Wheel Horse 3D
Custom 3d printed badges, ornaments etc.
Wheel Horse 3D
How much thread does a shifter need? Might have to let the client tap it so they can adjust to the exact number of threads to get it facing just right then a little thread lock on there.
Gonna have to be solid and dense too kinda like the door knocker ball.
Wheel Horse 3D
Soooo....any requests for the Big Show????
Already figuring on a bunch of the 3d keychains.
Thinking ahead to that time already. Think we'll leave Dug at home and come with an empty trailer to fill with something hydro with mower deck for Mrs!
Handy Don
Flat lock nut would let you be more precise on positioning, wouldn't it?
Wheel Horse 3D
As long as theres enough thread to work with, thats a perfect solution. I had planned the shaft to go deeper into the head though, with a portion of the bottom as a collar. Figured this would distribute the forces of shifting better.20220319_153126.jpg.373f73932a9b65f09299ce74b0d818b3.jpg
Handy Don
20220319_153126.jpg.373f73932a9b65f09299ce74b0d818b3.jpg 20220319_155101.jpg
Yeah, I see where you are going on this and it's a good idea.
More involved, but a setscrew through a small hole in the "wheel" part to grip the shaft solely to prevent rotation? Could still use a dab of purple loctite just to prevent wiggling?
Last wacky idea: ship the mandrel and the horse separately so the owner can thread the mandrel onto the shifter (again, purple loctite?) and then use their favorite adhesive to glue the horse to the mandrel with the horse positioned as they want it.
Wheel Horse 3D
Thats an interesting thought! A bit of acetone would be all that would be required.
Lol no gear jammer in the stable! Dug's a hydro
Wheel Horse 3D
M
The more I think on it, this may be exactly what is needed. Could then use a standard thread on insert, and apply it to all different shapes of custom shifter. Can anyone verify for me the shifter thread size, thread length, and diameter of the unthreaded portion of the shaft?
ebinmaine
11 minutes ago, Wheel Horse 3D said:
M
Text me about 5 and I can check it.
Handy Don
⅜-16 on both R-1-2-3 and H-L
~⅜ of usable thread on each
Hi-Low on ⅜" shaft
R-1-2-3 on ½" shaft
Edited by Handy Don
Wheel Horse 3D
Thanks Don! And sorry I didnt holler at ya Eric, been busy busy!
ebinmaine
No apologies brother man.
Notice the time on @Handy Don reply. Perfect timing. 👍
Wheel Horse 3D
Latest custom order.....a 20" tall Gary the Snail ??????!!!!!!!! Will take 14 individual pieces some weighing almost 2 lbs and requiring 2 days to print the larger pieces. Yikes!
  • Haha 2
  • Heart 2
ebinmaine
Gary the snail is the most awesomest
Wheel Horse 3D
Almost done. Now to repeat this 13 more times lol
  • Confused 1
Wheel Horse 3D
And the fun continues!
Wheel Horse 3D
Today got some more done! One of the upper shell pieces is almost finished as well.
  • Like 4
Wheel Horse 3D
4 more pieces to go!
  • Excellent 3
Wheel Horse 3D
Only 2 left, and did some assembly, welding and filling
sjoemie himself
Since Gary is acceptable I thought you might also enjoy my custom 3D printed IH logo I made for my 'Murray to IH 1568 project'.
Couldn't find a suitable off the shelf logo in the right scale so decided I would try to 3D print it.
I drew this myself in fusion360 and then had somebody else print it for me. Came out pretty good.
Plan is to paint it in the correct colors obviously ;)
Edited by sjoemie himself
Wheel Horse 3D
Could also be done as a multi color print! Just now tinkering with manual filament changes mid print. Eventually i intend to get at least a 4 color multi material type unit.
sjoemie himself
Funny you should mention that. The man that printed the logo for me said exactly the same!
I opted to not go that route so that I can match the paint with the rest of the tractor.
When I sent the example he said "well maybe it's better to paint it if you want it to match precisely".. :dunno:
Wheel Horse 3D
Getting a filament to match a color like RED is a pain, in here somewhere is documented the search for a decent "Red". We had orangy red, reddish orange, blaze red, iron red, brick red till i finally came across "Enzo Red" from one specific manufacturer that was the same color as regular red testors enamel.
sjoemie himself
Than i'm glad I chose the paint route.
Seems to me the red fillaments turn out a little 'flat' or 'bleached' once printed.
Wheel Horse 3D
These horses were done in the enzo red..but again, getting that correct color was a pain
  • Similar Content
    • sjoemie himself
      By sjoemie himself
      Soo.. yet another idea that floated around in my head for way too long was to build a wheelbarrow with a 'big' wheel.
      We're hauling horse manure from several places, some more muddy than others. When doing so with a 'normal' wheelbarrow the frontwheel tends to cut through the mud instead of rolling on top. My idea was to mount a single wide wheel to have more flotation so the wheelbarrow would be easier to push through the mud.
      To start things of I convinced my SO to donate her wheelbarrow to the good cause.
      This is what I started out with:
      Solid, narrow, single wheel. Yes it is crooked because the bearings are gone.
      More in next post.
    • Donavon1
      By Donavon1
      Project black Betty the diesel 1054
    • Wheel Horse 3D
      By Wheel Horse 3D
      Our customized ornaments have a base identical to our version of the original style ornament, but can be topped with 3 different styles of horse head and 3 different styles of wheel! Each is available unfinished, primed, or fully painted.
      They also include the pictured mounting hardware and the base spacer for a clean finished look. Can be ordred here https://greystone-3d.square.site/product/customizable-wheelhorse-hood-ornaments/10
    • Wheel Horse 3D
      By Wheel Horse 3D
      Welcome, and thanks for visiting our vendor area.
      We got our start in 3D printing for customers right here on Red Square!
      If you'd like to see how every thing gets developed and the contributions of Red Square members, please visit the thread that started it all and browse through our progress to date.
      We love our clients' input and work closely to turn ideas into reality. If you have an idea, request, or questions, you can post to that thread, message us or tag us here on Red Square, or visit our online store and reach out to us through there.
      Https://greystone-3d.square.site
