BHunter 1,702 #1 Posted August 27, 2020 Hi Guys. Can someone point me in the right direction to get a rebuild kit for my fuel pump? I’m not getting fuel to the carb. thanks, Bob 1 Share this post Link to post Share on other sites
WHX?? 58,230 #2 Posted August 27, 2020 Good Luck Bob, I'm in the same boat with a 161. Fellas told me to get ahold of @buckrancher as he has some. PMed him a week ago but no response yet. Worse comes to worse may try procuring some diaphragm material and making my own. Even bought cheapy kits for the cam lever ones off fleabay to rebuild a couple of those and still no luck getting a working pump. Guessing you got the cock open and it's not plugged in the tank? Share this post Link to post Share on other sites
squonk 48,163 #3 Posted August 27, 2020 7 minutes ago, WHX24 said: Good Luck Bob, I'm in the same boat with a 161. Fellas told me to get ahold of @buckrancher as he has some. PMed him a week ago but no response yet. Worse comes to worse may try procuring some diaphragm material and making my own. Even bought cheapy kits for the cam lever ones off fleabay to rebuild a couple of those and still no luck getting a working pump. Guessing you got the cock open and it's not plugged in the tank? Jim I can PM Brian's wife on FB and let her know you're trying to get a hold of him. 1 Share this post Link to post Share on other sites
BHunter 1,702 #4 Posted August 27, 2020 7 minutes ago, WHX24 said: Good Luck Bob, I'm in the same boat with a 161. Fellas told me to get ahold of @buckrancher as he has some. PMed him a week ago but no response yet. Worse comes to worse may try procuring some diaphragm material and making my own. Even bought cheapy kits for the cam lever ones off fleabay to rebuild a couple of those and still no luck getting a working pump. Guessing you got the cock open and it's not plugged in the tank? I cleaned the tank out and put a new Petcock in. I’m getting gas to the pump but not after. I don’t know what the inside of the pump looks like. The carb was really nasty. The PO let it sit for many years with gas in it. I’m don’t know if the motor is building enough pressure to make pump work. Are you supposed to prime the carb first? Share this post Link to post Share on other sites
WHX?? 58,230 #5 Posted August 27, 2020 (edited) That would be great if you can Mike. Might as well take it apart Bob you got nothing to lose. You'll find a valve plate in ther with two little springs and check valves that are gunked up. the diaphragm will have to be replaced if we can get ahold of Brian and he has them. I was going to do a rebuild instructional on them once I get mine sorted out. No you shouldn't have to prime it. Edited August 27, 2020 by WHX24 1 Share this post Link to post Share on other sites
Jennifer 1,878 #6 Posted August 27, 2020 Same here on the boat.. if anyone finds them or get someone to reply I would like a kit!!! I asked this same question months as well.... happy hunting!! 1 Share this post Link to post Share on other sites
ebinmaine 80,767 #7 Posted August 27, 2020 Folks I've got a phone number at home for Bryan. Share this post Link to post Share on other sites
Pullstart 71,329 #8 Posted August 27, 2020 @dells68 has made a block off plate with an 1/8” tap and used a remote mounted late model vacuum pump with success... 2 Share this post Link to post Share on other sites
BHunter 1,702 #9 Posted August 27, 2020 @WHX24 I did what you said and figured I had nothing to loose. I took it all apart and was able to clean the nasty tar like stuff off the diaphragm with wax and grease remover. It runs great now. It doesn’t crank , it fires right up . IMG_4663.MOV 4 Share this post Link to post Share on other sites
BOB ELLISON 2,983 #10 Posted August 27, 2020 (edited) I ordered 2 sets from then and now in june of this year. I rebuilt my c160 pump and it works good. But you have to call him. I never could get a return email. http://www.then-now-auto.com Edited August 27, 2020 by BOB ELLISON 1 1 Share this post Link to post Share on other sites
BHunter 1,702 #11 Posted August 27, 2020 7 minutes ago, BOB ELLISON said: I ordered 2 sets from then and now in june of this year. I rebuilt my c160 pump and it works good. But you have to call him. I never could get a return email. http://www.then-now-auto.com Thank you Share this post Link to post Share on other sites
WHX?? 58,230 #12 Posted August 28, 2020 2 hours ago, pullstart said: @dells68 has made a block off plate with an 1/8” tap and used a remote mounted late model vacuum pump with success... Ney ney Jose.... Bob and I are purists of heart and Kohler. We want orginal! Good news Bob I should just try putting the original diaphragm back in again nothing to lose. @BOB ELLISON I was under the impression then and now only had kits for the cam lever pumps? We are talking about the pulse pumps here OEM on the 7 & 8 HP's. Share this post Link to post Share on other sites
BOB ELLISON 2,983 #13 Posted August 28, 2020 12 minutes ago, WHX24 said: Ney ney Jose.... Bob and I are purists of heart and Kohler. We want orginal! Good news Bob I should just try putting the original diaphragm back in again nothing to lose. @BOB ELLISON I was under the impression then and now only had kits for the cam lever pumps? We are talking about the pulse pumps here OEM on the 7 & 8 HP's. Yes I'm referring to the original fuel pump that works off the cam. Thank for the correction. Share this post Link to post Share on other sites
BHunter 1,702 #14 Posted August 28, 2020 4 hours ago, WHX24 said: That would be great if you can Mike. Might as well take it apart Bob you got nothing to lose. You'll find a valve plate in ther with two little springs and check valves that are gunked up. the diaphragm will have to be replaced if we can get ahold of Brian and he has them. I was going to do a rebuild instructional on them once I get mine sorted out. No you shouldn't have to prime it. Your springs are bigger. Mine have 4 coils and are very light weight. Do they have different fuel pumps for different hp motors? I wish i took a picture of all the slime on my springs and other parts. No wonder it wouldn’t pump. Share this post Link to post Share on other sites
Jennifer 1,878 #15 Posted August 28, 2020 (edited) 1 hour ago, BOB ELLISON said: I ordered 2 sets from then and now in june of this year. I rebuilt my c160 pump and it works good. But you have to call him. I never could get a return email. http://www.then-now Edited August 28, 2020 by Jennifer 3 Share this post Link to post Share on other sites
ebinmaine 80,767 #16 Posted August 28, 2020 I found Brian's phone number. I'll call him tomorrow and tell him y'all's is lookin ferr im... 1 2 Share this post Link to post Share on other sites
WHX?? 58,230 #17 Posted August 28, 2020 (edited) 12 hours ago, BHunter said: Your springs are bigger. Correct Bob those are not the original springs. Those are from a gas valve conversion kit ( @squonk knows) that I was just experimenting with but seem two heavy. This pump did not have any or got lost in disassembly. The originals are quite dainty. This kit was from an ebay cheapy source for the cam style. Not much to it but two of them for 14 bucks. No valve plate gasket, valves, springs or anything. What you see is what you get. Note the made in China ....... go figure. That first pic I had to make a valve plate gasket using the old one as a template. Good enough to experiment with tho. Was thinking grind off the diaphragm to cam lever connector and try just using the diaphragm in a pulse style pump. Like Jennifer have one coming from then and now as well to play with and evaluate. Like I mentioned earlier trying to collect information about pumps to do a rebuild instructional thread on them. Plus I'd like to have a spare of each style on the shelf ready to roll if one goes out. Edited August 28, 2020 by WHX24 Share this post Link to post Share on other sites
WHX?? 58,230 #18 Posted August 28, 2020 12 hours ago, ebinmaine said: I found Brian's phone number. I'll call him tomorrow and tell him y'all's is lookin ferr im... EB 1 Share this post Link to post Share on other sites
ebinmaine 80,767 #19 Posted August 28, 2020 12 hours ago, ebinmaine said: I found Brian's phone number. I'll call him tomorrow and tell him y'all's is lookin ferr im... Folks I just talked to Brian. He has a regular house which is the number that I have and then he has a cottage which is where they've actually been staying most of the summer. I happened to catch him when they were home because he has the day off. He does have some of the diaphragms available for sale. He said to go ahead and p.m. him through Redsquare and he will try to remember to check his email more often. 1 Share this post Link to post Share on other sites
WHX?? 58,230 #20 Posted August 28, 2020 (edited) 15 hours ago, BHunter said: able to clean the nasty tar like stuff off the diaphragm with wax and grease remover. I Tried that too Bob mine was just too stiff, brittle and dried out for further service. Edited August 28, 2020 by WHX24 Share this post Link to post Share on other sites
WHX?? 58,230 #21 Posted August 28, 2020 13 hours ago, BOB ELLISON said: But you have to call him. Did you get one ordered from then and now @Jennifer ? I am having problems getting through but will keep trying. Share this post Link to post Share on other sites
buckrancher 2,697 #22 Posted August 28, 2020 WHX24 pm sent 1 Share this post Link to post Share on other sites
ebinmaine 80,767 #23 Posted August 28, 2020 22 minutes ago, WHX24 said: EB No worries brother man Share this post Link to post Share on other sites
ebinmaine 80,767 #24 Posted August 28, 2020 1 minute ago, buckrancher said: WHX24 pm sent Thank you Brian. Good to talk to you again. Share this post Link to post Share on other sites
tom2p 2,396 #25 Posted August 28, 2020 19 hours ago, BHunter said: @WHX24 I did what you said and figured I had nothing to loose. I took it all apart and was able to clean the nasty tar like stuff off the diaphragm with wax and grease remover. It runs great now. It doesn’t crank , it fires right up . IMG_4663.MOV music to my ears ! the Kohler in our 704 was similar - the pullstart barely engaged but just a small amount was enough and it would fire immediately ran like this for over 20+ years - just a few spark plug changes ... never touched the points Share this post Link to post Share on other sites
