ebinmaine 81,281 #8701 Posted August 8, 2025 1 hour ago, 8ntruck said: Oh, you've just been living free for a few years.... Oh no no no. It wasn't my car. I don't have the cojones to pull off something that stupid. My employment depends on me having a spotless record. 1 Share this post Link to post Share on other sites
jeremi3210 759 #8702 Posted August 8, 2025 4 hours ago, WHX?? said: Tagging @jeremi3210 & @Pullstartas they have the same camper. Keep an eye on it bros. Ramp door must have been leaking. A long time by the way it looks. Linoleum trapped the moisture in. Spent two days ripping out rotted wood and replacing. Not a huge job but 85 in the shade here. Cut the moldy linoleum out to the top of the dove tail and new underlayment to be coated with bedliner. Used treated lumber for all it's worth. Thanks for the heads up! That must have been leaking since new. Did you just notice mold or was it getting soft? Share this post Link to post Share on other sites
SylvanLakeWH 32,919 #8703 Posted August 8, 2025 Ruger LCP Max .380 Very similar size. Excellent little gun. 2 Share this post Link to post Share on other sites
Beap52 2,537 #8704 Posted August 8, 2025 3 hours ago, SylvanLakeWH said: Ruger LCP Max .380 Very similar size. Excellent little gun. Ruger LCP .380. one of the older models. I've painted the tiny fixed sites to help me in alignment, Green laser and Sneaky Pete holster. I also have a Ruger LCP .22 with same set up. The .380 is my CCW. The green laser allows me to cluster shots about size of paper plate at 21 feet. Which for me, who not a good shot, and 2.75" barrel suits me. I have carried this holster for more than two years. On the net, many poo poo this style of holster but it's exactly what I like. Comfortable to wear, pretty easy to remove for locations that personal protection is not allowed. I have never been asked what it's purpose is (even at church) and I have adapted it for other uses. The holster came with a plastic liner that helps hold the pistol in upright position. The liner wouldn't allow the pistol with laser installed to be inserted. By removing original and making my own liner, the gun fits and as an added benefit, my New Testament Bible slides in perfectly. This covers my needs as well as I can expect. I normally carry my phone on a belt holster, When CCW, the phone goes to shirt pocket and Sneaky takes it place. I purchased the .22 a year ago. I have access to a large lot of ammo so when I go to the range or to the farm, I get much more practice time. The .22 is not nearly as reliable but for plinking and practice, it works. 4 Share this post Link to post Share on other sites
adsm08 5,247 #8705 Posted August 8, 2025 Tore open the Escape to start on the rocker repairs. It's worse than I thought. The big issue is that what were sold as "full length rockers" did not include the arch at the front of the rear wheel well. The dog-leg is sold as a separate panel, and mos of the really bad rot is in that section. I guess I'll work on something else this weekend. 1 Share this post Link to post Share on other sites
WHX?? 58,388 #8706 Posted August 9, 2025 10 hours ago, jeremi3210 said: Did you just notice mold or was it getting soft? Loading tractors for Symco noticed a soft spot. The upper corner of the door was bent in from dropping too hard so I believe the seal was compromised. What's worse is i stored the camper pitched to the back so I think melting snow ran in. More investigation is in order. Dan suggested some sort of drip shield above the door. 3 Share this post Link to post Share on other sites
adsm08 5,247 #8707 Posted August 9, 2025 6 hours ago, WHX?? said: i stored the camper pitched to the back That will do it. I had a vehicle with one those cab visor deals on it. The silicone around the bolts broke down and if I parked it facing down hill in the rain I'd get wet when I drove away. Share this post Link to post Share on other sites
adsm08 5,247 #8708 Posted August 9, 2025 12 hours ago, Beap52 said: The green laser allows me to cluster shots about size of paper plate at 21 feet. Which for me, who not a good shot, and 2.75" barrel suits me. Pistols are harder to control than a long gun, and the short barrel makes them less consistent. When I take mine to the range I'm happy if I can take the target paper, hold it across my chest, and have all the holes inside the outline of my body. It might not be the kind of accuracy I want from a hunting rifle, but at least I didn't miss the bad guy. 1 Share this post Link to post Share on other sites
Bar Nuthin 3,642 #8709 Posted August 10, 2025 Getting ready for a fishing trip - one problem I always face is finding a level spot for my Banjo burner. The fact that it has a circular base makes it hard to get level and be sturdy at the same time. If it's not perfectly level the oil in my 15" iron skillet runs to one side. So, while I had my welder out, I decided to remedy that problem. 5 Share this post Link to post Share on other sites
peter lena 10,125 #8710 Posted August 10, 2025 @adsm08 a door and related rocker , trunk , tailgate from the inside top edge , for full coverage , lubrication creep , easy and protective . marvel at the newer trucks , with cab , fender wells , tailgates , rotted out , MAC,S CABLE ,GEAR SPRAY , FOLLOWED WITH OPEN GEAR SPRAY , NAPA . first lighter oil will creep and stain / wet , showing you tracking , days later heavier over spray , will be carried by lighter oil . all my doors , tailgate , trunk , have atop to bottom oil film , at every seaming area , bottom of cars also , zero rot / rust . showed my grandson how to mineral oil his car finish , perfect patina . initial closed areas , spray from inside top of door , so run down effect covers the entire make up of door with nozzle extension tube . been doing this since starting to drive . the same basic lighter oil is also terrific on faded wheel horse paint , my 3 horses have been easily buffed out , go oily , pete Share this post Link to post Share on other sites
ebinmaine 81,281 #8711 Posted August 10, 2025 Busy as hell here today. Started out with an hour workout. Trina and I did a one hour resistance training workout this morning. The gym is finally taking shape and getting cleaned up and organized. Body weight movements on the mats. Heavier motions on the rack. Had a great breakfast/brunch. Our own eggs, organic Australian ground beef, aged Dublin cheddar cheese. The hash brown is lovely. Lots of protein here. Got the big air compressor moved yesterday. Today I got the hose reel all on. Then switched to getting the last couple long bolts 🔩 in the pole trailer. The two closest ones to the tires. They're the only bolts that go through all four crossed layers so they're integral to the structural strength of the whole unit. Trina and her momma been working on firewood. The chickens 🐔 are 🔥 🥵 and relaxing. 4 Share this post Link to post Share on other sites
Sparky-(Admin) 26,898 #8712 Posted August 10, 2025 Went for an almost 13 mile bike ride with my mom this morning. She’s 81 years old!! No battery power either…we pedaled it all. 6 5 Share this post Link to post Share on other sites
adsm08 5,247 #8713 Posted August 10, 2025 2 hours ago, peter lena said: @adsm08 a door and related rocker , trunk , tailgate from the inside top edge , for full coverage , lubrication creep , easy and protective . marvel at the newer trucks , with cab , fender wells , tailgates , rotted out , MAC,S CABLE ,GEAR SPRAY , FOLLOWED WITH OPEN GEAR SPRAY , NAPA . first lighter oil will creep and stain / wet , showing you tracking , days later heavier over spray , will be carried by lighter oil . all my doors , tailgate , trunk , have atop to bottom oil film , at every seaming area , bottom of cars also , zero rot / rust . showed my grandson how to mineral oil his car finish , perfect patina . initial closed areas , spray from inside top of door , so run down effect covers the entire make up of door with nozzle extension tube . been doing this since starting to drive . the same basic lighter oil is also terrific on faded wheel horse paint , my 3 horses have been easily buffed out , go oily , pete New metal first. Then lubrication and water displacement can be worried about. I did not own this vehicle for most of it's life. It's the second time I've owned it, but I've only had it 4 years out of 15. Also, unfortunately, the rockers were designed to rot out like this on purpose. 1 Share this post Link to post Share on other sites
ebinmaine 81,281 #8714 Posted August 10, 2025 I'm happy to announce that the barn is beginning to have freed up space! 1 Share this post Link to post Share on other sites
Bar Nuthin 3,642 #8715 Posted August 10, 2025 11 minutes ago, ebinmaine said: I'm happy to announce that the barn is beginning to have freed up space! Every time I say that about my garage, I have to add, "for now". 1 Share this post Link to post Share on other sites
c-series don 12,752 #8716 Posted August 10, 2025 @ebinmaine Perfect timing Eric, because I’m going to have two C-160 automatics for sale soon 🤣🤣 1 4 Share this post Link to post Share on other sites
ebinmaine 81,281 #8717 Posted August 10, 2025 3 minutes ago, c-series don said: @ebinmaine Perfect timing Eric, because I’m going to have two C-160 automatics for sale soon 🤣🤣 You bring em up. 1 Share this post Link to post Share on other sites
ebinmaine 81,281 #8718 Posted August 10, 2025 4 minutes ago, Bar Nuthin said: Every time I say that about my garage, I have to add, "for now". Gotta get the parking spots back for winter. 1 Share this post Link to post Share on other sites
adsm08 5,247 #8719 Posted August 10, 2025 17 minutes ago, ebinmaine said: Gotta get the parking spots back for winter. I'm going to have to start worrying about that soon as well. That means getting the Escape put back together sometime before Christmas. Although I'm really hoping the new shop is up by then. Even if the floor isn't in I can store stuff/park there. Share this post Link to post Share on other sites
c-series don 12,752 #8720 Posted August 11, 2025 (edited) Today we went out to the very end of Long Island, to Montauk. The sport fishing capital of the world, some say it was the inspiration for the movie Jaws. We had lunch at a nice restaurant at the inlet to Montauk harbor watching the pleasure and commercial fishing boats come and go. I’m sure most of you know the Billy Joel song Downeaster Alexa. The boat in the last two pictures is that boat, the “Alexa” it’s actually his own boat. It’s docked a few towns to the east in Sag Harbor. I didn’t realize that was it until it was well past us. Quite possible it was him running the boat because he is known to captain his own vessel. Way off on the horizon is the Connecticut shoreline. Edited August 11, 2025 by c-series don 8 Share this post Link to post Share on other sites
TonyToro Jr. 2,560 #8721 Posted August 11, 2025 (edited) Took the doggy for an about 30 min walk around the property then gave her a water break in grandpas garage. When re stocking the stand this morning I found I weird squash in the garden. I called it exotic! Sold some stuff at the farm stand, Rototiled the garden, and bled the brakes on my quad. Edited August 11, 2025 by TonyToro Jr. Added pics 8 Share this post Link to post Share on other sites
8ntruck 9,420 #8722 Posted August 11, 2025 (edited) We slept in. Once we got moving, we went down to the lake house, mixed a couple bloody Marys, and fired up the Blackstone to cook a breakfast scramble out on the deck. Bulk sausage, onions, garden cherry tomatoes, hash browns, and eggs. Salt, pepper, horseradish, ground cumin, cumin seed, and diced jalapeños were used for seasoning. Oh, I also did some raking in the back yard and replaced the furnace filter so I can say I did something useful today. Edited August 11, 2025 by 8ntruck 3 Share this post Link to post Share on other sites
Wayne0 1,666 #8723 Posted August 11, 2025 (edited) On 8/8/2025 at 6:51 PM, Beap52 said: Ruger LCP .380. one of the older models. I've painted the tiny fixed sites to help me in alignment, Green laser and Sneaky Pete holster. I also have a Ruger LCP .22 with same set up. The .380 is my CCW. The green laser allows me to cluster shots about size of paper plate at 21 feet. Which for me, who not a good shot, and 2.75" barrel suits me. I have carried this holster for more than two years. On the net, many poo poo this style of holster but it's exactly what I like. Comfortable to wear, pretty easy to remove for locations that personal protection is not allowed. I have never been asked what it's purpose is (even at church) and I have adapted it for other uses. The holster came with a plastic liner that helps hold the pistol in upright position. The liner wouldn't allow the pistol with laser installed to be inserted. By removing original and making my own liner, the gun fits and as an added benefit, my New Testament Bible slides in perfectly. This covers my needs as well as I can expect. I normally carry my phone on a belt holster, When CCW, the phone goes to shirt pocket and Sneaky takes it place. I purchased the .22 a year ago. I have access to a large lot of ammo so when I go to the range or to the farm, I get much more practice time. The .22 is not nearly as reliable but for plinking and practice, it works. Everybody "poo-poos" the .380 as not powerful enough. I know one thing, I wouldn't want to be hit by one! With the right bullet and load, it's fine! I don't carry as most of my pistols are too bulky. I do have a Star Mo. BM 9mm. Basically a mini 1911. Small enough, but heavy. No plastic. Edited August 11, 2025 by Wayne0 Share this post Link to post Share on other sites
ebinmaine 81,281 #8724 Posted August 11, 2025 Projects for this evening. Unfortunately, we're in a drought here. On the plus side, Trina took advantage of the ultra low water levels to clean out the bottom of the frog pond 🐸 We're headed to the Great North Maine Woods soon. Rough camping at its finest. In the past I've made a "lavatory" outta 3 logs. This year I'm goin' full luxury! I'm using a step stool as the base. Full plastic toilet seat for weather proof long lasting construction. 2 Share this post Link to post Share on other sites
adsm08 5,247 #8725 Posted August 11, 2025 9 hours ago, Wayne0 said: Everybody "poo-poos" the .380 as not powerful enough I prefer the .380 over the 9mm. Same bullet, different powder load. 9mm is prone to over-penetration, .380 is not, and neither is going to pierce body armor. 2 Share this post Link to post Share on other sites
