Berny 9 #1 Posted January 20, 2021 I have a wheel horse C-160 that I have been trying to fix up. It has the Tecumseh HH-160 engine. Today I found out it has low compression, which was a major bummer. I need to open up the engine and do the piston rings, head gaskets etc. I found the piston rings, but I haven't been able to locate a gasket kit for this engine anywhere online. It's tough because Tecumseh has been out of business for 20+ years. Also, it seems most C-160s had the kohler engine. I can't even find a good service manual for it! Does anyone know where I can buy the gasket kit for this engine? If I can't find it, should I try to swap out the engine? With what? Any idea where I can find a good service manual? Thanks a ton! Share this post Link to post Share on other sites
ebinmaine 72,664 #2 Posted January 20, 2021 The C160 with the Tecumseh is rare. Only made in 1974 and rumored as little as 200 to 300 made. For a parts source try Lincoln at A to Z Tractor in Pennsylvania. We may have a manual here in the information section. If you were to swap that engine for another one the easiest would be the Kohler 16. What are your compression figures hot and cold? Share this post Link to post Share on other sites
squonk 43,808 #3 Posted January 20, 2021 You could drop a K321 14 in it and have a C-140. They are plentiful and cheaper. Use the Tecky for a door stop. 4 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,475 #4 Posted January 20, 2021 May be listed as HH-160 as it was later changed to OH-160 Parts lists https://www.partstree.com/models/oh160-170019-tecumseh-engine Garry 1 Share this post Link to post Share on other sites
953 nut 59,957 #5 Posted January 20, 2021 6 hours ago, Berny said: Today I found out it has low compression, which was a major bummer. I need to open up the engine and do the piston rings, Prior to dropping a bunch of money on parts you need to have the engine measured to determine the condition of the cylinder. A set of rings won't cure low compression if the cylinder is egg shaped or badly worn. know if 3 Share this post Link to post Share on other sites
ohiofarmer 3,372 #6 Posted January 20, 2021 As far as compression, can we really measure it when these engines have compression release? Besides that, just popping the top off the piston may reveal other problems like a leaking head gasket or a head that needs flattened. i often find valves that need adjusted or cleaned as well. Most that i buy, have at least some wear and another quick test is just to push the head of the piston sideways with the front and side of the bore. An oblong bore of any amount will show difference as the piston moves down the bore. I also use a feeler gauge on the the top edge of the piston which is sort of like the piston ring gap idea but not as accurate. 2 Share this post Link to post Share on other sites
peter lena 9,270 #7 Posted January 20, 2021 BERNIE, if that tecy is really sick , why not just swap just swap it put with a K321 ? really a bolt in set up , you could also add electronic ignition and a few other improvements to bring it up to date ( if you want to ) . pete 1 Share this post Link to post Share on other sites
Berny 9 #8 Posted January 20, 2021 11 hours ago, ebinmaine said: The C160 with the Tecumseh is rare. Only made in 1974 and rumored as little as 200 to 300 made. For a parts source try Lincoln at A to Z Tractor in Pennsylvania. We may have a manual here in the information section. If you were to swap that engine for another one the easiest would be the Kohler 16 Thank you! I figured they were rare as I can't find any info about them. But I feel better about it now, thanks. I will try that store. No luck on the manual here in the site. I found some useful info, but not the top to bottom engine/tractor guide I was looking for. I'll check out the kohler, any idea on where to find and how much it would cost? Thanks! Share this post Link to post Share on other sites
ebinmaine 72,664 #9 Posted January 20, 2021 Used Kohler like anything else is going to be just a potluck. You can find them anywhere from $100 $150 all the way up to $400. if it's a tractor you honestly intend to keep for a long time you may want to seriously consider a reman Kohler 16. most of what you do is going to be a bolt in. If there's anything that's that different parts are readily available from several of us or A to Z as mentioned above. One of our own, @richmondred01 sells engines that he has rebuilt. I'll let him throw a quote at you for the engine plus shipping..... Those Tecumseh engines were popular in Sears tractors so it's possible there's manuals there. I've seen the manual that supplied for all of those of the various sizes and some of it like you say is not super specific. At least now you have several different options and directions to go. Good luck and keep asking questions! Share this post Link to post Share on other sites
Berny 9 #10 Posted January 20, 2021 7 hours ago, gwest_ca said: May be listed as HH-160 as it was later changed to OH-160 Garry, Thank you so much! Are you certain the OH160 is the same engine? If that is the case it solves a ton of my problems. On another forum I read another post about the OH being a much newer and different motor. However, looking at those diagrams, they sure do look like my engine. I do have that manual you posted, but it didn't include HH160 in the models it covered. You may have solved the problem. Thank you! Share this post Link to post Share on other sites
Berny 9 #11 Posted January 20, 2021 7 hours ago, 953 nut said: Prior to dropping a bunch of money on parts you need to have the engine measured to determine the condition of the cylinder. A set of rings won't cure low compression if the cylinder is egg shaped or badly worn. Thank you! I was hoping to make sure the gaskets and such were even available before I took the engine apart. If I can find them then I'll crack it open and see what the deal is. You make a good point though, no need to waste money on an engine that is beyond saving. I really like that procedure on finding out about honing the cylinder, thanks! 2 Share this post Link to post Share on other sites
ebinmaine 72,664 #12 Posted January 20, 2021 6 minutes ago, Berny said: Garry, Thank you so much! Are you certain the OH160 is the same engine? If that is the case it solves a ton of my problems. On another forum I read another post about the OH being a much newer and different motor. However, looking at those diagrams, they sure do look like my engine. I do have that manual you posted, but it didn't include HH160 in the models it covered. You may have solved the problem. Thank you! Berny the way I understand it is that the early 70s 16 was an ohv of a very early type. @Stepney can you shed any light here? Not sure who else knows Sears tractors... @jabelman @ZXT ? Share this post Link to post Share on other sites
Berny 9 #13 Posted January 20, 2021 35 minutes ago, ebinmaine said: Berny the way I understand it is that the early 70s 16 was an ohv of a very early type. Thank you! A couple days ago I found a table of Tecumseh models and what the letters mean. Of course I can't find it now, but basically the HH is horizontal heavy duty, and the OH refers overhead valve. So mine is an HH, but it certainly had overhead valves, so the question is if it is the same basic engine as the OH160? If I buy a gasket kit for the OH160, will it fit my engine? Is the OH just an updated model number for the same engine? If you or the users you mentioned could shed some light on this, I sure would be grateful! Also, I will look into getting a rebuild kohler that fits, that is a good idea! Thanks! 1 Share this post Link to post Share on other sites
WHNJ701 4,165 #14 Posted January 20, 2021 I will check what manuals I have, my 1968 Sears I pulled out the tech engine and it's getting a predator swap. It's one of those tractors I got for free and really don't want it or to sink any money or much time into. The predator swap looks interesting without modifications. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,475 #15 Posted January 20, 2021 I don't know if there ever was a 16hp flat head engine. I know the first overhead valve models were labelled a HH160 and they changed the name to OH160 to better identify them. Garry 2 Share this post Link to post Share on other sites
Stepney 2,354 #16 Posted January 20, 2021 I've been around a lot of Sears, and Teccy in general.. AFAIK, there was, in the HH lineup, a 12, 10, 9, 8, and so on down the line. An OHV OH140 shares internals to a point with the 10hp flathead, and the 16hp OHV shares that of the HH120 12hp. As I remember it in my giant Tec book from the 70s. I think they planted an OHV 12hp in there for a short period.. But chances are, it's an OH160. I've never heard of an HH160 in any of my books, and they date that period. Tec could get weird with stuff though.. My best advice is study your engine and lots of pictures, and take measurements before so much as thinking about buying a single bit. I've seen many a botched-built original Tec with oddball oversize parts or undersize here or there. 1 Share this post Link to post Share on other sites
Berny 9 #17 Posted January 21, 2021 22 hours ago, gwest_ca said: I don't know if there ever was a 16hp flat head engine. I know the first overhead valve models were labelled a HH160 and they changed the name to OH160 to better identify them. Garry That is wonderful news. So I should be able to buy a gasket kit for an OH-160, and expect it to fit my engine? You might have just saved my tractor, I really appreciate it! Share this post Link to post Share on other sites
Berny 9 #18 Posted January 21, 2021 22 hours ago, Stepney said: I've been around a lot of Sears, and Teccy in general.. AFAIK, there was, in the HH lineup, a 12, 10, 9, 8, and so on down the line. An OHV OH140 shares internals to a point with the 10hp flathead, and the 16hp OHV shares that of the HH120 12hp. As I remember it in my giant Tec book from the 70s. I think they planted an OHV 12hp in there for a short period.. But chances are, it's an OH160. I've never heard of an HH160 in any of my books, and they date that period. Tec could get weird with stuff though.. My best advice is study your engine and lots of pictures, and take measurements before so much as thinking about buying a single bit. I've seen many a botched-built original Tec with oddball oversize parts or undersize here or there. Well, it is certainly labeled "HH160" I certainly understand the doubt. Google found me maybe 3 mentions of an engine called HH160 across the entire internet. They were all 10 year old posts on random forums. Maybe they just made a few before updating the label. So it sounds like I can be relatively safe buying a gasket kit for an OH160 and expect it to fit my engine. That is great advice on measuring everything before I buy, but I'm not sure how to do that on the internet. I think I will be hard know the exact sizes on all the different gaskets offered in a set online. I can probably manage it with stuff like pistons and rings because they are just circles. I really appreciate the help and advice. If you have more I would love to hear it. Thanks!! 1 Share this post Link to post Share on other sites
ebinmaine 72,664 #19 Posted January 21, 2021 1 minute ago, Berny said: certainly labeled "HH160 Lemme look at my own and I'll see what it's labeled. The labeling may have been simply a "consistency" of Tecumseh. Share this post Link to post Share on other sites
Berny 9 #20 Posted January 21, 2021 5 minutes ago, ebinmaine said: Lemme look at my own and I'll see what it's labeled. The labeling may have been simply a "consistency" of Tecumseh. That would be awesome, thanks! 1 Share this post Link to post Share on other sites
ebinmaine 72,664 #21 Posted January 21, 2021 54 minutes ago, Berny said: That would be awesome, thanks! Just got home. Wish I could help you out but there's no label on mine. Long long gone. Share this post Link to post Share on other sites
Stepney 2,354 #22 Posted January 21, 2021 36 minutes ago, ebinmaine said: Just got home. Wish I could help you out but there's no label on mine. Long long gone. You talking about the Raider? Or your own C160? I think yours may have been stamped in the actual shroud sheet metal, not the tag, they did that sometimes for .. some reason. Its Tecumseh.. expect nothing to be the same. Share this post Link to post Share on other sites
ebinmaine 72,664 #23 Posted January 21, 2021 6 minutes ago, Stepney said: You talking about the Raider? Or your own C160? I think yours may have been stamped in the actual shroud sheet metal, not the tag, they did that sometimes for .. some reason. Its Tecumseh.. expect nothing to be the same. My c-160 with the Tecumseh. There's a lighter spot in the paint where there may have been either a tag or a riveted on label at some point. You may remember it's quite rusty so it's really hard to see what's going on. Could very well be stamped into the sheet metal but I don't see where anymore..... Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,475 #24 Posted January 22, 2021 If there was a true flat head HH-160 and an OH-160 they would not have the same 170019 spec number. Garry Share this post Link to post Share on other sites
Berny 9 #25 Posted January 22, 2021 23 hours ago, gwest_ca said: If there was a true flat head HH-160 and an OH-160 they would not have the same 170019 spec number. Garry Right. Mine is definitely overhead valve. Then I suppose I can take that spec number match as confirmation that I can buy parts for the OH160 and reasonably expect them to fit my engine? Share this post Link to post Share on other sites
