RandyLittrell 3,946 #26 Posted August 4, 2020 Easy off oven cleaner works wonders to get off grease and grime, just power wash then dry it well. Scuff pad what you can get to then use a final wash before paint. Works for me. randy 2 Share this post Link to post Share on other sites
Racinbob 13,250 #27 Posted August 4, 2020 1 hour ago, Gordyhogg said: Thanks @Racinbob for the tip. It is definitely getting torn apart i cant keep it in 3rd gear lol You're welcome. I'm afraid that you have a worn 3523 gear causing your problem. Quite a common problem. The input shaft/gear might be adding to the problem. Keep us posted once you get her apart. 1 Share this post Link to post Share on other sites
953 nut 70,067 #28 Posted August 5, 2020 14 hours ago, Gordyhogg said: love the way you guys think outside the box Some on here think outside the padded call they should be confined to! 1 4 Share this post Link to post Share on other sites
WHX?? 58,326 #29 Posted August 5, 2020 13 hours ago, Racinbob said: You're welcome. I'm afraid that you have a worn 3523 gear causing your problem. Quite a common problem. The input shaft/gear might be adding to the problem. Keep us posted once you get her apart. https://wheelhorsepartsandmore.com/transmissions.html#!/3523-3rd-gear/p/84932562/category=23548039 Share this post Link to post Share on other sites
Gordyhogg 150 #30 Posted August 5, 2020 22 hours ago, Racinbob said: You're welcome. I'm afraid that you have a worn 3523 gear causing your problem. Quite a common problem. The input shaft/gear might be adding to the problem. Keep us posted once you get her apart. Will definitely keep yall posted thankfully lowell has em new for 85 bucks i think 2 Share this post Link to post Share on other sites
WHX?? 58,326 #31 Posted August 5, 2020 (edited) On 8/4/2020 at 5:42 PM, Racinbob said: The input shaft/gear might be adding to the problem. I think what Bob is saying here is he shims the input shaft inward if there is any slop to keep the input shaft firmly into the 3rd gear. I've never done this but not a bad Idea and @Achtohas a horse that pops out that he is going to fix some day and will look at this. His 3rd gear looked pretty decent when he had it apart. Don't throw the old one out Dan makes dandy hitch pins out of them! Geez I shoulda posted that in repurpose Dan! Edited August 5, 2020 by WHX24 'Nother pic 3 1 Share this post Link to post Share on other sites
Racinbob 13,250 #32 Posted August 5, 2020 40 minutes ago, Gordyhogg said: Will definitely keep yall posted thankfully lowell has em new for 85 bucks i think Excellent. Do this little check before you open it up. Put the transmission in 3rd gear and only let the shift rail detents hold it there (engine not running). See if there's any in/out play on the drive pulley. It should be zero. If there is any at all measure it the best you can. When you reassemble it you need to put an arbor shim in that thickness on the input shaft behind the gear before you slip in into the case. 2 minutes ago, WHX24 said: I think what Bob is saying here is he shims the input shaft inward if there is any slop to keep the input shaft firmly into the 3rd gear. I've never done this but not a bad Idea and @Achtohas a horse that pops out that he is going to fix some day and will look at this. His 3rd gear looked pretty decent when he had it apart. Don't throw the old one out Dan makes dandy hitch pins out of them! I was typing as you posted Jim. Very true. Any in/out play is how much the two gears are separating as you're using it. If it's popping out of gear the shim itself probably won't cure it but it will help save the new 3523. The new gear itself won't eliminate the play. 2 Share this post Link to post Share on other sites
Gordyhogg 150 #33 Posted August 7, 2020 Will do! I will have to post a picture of this later but would you guys have any idea why the shifter touches the frame when its in 2nd gear? Also heres a little sneak peek at the new paint 1 Share this post Link to post Share on other sites
WHX?? 58,326 #34 Posted August 7, 2020 Looks nice, Is the shifter bent? Share this post Link to post Share on other sites
Gordyhogg 150 #35 Posted August 7, 2020 1 minute ago, WHX24 said: Looks nice, Is the shifter bent? Thanks! Not from what i can tell but its entirely possible Share this post Link to post Share on other sites
Gordyhogg 150 #36 Posted August 7, 2020 If you look real close in this picture you can see the divet where its hitting Share this post Link to post Share on other sites
Gordyhogg 150 #37 Posted August 7, 2020 Heres where its hitting and stick doesnt seem bent Share this post Link to post Share on other sites
ebinmaine 81,048 #38 Posted August 7, 2020 Maybe the forks have a bit of play? When you assemble it you can double check the adjustment on the dog point screw. 1 Share this post Link to post Share on other sites
Gordyhogg 150 #39 Posted August 8, 2020 11 hours ago, ebinmaine said: Maybe the forks have a bit of play? When you assemble it you can double check the adjustment on the dog point screw. Is that the one that holds the shifter in the hole? Share this post Link to post Share on other sites
ebinmaine 81,048 #40 Posted August 8, 2020 8 minutes ago, Gordyhogg said: Is that the one that holds the shifter in the hole? Yessir 1 Share this post Link to post Share on other sites
Terry M-(Moderator) 2,329 #41 Posted August 9, 2020 Upgraded my 606 with a nice fresh K161.... 3 4 Share this post Link to post Share on other sites
Gordyhogg 150 #42 Posted August 11, 2020 Thats a nice lookin tractor! @Terry M Share this post Link to post Share on other sites
Gordyhogg 150 #43 Posted August 11, 2020 On 8/8/2020 at 7:27 AM, ebinmaine said: Yessir @thanks @ebinmaine 1 Share this post Link to post Share on other sites
Gordyhogg 150 #44 Posted August 11, 2020 (edited) finished the hood! And also painted the mount and four bolts (not pictured) next will be to finish the body work on the fenders and paint them too. Edited August 11, 2020 by Gordyhogg 2 Share this post Link to post Share on other sites
Racinbob 13,250 #45 Posted August 14, 2020 On 8/4/2020 at 4:10 PM, Vinylguy said: Is that a 4 or 8 speed B-160? PM sent Terry. I'm finally getting off my lazy butt and getting a pair of these. 1 Share this post Link to post Share on other sites
