ebinmaine 73,288 #1 Posted July 25, 2020 I thought I'd saved a link to threads with the info we need but I can't find it. Thanks in advance for answering again. @Stepney has a hydro lift setup I'm adding to my Charger. The obvious to me is we need the correct rockshaft, hoses, and valve/lever. What needs to be removed/swapped to my manual lift hydro transmission from his hydro lift transmission? Are there different fittings/valves, etc?? @953 nut @pfrederi @daveoman1966 Share this post Link to post Share on other sites
The Tuul Crib 7,339 #2 Posted July 25, 2020 13 minutes ago, ebinmaine said: I thought I'd saved a link to threads with the info we need but I can't find it. Thanks in advance for answering again. @Stepney has a hydro lift setup I'm adding to my Charger. The obvious to me is we need the correct rockshaft, hoses, and valve/lever. What needs to be removed/swapped to my manual lift hydro transmission from his hydro lift transmission? Are there different fittings/valves, etc?? @953 nut @pfrederi @daveoman1966 I would be interested in the same thing Eric. I'm going through my sunstrand and would like to get the same control for my deck and maybe more. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,558 #3 Posted July 26, 2020 Would this help? Garry 2 1 1 Share this post Link to post Share on other sites
ebinmaine 73,288 #4 Posted July 26, 2020 @gwest_ca That's exactly what I was looking for! Share this post Link to post Share on other sites
