim is 8".
In a picture it may be 1/4 inch or say 5mm.well
If you have a straight on side view you can use your calipers take that and walk it all over the place. If ya use the calipers to take that 8" and scribe it in half, you can now get down to 4 inch resolution. Half again and youre within 2 inches.
Even somethinh like a lug nut, or hub of a known dimension can be helpful. Once ya nail down what 1mm represents in actual length then a ruler and calipers can extrapolate a lot.
It wouldnt be EXACT but the proportions and eveything would match.
Wheel Horse 3D
Theres even a way to extrapolate an svg file from a photo, which while it wouldnt create the whole model it would give you dimensions to work off of and round out in a cad program.
  • Excellent 1
DennisThornton
Overwhelming details!  X3!
A friend has a very expensive 3D scanner but I don't know it's resolution.  It ways a couple tons!  Nikon I think.  I know there are smaller ones and I assume with sufficient detail to do this. Sure won't be me.
Wheel Horse 3D
Yeah a 3D scanner would be awesome even a handheld one! But $$$$$$$
ebinmaine
I can give you all the measurements you want with a stick ruler but I don't have any calipers to go with.
Wheel Horse 3D
Any dimension and related photos is info. Your eye can fill in a lot too. Is the slope there right? Is that parallel to that other piece there? Etc etc.
With the original ornament model all i had to go on were stick measurements, and i added .2 inches in all dimensions to accomodate the screws but maintain proportions. When I got a hold of the real deal, i wad almost exactly .2 over in each dimension. So same process, just way more modeling!
DennisThornton
No idea of the resolution or features but I'm seeing some for under $200.
Wheel Horse 3D
Definately one of the things on my upgrade list!
DennisThornton
I had no idea they had come down so much but I also have no idea how much they will do.  BUT!  If one could scan something as big as one could print!  Oh my!  Piece the broken one back, find a good one, build a prototype and then print all you needed!  Wow!  Make most anything plastic.
Wheel Horse 3D
Yep ya could make a replacement of almost anything PDQ. The biggest thing is getting a good closed object once done. Any gaps in the scan and you end up with an object with holes the cad doesnt know what to do with. Then ya have to go adjust and close gaps etc.
Ya wouldnt need a huge resolution unless you needed pin point accuracy.
Tractorhead
Tried some experiments
the first tests i did with an XBox kinect Sensor and open Source SW,
but they be to worse in resolution on smaller detailful things.
Resolution of the kinect was to weak, even Software was to Alpha in that stadium,
you see how dusty it is, that fit‘s to my tries before i stop them. 😎
than i tried the ciclop Scanner with Horus open source SW from Jesus.
http://diwo.bq.com/de/einfuhrung-ciclop-und-horus/
That gives me for less money the best results.
a cheap Webcam an Arduino 2 line lasers a stepper motor and a Stepperdriver like on 3D Printerboards
and little open Source Software. Without the time  for build all, Definitely worth a try for the cost.
all in all under 200$
but i like it more to spent actually time in my Shed, than to play on the 3 D Scan and printer actually.
Wheel Horse 3D
The kinect i think is a very economical solution for larger items! I can imagine scanning a whole tractor with one of those setups! Im actually suprised i dont already have one of those around i have all sorts of scavenged game system stuff but alas no kinect
bc.gold
Have you tried Sketchup.
8ntruck
I contracted some 3d scanner work to capture some hand tuning done on die details.  The scanner worked fine.  The hard part was taking the point cloud the scanner produced and turning it into a useable solid in CAD to get the CNC program that would make a duplicate of the hand worked part.
Wheel Horse 3D
Sketchup never seemed to flow for me, i use Autodesk 123design, and when it comes to point clouds and meshes im hoping Meshmixer will suit me
  • Similar Content
    • Donavon
      By Donavon
      Need ideas to convert my 1054 A Frame plow into a snow blower
      Any idea's?
    • Wheel Horse 3D
      By Wheel Horse 3D
      Welcome, and thanks for visiting our vendor area.
      We got our start in 3D printing for customers right here on Red Square!
      If you'd like to see how every thing gets developed and the contributions of Red Square members, please visit the thread that started it all and browse through our progress to date.
      We love our clients' input and work closely to turn ideas into reality. If you have an idea, request, or questions, you can post to that thread, message us or tag us here on Red Square, or visit our Etsy store and reach out to us through there.
      Greystone 3D on Etsy
    • Wheel Horse 3D
      By Wheel Horse 3D
      Our customized ornaments have a base identical to our version of the original style ornament, but can be topped with 3 different styles of horse head and 3 different styles of wheel! Each is available unfinished, primed, or fully painted.
      They also include the pictured mounting hardware and the base spacer for a clean finished look. Can be ordred here Custom Wheel Horse hood ornaments..9 different styles
    • Burnerman
      By Burnerman
      I’m building a lowered 300 series wheelhorse. So far it’s a combination of 3 scrap tractors.
      the frame, trans and tins are from a GT2500 anniversary special given to me by a neighbor with a trashed Briggs. The Kohler M12 is from a junkyard 312 that was roached. The parts tractor I’m using for the build was another older 312. I’ve got the k301 in the garage. The trans was toast. Both axles wallowed out keyways and 1 axle actually broken.
      Anyway! I needed a project and a toy to putt around the neighborhood. I couldn’t find any other posts on how to do the whole thing. I’m trying to keep it cheap using stuff I have on hand and looking as “stock but cooler” as possible. So here we go.
      I’ll update this as I go along.
