By
953 nut
						I have a few basic electrical system diagrams that are helpful in understanding how the wiring system works. They are not specific to any particular tractor and do not include safety switches. All use the 5 post ignition switches 103-991 for Magneto and 103-990 for Battery Ignition. I failed to include fuses in the Starter Generator drawing, this is an over-site and I would encourage fuses be used as shown in the other two drawings.
	Hope this is helpful.
	Magneto Ignition system with electric start and solenoid.
	Battery powered ignition system with points, condenser, solenoid and electric start.
	Battery powered ignition with solenoid, points, condenser, Starter Generator and a mechanical voltage regulator.
		We have uncovered a shortcoming in the factory  wiring diagrams for S/G battery ignition systems with a four terminal voltage regulator. The wire from the regulator "Gen" terminal to the S/G  "A" terminal was omitted. This drawing should clear that up.
