Flat Thunder Channel
Generator Head/AC Power
Anyone have creative ideas / designs for building an economical generator for 520 tractor?  I have always wanted one and contemplated building one a time or two before.  I have only found a few used models over the last 20 years.  Recently saw a new old stock unit on a tractor on Instagram.  It was pretty awesome!
ebinmaine
:popcorn:
Tractorhead
I think i can remember in the classified section was a Genny, but it was few moons ago.
Maybe someone have a Generator for sale.
If i would have such a need, i would search for an used combined genny with a defect Engine.
Remove all the Engine parts, built an Mounting plate where the Genny can be hooked up
and search for a taper pulley, that fits on the axle.
Try to calculate the right rpm speed when the Horse engine is in about 2/3 speed, to have enough reserves
in revning up while under Load.
if the rotation direction must be changed, simply use a Jackshaft.
So the belt can used with PTO Clutch to start the Genny.
another advance, on most Genny‘s there are plugs and safetyswitches be mounted.
WHX??
I had one that I traded to @953 nut for a seat. It came with a 520 score and I am already genny heavy so good trade. . It had a bracket that clipped to the front attach. The bracket on the right I don't know what the other bracket was for never futzed with it.  Maybe use a old snow blower attach with a mounting plate like the MN boys do with their plow weights??? A mule drive worked over and modded?
Here's another one to wrap yer head around... a front mounted air compressor! I'm sure that's been done before and maybe saw a piece of old :wh: where it was an option.
Edited by WHX24
15 hours ago, Racinbob said:
This looks like it would be a good start. I've seen a couple of guys fabricate a mount similar to a factory unit. :)
https://www.harborfreight.com/10000-watts-max-7200-watts-rated-belt-driven-generator-head-45416.html
I think I went down this road when I saw these generator heads while roaming around HF.  I question any electronics from Harbor Freight (aka The Chinese outlet mall).  It might work great not for sure.  Has anyone used these generator heads before?
I have an old Powerchief generator.  It works amazing, but it's a bear to move.  My best approach is to drag it and or two wheel cart it around.  Always seems like my two wheel cart is buried behind something.  I used it yesterday for the first time this year.  Started on the first pull.  Now that's quality!
@WHX24The manual shared is awesome!!! Thanks for posting.  I never knew an air compressor attachment existed.  These are such unique/universal tractors. 😁👍
WHX??
Your :text-welcomewave:Flats.... I like looking at the prices. A complete loader for a little over 500 bucks!?!?! 30 for a ballast box!?!?
Wouldn't buy you just  the steel for the bucket now days!
I talked to my neighbor yesterday.  He is a wheelhorse fan too.  We talked about the generator project.  In our discussion he offered up a generator head from his old unit.  The motor still works but the generator stopped making power.  He is going to keep the engine, but said I could have the generator.  If I am lucky I can repair the generator head and have good unit for the Wheelhorse mount.  I was thinking about this project over the last couple days.  I would like to mount it so it does not impede the functionality of the tractor.  I'll have to see how large this thing is first.  Ideally I could operate the mower, snow blade, and open the hood without lifting the genset off.  We will see how it goes. 🤔
pfrederi
Generators are heavy.  leaving it on while trying to mow or what ever you will find the steering very very hard.
bc.gold
Years ago arranged the rental of a small portable welder over the phone then when i had showed up at the rental place thought  the welder was a JOKE. It was a Delco automotive alternator running off a small single cylinder gas engine.
Built a steel deck and mounted a pto style Braden winch most of the welds were very long runs, using 7018 rod this little welder never failed to perform.
You''ll find plenty of tube vids out there showing how to convert a Delco into a welder.
This video is of interest as i shows the alternator running universal power tools.
Good point!  I will have to see how large the generator head is.  Inverter generators are tiny, but i have no idea what this unit is.  I know it is a 'freebie'!  If i can fix it great.  If it can't be readily fixed it will go in the scrap hopper.  :)
  • Similar Content
    • DevonianHorse
      By DevonianHorse
      Hi all, on a 1977 Wheelhorse C-100 (Belgium made), I have a question
      My Wheelhorse hood opens really far- it does eventually stop but I don't think it is meant to go this far and that there's a piece missing.
      In this photo, there's a hole you can see (near the middle of the pic, 1/3 down) and the same on the other side of the hood mounting part of the frame- I assume some sort of bar is meant to go between them that the hood latches at the base will catch on and this stops the hood dropping further when opened? If this makes no sense sorry- I have simply always assumed that the hood is meant to open at a right angle from the front, but having seen videos, I can see most stop before that.
      Does anyone know the part I need, or would two bolts, one on each side, do the job? Mine has never had one, so I am unsure.
      Thanks!!
    • crich8878
      By crich8878
      Its a 1969 GT-14
      Mower, snowblower, tire chains attachments
      Everything works.
      Always stored inside, just dusty.
      Model: 1 7441
      Serial: 555525
      $1500 OBO
      (*just took the hood off to get it running in the video, its there*)
      IMG_7731.mov
    • Donavon1
      By Donavon1
      Need some help deciding on a brand of engine to buy for my 1054. (Needs to be a diesel 10 hp+) I’m refining used motor oil/cooking oil for fuel for it. So it will have to have an option to run used oil and diesel
    • MainelyWheelhorse
      By MainelyWheelhorse
      Hi All, I’m a member of the RedSquare Facebook group, some of you may have seen My tractor there. I have a 1992 312-8 with a 37 inch deck. It came with a house my brother bought, and was given to me. It needed work but just minor things. I mow my lawn with it, and I just bought a plow to push snow/dirt so it’s a working restoration. It was relatively well taken care of by the previous owners so it really just needed a refresh. Anyway see you around the site!
    • Rob R
      By Rob R
      So... I got cabin fever and against my best judgement, picked up from my brother a 520H Model # 4120OE02; Serial 1033076 (1991) that he got from a Friend who claim it ran but hasn't been used in years and was in dry storage. Included was a 48-inch triple blade mower in very good condition, total cost $250 ..... I figured that even if the tractor was no good the deck was worth the coinage....... and it had a good new battery....... So got it home fixed the one flat tire, replace the cooked fuse in the fuse holder. Cranked the engine over it cough a few times and then quit, was not getting fuel, replace the fuel line from the tank to the pump, pump not pumping, replace it with a B&S pump, cranked her over and she started right up ran and idled decent with no noticeable smoke. p.s. the hour meter is disconnected but you can tell she was run hard and put away wet but overall, in fair to good condition.
      So without doing anything else time for a test drive. It moved forward and backwards took her out into the yard got about 50 feet and the motor started laboring to me was like the transmission was putting a heavy load on engine, I tried to shift into neutral, but it wouldn't let me do that and then the engine bogs down and shuts off. Wait like 10 seconds start her up again and the issue repeats.... In all my years I have never had anything close to this issue hence my call for help.
      I did all the normal stuff trans fluid looks clean added some 10-40 weight to top her off, did not change the filter yet as I do not have one in stock.  You can start the engine without engaging the transmission and it will run fine until the cows come home..... put it in gear forward or reverse and it will go an little ways and then the load condition occurs, the engine loads up and is dragged down into a stall.
      Appreciate all your advice as this one has me stumped......
