Wheel Horse 3D
Custom 3d printed badges, ornaments etc.
Wheel Horse 3D
Lookie who i found on Dad's shelf!
  • Heart 1
Wheel Horse 3D
Plenty of flex too.
  • Excellent 2
ebinmaine
Mack!!!
Wheel Horse 3D
1 minute ago, ebinmaine said:
Mack!!!
Tryin to figure out how im gonna duplicate and modify. Maybe take a marker and divide him into 5mm slices, measure and duplicate each slice and stack em up.
Wheel Horse 3D
Maybe i could drop some pics of him on a grid in blender.
Wheel Horse 3D
Take me piece of plexi, put a grid on it, and put him just behind the grid! Then some pics and I've got something to work with!
Drop the patent pic behind rhe grid too. Should show me the mods needed for the original 30s model. Then just have to get the size correct.
Edited by Wheel Horse 3D
Wheel Horse 3D
Heres the previous version of a headlight bezel with thr flat head snd classic wheel. Lugs were too small to take paint correctly.
Wheel Horse 3D
Or i could just find an app for that!
Wheel Horse 3D
Uggh stayed up and find i printed the wrong file! Lol printed another hubcap! Starting the classic wheel now! Should be done by morning.
Wheel Horse 3D
Glossy? Or plain?
If i put a coat of acetone on there i can make the ABS more shiny. I think the plain looks better.
What do yall think?
ebinmaine
Kind of hard to tell from the pictures. The plain one looks like it has more depth and definition and I would prefer that.
Wheel Horse 3D
That's how I see it. The plain adds overall contrast.
Wheel Horse 3D
9 minutes ago, Jeff-C175 said:
Mine is coming along nicely.  Another coat of white on the wheels and some touchup on the hubs and she'll be ready to mount.  (I use that term loosely!)
NICE FINISH!!! Any tips/tricks to share?
Wheel Horse 3D
I think I did some extra acetone smoothing on that one, dunno if it helped.
Jeff-C175
Nothing special really,  I did a light wet sanding with 400 and then with 2000, but the detail areas I really couldn't get into very well.  Mainly just the base I wanted to get as smooth as possible and remove the center seam stuff in the mane and face.
Used "Testors" model paint, couldn't find the "Model Masters" you mentioned but I believe that's also packaged by Testors.  I went to the hobby shop that was supposed to be open until the end of March, and it was CLOSED! already.  Empty, lights out.
First coat was light, second coat I applied heavier, just short of 'sagging'.
Allow plenty of 'curing' time between coats, these enamels are slow drying.  They 'skin over' quickly, but are not yet dry underneath.  Add a second coat too soon and you'll be 'pulling' the top skin off and make a messuvit.
Use QUALITY! brushes.  That's probably the most important part.
Edited by Jeff-C175
  • Excellent 3
Wheel Horse 3D
I went ahead and added the headlight bezel/lens  and the steering wheel inserts to the store. Soon I'll be adding custom options to the inserts as well, just like the ornaments and bezels. So then you can have all your Horses on your Horse match!
https://www.etsy.com/shop/greystone3d
Jeff-C175
I might have missed in a previous post...  are you by chance doing horses for the steering wheel center?  My poor C series has been whinnying for a logo there for a long time.  I don't think the C's came with them.  Maybe something that fits the radius of the existing cap that can be siliconed in place on top?
Like this?
Edited by Jeff-C175
roadapples
Not finding your  store...
AMC RULES
Just search Wheel Horse there on Etsy Jay.
Wheel Horse 3D
hmm, lets try https://www.etsy.com/shop/greystone3d
Wheel Horse 3D
2 minutes ago, Wheel Horse 3D said:
"SHOP" not "store"
Wheel Horse 3D
Like this?
Just added these (center one is original others I printed), I will be eventually customizing these with the same options as everything else. If you need a specific size or thickness just let me know!
Wheel Horse 3D
@Jeff-C175 if need be for a custom application I could add a "cup" on the bottom? Id have to get a closer look at your steering wheel If we need to fine tune a solution.
Jeff-C175
As close as you can get without a road trip!
What I have no clue how to cipher is the radius of the part.  I guess I could lay a straignt edge across the wheel and measure down to the center, and then the edge.
What are the dimensions of the ones you made already?
I've never had that center piece out.  It looks like there are two 'slots' to fit in a small flat blade and that part would pop out but I'm a-feared to try it for breaking something.
Anyone know if that's how to do it?  Will that piece pop out easily?
If there were slightly MORE curve to it, and only needed to be silly-coned in around the outer edge, that would work.  LESS curve would not work because the edges would be 'floating'.
Coolest solution would be if that part did pop out easily and the logo part pop in it's place.
Edited by Jeff-C175
  • Similar Content
    • sjoemie himself
      By sjoemie himself
      Soo.. yet another idea that floated around in my head for way too long was to build a wheelbarrow with a 'big' wheel.
      We're hauling horse manure from several places, some more muddy than others. When doing so with a 'normal' wheelbarrow the frontwheel tends to cut through the mud instead of rolling on top. My idea was to mount a single wide wheel to have more flotation so the wheelbarrow would be easier to push through the mud.
      To start things of I convinced my SO to donate her wheelbarrow to the good cause.
      This is what I started out with:
      Solid, narrow, single wheel. Yes it is crooked because the bearings are gone.
      More in next post.
    • Donavon1
      By Donavon1
      Project black Betty the diesel 1054
    • Wheel Horse 3D
      By Wheel Horse 3D
      Our customized ornaments have a base identical to our version of the original style ornament, but can be topped with 3 different styles of horse head and 3 different styles of wheel! Each is available unfinished, primed, or fully painted.
      They also include the pictured mounting hardware and the base spacer for a clean finished look. Can be ordred here https://greystone-3d.square.site/product/customizable-wheelhorse-hood-ornaments/10
    • Wheel Horse 3D
      By Wheel Horse 3D
      Welcome, and thanks for visiting our vendor area.
      We got our start in 3D printing for customers right here on Red Square!
      If you'd like to see how every thing gets developed and the contributions of Red Square members, please visit the thread that started it all and browse through our progress to date.
      We love our clients' input and work closely to turn ideas into reality. If you have an idea, request, or questions, you can post to that thread, message us or tag us here on Red Square, or visit our online store and reach out to us through there.
      Https://greystone-3d.square.site
